Home » Archived » BIRT » BIRT perspective does not appear in Eclipse 3.1.2 after reinstalling BIRT 2.0.1
BIRT perspective does not appear in Eclipse 3.1.2 after reinstalling BIRT 2.0.1 [message #157525] Mon, 01 May 2006 12:51 Go to next message
after having tried to install BIRT 2.1RC1a under Eclipse 3.1.2 (what
didn't work as well), i deleted all directories containing "*BIRT* from
the plugin and feature directory of eclipse.
After that, i installed BIRT 2.0.1 in the eclipse environment. The
settings for BIRT are available under preferences in eclipse, the views
are availabel as well. The configuration of eclipse does not report any
problems with BIRT.
But the BIRT perspective is not available to select. Even if i started
eclipse with c:\program files\eclipse.exe -clean
How can i really wipe out my old BIRT fragments to get a clean
re-installation.
Any suggestions ?
Holger
Re: BIRT perspective does not appear in Eclipse 3.1.2 after reinstalling BIRT 2.0.1 [message #157565 is a reply to message #157525] Mon, 01 May 2006 15:03 Go to previous messageGo to next message
RC1 requires Eclipse 3.2.
Try downloading the AllInOne and see if it works on your system.
Jason
"Holger Buchner" <Holger.Buchner@Web.de> wrote in message
news:e35e9j$7nu$1@utils.eclipse.org...
> Hello,
> problems with BIRT.
> re-installation.
> Any suggestions ?
> Holger
Re: BIRT perspective does not appear in Eclipse 3.1.2 after reinstalling BIRT 2.0.1 [message #157573 is a reply to message #157565] Mon, 01 May 2006 15:10 Go to previous messageGo to next message
Hi Jason,
BIRT 2.1RC1a wor.
I would just like to learn, how to get my old configuration back working
on Eclipse 3.1.2 wihtout having to install everything from the scratch.
Somewere in the eclipse environment, some fragments of my failed BIRT
2.1 installation are still avoiding BIRT 2.0.1 from starting up properly.
Is it possible to turn a log-level on during startup from Eclipse ?
Yours,
Holger
> Jason
>>Hello,
>>problems with BIRT.
>>re-installation.
>>Any suggestions ?
>>Holger
Re: BIRT perspective does not appear in Eclipse 3.1.2 after reinstalling BIRT 2.0.1 [message #157581 is a reply to message #157573] Mon, 01 May 2006 16:24 Go to previous message
Have you tried running eclipse with the -consolelog command?
You can also extract the Birt plugins to another directory and verify that
all the plugins from the original where removed.
Jason
news:e35mg0$c0d$1@utils.eclipse.org...
> Hi Jason,
> BIRT 2.1RC1a wor.
> Somewere in the eclipse environment, some fragments of my failed BIRT 2.1
> Yours,
> Holger
>> Jason
>>>Hello,
>>>problems with BIRT.
>>>re-installation.
>>>Any suggestions ?
>>>Holger
Previous Topic:Frameset
Next Topic:Exception Handling
Current Time: Thu Nov 20 19:33:45 EST 2025
Powered by FUDForum. Page generated in 0.03820 seconds
