Home » Language IDEs » ServerTools (WTP) » Websphere 5.1 connector for Eclipse WTP 1.0
Websphere 5.1 connector for Eclipse WTP 1.0 [message #157402] Thu, 19 January 2006 19:57 Go to next message
Originally posted by: satish.vasa.equifax.com
Can we use WTP 1.0 to connect to Websphere 5.1 ? Does anyone know of a connector available or steps to configure Websphere 5.1?
Satish Vasa
Re: Websphere 5.1 connector for Eclipse WTP 1.0 [message #159881 is a reply to message #157402] Thu, 09 February 2006 11:36 Go to previous messageGo to next message
Originally posted by: stephane.arguin.gmail.com
Please, if you got the answer I'm really interested... I have the same problem.
Re: Websphere 5.1 connector for Eclipse WTP 1.0 [message #159889 is a reply to message #159881] Thu, 09 February 2006 11:43 Go to previous message
Websphere 5.1 is not supported by WTP. But, configuring and setting up a 5.1 server should not be a problem because the Generic server configuration is XML based and you can re-use the Websphere 6.0 configuration as there ANT scripts used to start / stop / deploy apps haven't changed much between 5.1 and 6.0
We are still working on getting a working configuration.
Previous Topic:Run tomcat with deployed services (eg. axis)
Next Topic:jsp editor error: HttpServlet Request cannot be reolved to a type
Current Time: Mon Jul 14 08:27:05 EDT 2025
Powered by FUDForum. Page generated in 0.50277 seconds
