Home » Eclipse Projects » Nebula » CompositeTable has landed. :-)
| CompositeTable has landed. :-) [message #14795] |
Sat, 21 October 2006 02:37  |
CompositeTable source code has just been committed to Nebula CVS with
the following features:
- Edit your grid visually using the Eclipse Visual Editor
- Use *any* SWT control anywhere in your grid's header or row
- Automatically edit in-place with zero extra code
- Fully virtual -- only requests data that it actually displays
- Insert / delete either programmatically or from the user interface.
- Supports the new JFace Data Binding API (binding code in the JFace
data binding examples plugin)
In addition, an example Outlook(r)/PalmOS(r) calendar control has been
submitted illustrating some of the more sophisticated things that can be
done with this control.
I'll be working with Chris to make a full download available as soon as
possible. In the meantime, grab HEAD and try out CompositeTableTest and
DayEditorTest to see how things work.
Dave Orme
| Re: CompositeTable has landed. :-) [message #15247 is a reply to message #15214] |
Sat, 21 October 2006 16:02   |
Originally posted by: alnospammajor.noboxspamspoon.com
if this works as the snippet implies, one option for me would be to
modify the standard JFace viewer so that it'll
a) provide a model that allows a representation of arbitrary widgets in
rows, kinda like CTableTreeViewer
b) use the ***Editor classes within this modified viewer to implement
the arbitrary widgets using the standard Tree controls
c) change the row-height of TreeItem (on a first glance at the code,
this actually seems to be the only thing that the current design makes
difficult).
this seems a bit like re-inventing CTableTreeViewer without the
tree-in-every-cell feature (which i don't need). but since that viewer
needs to be modified to support my use-case (ITreePathContentProvider),
this may actually be the easiest option for me.
however, this is such a common use-case (i think) that it begs to be
abstracted. it probably should be in JFace to begin with. or somewhere
else where it can be re-used.
al
Chris Gross wrote:
> The base SWT TableEditor/TreeEditor classes can be specifically
> activated or active all the time. Its up to you. See the following SWT
> snippet:
> http://dev.eclipse.org/viewcvs/index.cgi/~checkout~/org.ecli pse.swt.snippets/src/org/eclipse/swt/snippets/Snippet126.jav a
> Regarding JFace viewers, I believe you can use a viewer and still create
> and use a regular SWT TableEditor. JFace viewers also have a paradigm
> for using its own cell editors which are typically triggered by clicking
> on the cell. I'm not sure if JFace has a way to keep an editor active.
> -Chris
> Al Major wrote:
>> plus, i do like JFace style model/view separation, so would want
>> viewers on top of the TreeEditor/Tree combo.
>> Al Major wrote:
>>> but that's an API for embedding a widget, one cell at at time
>>> (whichever cell is being in-place-edited), correct? i just assumed it
>>> wasn't appropriate for a table/tree that may have half or more of
>>> it's cells be arbitrary widgets. if that's an incorrect assumption, i
>>> would definitely consider that as an option.
>>> Chris Gross wrote:
>>>> It should be noted that you can use an TableEditor/TreeEditor to
>>>> embed any widget in even the standard SWT Tree and Table.
>>>> -Chris
>>>> Al Major wrote:
>>>>> how does this compare with CTableTree's functionality. can i
>>>>> embed a GEF viewer in a row? that's the primary use case i'm
>>>>> interested in.
>>>>> i'm assuming that this means the row heights can be set
>>>>> individually.
>>>>> how does CompositeTable compare to CTableTree in general?
>>>>> thx,
>>>>> al
| Re: CompositeTable has landed. :-) [message #15280 is a reply to message #14825] |
Sat, 21 October 2006 16:41   |
> how does this compare with CTableTree's functionality. can i embed a
> GEF viewer in a row? that's the primary use case i'm interested in.
I believe that CTableTree is lightweight. CompositeTable works by
pasting together existing SWT controls to look and behave like a table.
> i'm assuming that this means the row heights can be set individually.
Currently all rows must be the same height. If you need flexibility
here, please file a bug or better yet, contribute a patch. :-)
CompositeTable makes no attempts to be a tree and it's best to think of
it as like a *really* powerful tabular layout manager because it
fundamentally works with other controls that you supply.
The advantage is that you get complete flexibility for how the users
will interact with your table as well as complete flexibility about
mixing and/or matching lightweight and heavyweight controls inside your
table. The disadvantage is that a highly-optimized lightweight control
will draw and, resize, and scroll somewhat faster.
To see both the advantages and disadvantages in action at once, try
running the DayEditorTest demo, which implements an Outlook-like work
week calendar control. It really powerful and looks nice, but when you
load a lot of data into it, there are a few visible artifacts when you
scroll where you can see the layout managers delegating layout semantics
to all of the embedded controls.
DayEditor is an extreme example both of how graphical you can get with
CompositeTable and also pushes the limits of what you can do nicely with
it performance-wise, so it's a pretty good example to study.
Dave Orme
Dave Orme
| Re: CompositeTable has landed. :-) [message #15444 is a reply to message #14910] |
Sun, 22 October 2006 16:34   |
> ...is there an easy way to do
> master/detail rows (basically a tree of depth 2)?
Master/Detail rows is what caused CTableTree to be created in the first
place, though maybe we're talking about different things here.
A master/detail block, as one might create using the Forms toolkit, has
a table on one side and a detail composite on the other. As the user
selects an item from the table, the appropriate info is filled in, and
is editable in, the child controls of the detail composite.
see the pic most of the way down this page:
http://www.eclipse.org/articles/Article-Forms/article.html
When using the CTableTree, each cell's title area effectively creates
the master table but rather than having a separate detail composite to
the side, it is in the child area of the cell (which can now span the
width of the table width if necessary).
see in the first pic's upper left, "Contacts", view part:
http://www.aspencloud.com/screenshots.php
Is there a reason you do not use the child area of the CTableTreeCell?
| Re: CompositeTable has landed. :-) [message #15573 is a reply to message #15477] |
Mon, 23 October 2006 08:16  |
> CTableTree can be either, or both. It works by pasting together
> CTableTreeCells which have a Title Area and a Child Area and thus allow
> each cell to create and display itself in two stages.
> One way to begin looking at a CTableTree is to view each column as a
> vertical list of ExpandableComposites (or PGroups), where both the title
> and child can contain anything, or have anything drawn on them using a GC.
That's pretty cool. :-)
Dave
| Re: CompositeTable has landed. :-) [message #567052 is a reply to message #14795] |
Sat, 21 October 2006 13:15  |
thx,
al
| Re: CompositeTable has landed. :-) [message #567087 is a reply to message #14795] |
Sat, 21 October 2006 13:18  |
does CompositeTable use content providers ala JFace? if so, does it
support ITreePathContentProvider?
> Best regards,
> Dave Orme
| Re: CompositeTable has landed. :-) [message #567121 is a reply to message #14855] |
Sat, 21 October 2006 13:19  |
i see that there's no nebface viewer correspondong to CompositeTable, so
i'm assuming the answer to my questions are no and no.
>> be done with this control.
>> as possible. In the meantime, grab HEAD and try out
>> CompositeTableTest and DayEditorTest to see how things work.
>> Best regards,
>> Dave Orme
| Re: CompositeTable has landed. :-) [message #567158 is a reply to message #14825] |
Sat, 21 October 2006 13:39  |
one difference appears to be tree functionality. i'm assuming
CompositeTable doesn't provide any. but is there an easy way to do
| Re: CompositeTable has landed. :-) [message #567171 is a reply to message #14825] |
Sat, 21 October 2006 13:58  |
It should be noted that you can use an TableEditor/TreeEditor to embed
-Chris
> thx,
> al
| Re: CompositeTable has landed. :-) [message #567226 is a reply to message #14930] |
Sat, 21 October 2006 14:13  |
but that's an API for embedding a widget, one cell at at time (whichever
cell is being in-place-edited), correct? i just assumed it wasn't
appropriate for a table/tree that may have half or more of it's cells be
arbitrary widgets. if that's an incorrect assumption, i would definitely
> -Chris
>> a GEF viewer in a row? that's the primary use case i'm interested in.
>> thx,
>> al
| Re: CompositeTable has landed. :-) [message #567249 is a reply to message #15152] |
Sat, 21 October 2006 14:30  |
plus, i do like JFace style model/view separation, so would want viewers
>> -Chris
>>> interested in.
>>> individually.
>>> thx,
>>> al
| Re: CompositeTable has landed. :-) [message #567277 is a reply to message #15182] |
Sat, 21 October 2006 14:45  |
snippet:
-Chris
>> wasn't appropriate for a table/tree that may have half or more of it's
>> cells be arbitrary widgets. if that's an incorrect assumption, i would
>>> -Chris
>>>> interested in.
>>>> individually.
>>>> thx,
>>>> al
| Re: CompositeTable has landed. :-) [message #567305 is a reply to message #15214] |
difficult).
al
> snippet:
> -Chris
>>>> -Chris
>>>>> interested in.
>>>>> individually.
>>>>> thx,
>>>>> al
| Re: CompositeTable has landed. :-) [message #567320 is a reply to message #14825] |
Dave Orme
Dave Orme
| Re: CompositeTable has landed. :-) [message #567343 is a reply to message #14910] |
Sat, 21 October 2006 16:43  |
A row can currently contain *anything* you want as long as consecutive
rows in the same table are all the same height.
Dave Orme
| Re: CompositeTable has landed. :-) [message #567363 is a reply to message #14930] |
Sat, 21 October 2006 17:03  |
True, but you can't lay them out however you want. :-) For example,
the following kind of repeating row layout is hard to do with the
standard table, but is dirt simple with CompositeTable:
CheckNo Clr Description Debit Credit Balance
Memo Category
Memo Category
Memo Category
Best Regards,
Dave Orme
| Re: CompositeTable has landed. :-) [message #567382 is a reply to message #14855] |
Sat, 21 October 2006 17:17  |
CompositeTable uses a concept similar to JFace content providers by
default (since it's virtual). Again, because CompositeTable is virtual,
it is actually impossible to use CompositeTable in any way other than
via some sort of MVC pattern--either using CompositeTable's native API
or via data binding.
CompositeTable's native API is intentionally designed to be conceptually
similar to JFace, but because of the requirement to be able to put any
kind of control anywhere in a row using any layout manager, the API
necessarily isn't exactly the same as JFace.
In addition, CompositeTable supports the new JFace data binding API
right now. (We actually have deployed CompositeTable in a 2 million
plus line enterprise application using data binding as the MVC layer.)
So CompositeTable supports a nice MVC separation of concerns either way.
Dave Orme
| Re: CompositeTable has landed. :-) [message #567443 is a reply to message #15378] |
Sat, 21 October 2006 23:58  |
hmm. data binding isn't particularly important in this case.
architecture/API similarity/correspondence with other JFace viewers is
desirable. but i'll take a look at the actual CompositeTable code before
i comment further.
> Best regards,
> Dave Orme
| Re: CompositeTable has landed. :-) [message #567469 is a reply to message #14910] |
| Re: CompositeTable has landed. :-) [message #567495 is a reply to message #15280] |
Sun, 22 October 2006 16:48  |
| Re: CompositeTable has landed. :-) [message #567523 is a reply to message #15247] |
Mon, 23 October 2006 04:03  |
Comments in line:
https://bugs.eclipse.org/bugs/show_bug.cgi?id=36977 The only problem I
could think of are resources needed when using arbitary widgets like
Steve says in https://bugs.eclipse.org/bugs/show_bug.cgi?id=36977#c6
> difficult).
The limitation of SWT Tree/Table is that *all* rows in your table need
to have the same row height!
By the way we have been actively working on JFace-Viewer support for
nebula already and provide draft solutions how this could work.
https://bugs.eclipse.org/bugs/show_bug.cgi?id=154329
together with:
https://bugs.eclipse.org/bugs/show_bug.cgi?id=153993
https://bugs.eclipse.org/bugs/show_bug.cgi?id=151295
Will make JFace a really powerfully editing platform.
>> create and use a regular SWT TableEditor. JFace viewers also have a
>> paradigm for using its own cell editors which are typically triggered
>> by clicking on the cell. I'm not sure if JFace has a way to keep an
>> editor active.
Yes that's true. You can use Table/TreeEditor together with CellEditors
currently although you need some custom code to deactivate the
Table/TreeEditor. Although I have tried it myself it seems to work.
http://dev.eclipse.org/newslists/news.eclipse.platform/msg58 930.html
I'll revisit this topic once I'll start working on
https://bugs.eclipse.org/bugs/show_bug.cgi?id=36977 but there are more
important JFace topics on my personal priority list and because
CompositeTable provides what is requested here the priority is lowered
once more ;-)
By the way CompositeTable is really cool stuff David how good is it
tested in real world applications. Do you think it could already be used
in commercial projects?
Tom
| Re: CompositeTable has landed. :-) [message #567548 is a reply to message #15510] |
Thanks. :-)
We're using CompositeTable successfully in a two million plus line
enterprise RCP application, plus I have used it on small in-house projects.
One thing CompositeTable does to eliminate the SWT resource issue is: it
only creates SWT controls to represent *visible* rows. So there is a
hard upper bound on how many SWT controls CompositeTable will ever
create at a given time.
Dave Orme
| Re: CompositeTable has landed. :-) [message #567570 is a reply to message #15477] |
Dave
Current Time: Sat Nov 08 23:12:08 EST 2025
Powered by FUDForum. Page generated in 0.13679 seconds
