Home » Language IDEs » C / C++ IDE (CDT) » How to exclude dirs with managed projects
How to exclude dirs with managed projects [message #157526] Wed, 09 November 2005 05:42 Go to next message
Using a managed C project, with the project folder set to an existing set
of files, is it possible to exclude certain directories from the build?
How?
Re: How to exclude dirs with managed projects [message #157610 is a reply to message #157526] Wed, 09 November 2005 18:58 Go to previous message
Originally posted by: eclipse.dharty.com
Try setting the exclusion filter for the source folder
Project Properties->C/C++ Project Paths->Source Tab, and edit the
exclusion filter of your source folder(s) to add the subfolders.
It works in standard make, and IIRC it should also work in managed builds.
D
> set of files, is it possible to exclude certain directories from the
> build? How?
Previous Topic:Multiple projects using the same code
Next Topic:C99
Current Time: Mon Nov 10 00:13:15 EST 2025
Powered by FUDForum. Page generated in 0.02662 seconds
