Home » Eclipse Projects » Babel » Background jobs with the Babel server
Background jobs with the Babel server [message #14777] Wed, 09 July 2008 13:33 Go to next message
Originally posted by: atoulme.intalio.com
is there any documentation regarding the background jobs to make Babel
run properly ? As I understand it, the important jobs to run are
map_process_files.php, generate1.php and dbmaintenance_15min.php.
Should there be a cron job to run those files ?
Antoine
Re: Background jobs with the Babel server [message #14867 is a reply to message #14777] Thu, 10 July 2008 08:56 Go to previous messageGo to next message
Follow up there:
https://bugs.eclipse.org/bugs/show_bug.cgi?id=240320
Re: Background jobs with the Babel server [message #14918 is a reply to message #14777] Thu, 10 July 2008 10:36 Go to previous message
Eclipse Webmaster is currently offline Eclipse WebmasterFriend
Thanks for opening up the bugs. Indeed, we need to add documentation
and patch some things up. If you can supply patches to your bugs, that
would definitely expedite things!
Denis
Antoine Toulme wrote:
> Antoine
Eclipse WebMaster - webmaster@eclipse.org
Questions? Consult the WebMaster FAQ at
http://wiki.eclipse.org/index.php/Webmaster_FAQ
View my status at http://wiki.eclipse.org/index.php/WebMaster
Re: Background jobs with the Babel server [message #572008 is a reply to message #14777] Thu, 10 July 2008 08:56 Go to previous message
Follow up there:
Re: Background jobs with the Babel server [message #572068 is a reply to message #14777] Thu, 10 July 2008 10:36 Go to previous message
Denis
> Antoine
Previous Topic:toescapedunicode() function
Next Topic:Import properties file into babel server
Current Time: Sat Nov 22 11:31:45 EST 2025
Powered by FUDForum. Page generated in 0.04453 seconds
