One Row Per Page [message #157387] |
Mon, 01 May 2006 10:19  |
Originally posted by: milton.corigo.com
I'm interested in creating a report that has queried data where each row
of the result set would be displayed on a separate page. The output format
would PDF so that each page could be printed separately.
Does anyone know how to configure BIRT to do this? Thank you.
Milton Hagler
Re: One Row Per Page [message #158559 is a reply to message #158308] |
Fri, 05 May 2006 01:56   |
--------------090504070800020802040003
Content-Type: text/plain; charset=us-ascii; format=flowed
Jason,
Here is a screen shot of Eclipse after running Preview and a PDF of the
same report showing the incorrect data. I assume this is what you
wanted. I've also reattached the report's rptdesign file for convenience.
Please let me know if there's anything else you need.
Milton
Jason Weathersby wrote:
> Milton,
> Can you upload a screenshot of the error you are getting?
> Jason
> "Milton Hagler" <milton@corigo.com> wrote in message
> news:e3cbo8$vlt$1@utils.eclipse.org...
>>Interesting. I confirmed that the iText-1.3.jar file is in the correct
>>location and even tried running the report again and had the same problem
>>of the phone number not stepping over the record set.
>>My environment is the following:
>>- eclipse 3.2.0 Birt 2.1 All-in-One
>>- JDK 1.5.0_05
>>- Windows 2000 Server SP4
>>I even tried downloading the latest iText-1.4.jar and had the same result.
>>Also tried installing JDK 1.4.2 running with both iText-1.3 and iText-1.4
>>and that also didn't help.
>>At this point I'm at a loss, but will go ahead and solve my report
>>directly with iText and will use Birt for other more standard reports that
>>I'll be needing. BTW, the Birt tool is quite nice, easy enough to learn
>>and very capable.
>>Thanks again for your help.
>>Milton
>>>The report works fine for me. It appears that you dont have iText in the
>>>right place.
>>>The pagination example was setup for PDF not html. Copy the iText jar to
>>>the lowagie plugin lib directory and this should fix the problem.
>>>Jason
>>>news:e39akg$dok$1@utils.eclipse.org...
>>>>Thanks for the help again. The report you sent works and steps over the
>>>>data correctly. However, when I change the OFFICECODE to display phone
>>>>numbers the numbers don't step with the result set and displays the
>>>>first number repeatedly. The city name steps normally though. I've
>>>>attached the report file for you to look at.
>>>>I found the same problem when I tried to duplicate your report using my
>>>>data where only the first row of the result set is displayed repeatedly.
>>>>Also when setting up the report I'm receiving the error message quite
>>>>frequently "Error happened while running the report" for no apparent
>>>>reason.
>>>>Thanks again.
>>>>Milton
>>>>>Here is an example.
>>>>>I added a grid to the detail row of a table to format the cells.
>>>>>I added a style to the detail row to page break after.
>>>>>Jason
>>>>>news:82ecc722c082e0614722b9851ece7c6c$1@www.eclipse.org...
>>>>>>Great, that worked for a simple table. Now what I need to do is enhance
>>>>>>the report so it has these characteristics:
>>>>>>1. Each row of data has a separate page
>>>>>>2. Each page has a header also fed from the data with a static image
>>>>>>3. Each page has 2 columns beneath the header with data
>>>>>>| static image field8 |
>>>>>>| label field0 | label field1 | one page per row
>>>>>>| label field2 | label field3 |
>>>>>>| label field4 | label field5 |
>>>>>>| label field6 | label field7 |
>>>>>>I've tried many different combinations but have been unable to make the
>>>>>>report generate a page for each row. Any hints on how to construct the
>>>>>>reports framework?
>>>>>>BTW, how to chase down the error message: "Error happened while running
>>>>>>the report"
>>>>>>Thanks,
>>>>>>Milton
Content-Type: application/pdf;
name="Eclipse Duplicate Phone.pdf"
Content-Disposition: inline;
filename="Eclipse Duplicate Phone.pdf"
JVBERi0xLjQKJeLjz9MKMiAwIG9iaiA8PC9GaWx0ZXIvRENURGVjb2RlL1R5 cGUvWE9iamVj
dC9MZW5ndGggNTUyNTUvQml0c1BlckNvbXBvbmVudCA4L0hlaWdodCAxNTkv Q29sb3JTcGFj
ZS9EZXZpY2VSR0IvU3VidHlwZS9JbWFnZS9XaWR0aCAyMzU+PnN0cmVhbQr/ 2P/gABBKRklG
AAECAQEsASwAAP/hFVpFeGlmAABNTQAqAAAACAAHARIAAwAAAAEAAQAAARoA BQAAAAEAAABi
ARsABQAAAAEAAABqASgAAwAAAAEAAgAAATEAAgAAABQAAAByATIAAgAAABQA AACGh2kABAAA
AAEAAACcAAAAyAAAASwAAAABAAABLAAAAAFBZG9iZSBQaG90b3Nob3AgNy4w ADIwMDU6MDQ6
MDUgMTI6NTU6NDQAAAAAA6ABAAMAAAAB//8AAKACAAQAAAABAAAA66ADAAQA AAABAAAAnwAA
AAAAAAAGAQMAAwAAAAEABgAAARoABQAAAAEAAAEWARsABQAAAAEAAAEeASgA AwAAAAEAAgAA
AgEABAAAAAEAAAEmAgIABAAAAAEAABQsAAAAAAAAAEgAAAABAAAASAAAAAH/ 2P/gABBKRklG
AAECAQBIAEgAAP/tAAxBZG9iZV9DTQAC/+4ADkFkb2JlAGSAAAAAAf/bAIQA DAgICAkIDAkJ
DBELCgsRFQ8MDA8VGBMTFRMTGBEMDAwMDAwRDAwMDAwMDAwMDAwMDAwMDAwM DAwMDAwMDAwM
DAENCwsNDg0QDg4QFA4ODhQUDg4ODhQRDAwMDAwREQwMDAwMDBEMDAwMDAwM DAwMDAwMDAwM
DAwMDAwMDAwMDAwM/8AAEQgAVwCAAwEiAAIRAQMRAf/dAAQACP/EAT8AAAEF AQEBAQEBAAAA
AAAAAAMAAQIEBQYHCAkKCwEAAQUBAQEBAQEAAAAAAAAAAQACAwQFBgcICQoL EAABBAEDAgQC
BQcGCAUDDDMBAAIRAwQhEjEFQVFhEyJxgTIGFJGhsUIjJBVSwWIzNHKC0UMH JZJT8OHxY3M1
FqKygyZEk1RkRcKjdDYX0lXiZfKzhMPTdePzRieUpIW0lcTU5PSltcXV5fVW ZnaGlqa2xtbm
9jdHV2d3h5ent8fX5/cRAAICAQIEBAMEBQYHBwYFNQEAAhEDITESBEFRYXEi EwUygZEUobFC
I8FS0fAzJGLhcoKSQ1MVY3M08SUGFqKygwcmNcLSRJNUoxdkRVU2dGXi8rOE w9N14/NGlKSF
tJXE1OT0pbXF1eX1VmZ2hpamtsbW5vYnN0dXZ3eHl6e3x//aAAwDAQACEQMR AD8A9VSSSSUp
JJUerdZwOkUC7MeQXmKaWDdZY7/R01D3PcgSACSaA6ldGMpyEYgykdgG8s7q X1h6N0t2zNym
V26RS2X26/R/QVb7fd/UXN5fUutdVJ9a13S8M8YuO79YcP8Auxlf4D/iqP8A i7EPExsPCEYl
LKSeXgS8/wBe52613+esjmfjeLGTHDH3SP0vlx/a3cfIga5ZWf3Mf7cv/eRm 6r/rffYJwOkZ
Vw7PyCzGaf5TTa57/wDwNBf9YPrM/WrBw6R4WZDnn/wKtir+qTqSl6qzZ/Gu dlsYRHhH9rOM
GEbYo/4RnI/9Ph/5rYZ9YPrOzW3Bw7h4V5DmH/wVjkVn1wvqE9Q6RlUt/foL Mlg83OqLHf8A
QVL1UhaRqDBSh8a52O/BIeMf2qODCd8Uf8Ezif8Ap8P/ADXoem/WHovVDsws tlluv6EyyzT6
X6G3Zb7f6q0VwuXi4WaP1ullp7PIh4/q3M22/wDSRMTqfW+kkejY7quEOca9 36y0f918n/D/
APF3f1K1pct8bxZCI5o+1I/pfNj+1gyciDrilR/cyf8Ac5fl/wAeON7ZJUek 9Z6f1fHN2FZJ
YYtqcNtlbv8AR3Vn6DleWuCCLBsFpSjKEjGQMZDcHdSSSSK1/9D0nq/U6Ok9 NyOo3gurx27t
reXEnZXW3/jLHNYsPofWfrf1OvH6k7Bw2dMynt20iywZIpc7b9p3vb6Fmxn6 b09tb7q/9Gtn
r3SWdZ6Rk9Ne81faGw2wCdr2kWVP2/nNbYxm5iwcXqf1g+r3S8bG6l0+n7Jg MbVbnMyAQ9jB
6dIxsb0he7It/RsZW9uz/hFJExGORPDxA2eI16KQIylOMQCeKhER/fRdO+vl +R0q267HrPUv
tNmLi41TjD9gY/7RZv8AdVTX6n6VywcHqZy+u5Tcp4yM4e1uXOkMj1sbHr+j TTXv9mz+c/wi
pdLxs/BF7/srDkZBc71Da32SJrr26/4T6ajX0vKxRhX0vNuTQd19bnMaz3+7 IFJ2s+k9z/pv
fvWXzmTl85z45ZcYhOPDyvBkjKPucPue7mMJfq4+5CGH9Z/nG/hjlxwxcGOV g3zJlH1zjfD7
eP8AehGPr9Lo4HVsvMvtc2moYlT3MLRYftAa0fz7qo2bN36P0/ppundWzs2l +SaaBjxYWhlh
NlewE1faWEf4eP8ABqpZiZNvUaMplLMWyp5dfkseCLWj6Nfot9+636NrntTM w8l3UBlNoZhj
03tyA2wFtz3tc1obXXu2V+o71P0n/nxV54eQMchAwwvFCUfXHJ7U4e5+q9OX 9dLP6P1sP1mP
9X96wfzqI/ebj88vXIH0yjxg8Pr+X9X7f7n83P8AyKX/AJyWnp2Pe3GD8zKs dVVQ10NJa4Vb
tzv33ub7f/BFpY13UdzmZtdIgS2zHe5zZmDUWXNbZ/K9T+bWHj9Lyq8TDcQ0 ZWFc+0Vlw2ua
5ws2+o3c1r/atSnIybHP9bH+zsAGybGvc4/ne2qWtb/aUHPYuVEJ/dY4TEZM vHLj/Xfz/wCo
9iMsnrxfd+D+ahk/ynuMvLDMZD3vcB4YcI4f1f8AN/rPcPD8/u/vsx1Vv7XP THNAJY11dk67
yN5re3+p9BAr+sNLn525n6HDAdW9p1sBd6Pf6P6X879xUszp2VfbmZNRazKd bW/Efuj2sYaz
ud/g/pbv7Cg3ohZddj1kNw7MZtTbJG71GGt/qPr+l77WPe//AIxTQ5b4VwAz mOL28IyAHaeO
WGfNzh/XzYsnt44f6vmFkjzvERGPp4snAa6TGT2RL/Zzj6v7+NvM6x1FuGzq WTjVNwnwfTre
43tredtdx3D0Xbvp+mpO6tmW9T+w4LKLGOqbey21z2gscGO/wbX/AOk9qqZF PU7+n1dNbUyp
rWsZZkmwOZtr+i5lTf0zvo/Q2J68TJw+ojIxavXpqxm49QNjWH2tY3dZv/4t H2eT9ZI5cZzH
N7MBkj934OLF929yfucHvfzv6fue3/OoPv8ApoZfb4ocZ4Ze7xcM/d4R8/B/ N/1GV/XH1M/a
2Ew43VcS0Y97QZ3A7/0dkDbk1PdV7d//AJBbzfr/ANSbRh+vjYwy7c4YmRjs scSKn7PSyK3a
/nv2f4atctZ0fLd0+9rnMfmZdzbbQ10Na1oeNjHv273/AKVz3I1+FYRj3YuD VjWY2Q2001uZ
7217LW/Q2M3b6/T/ANIr3LZ+Sw8OPHOHtHLOMuKf83Dgjw8Puz9z2fd9yGOf rYsmPmckT7sZ
mcccPbqP9f1xPB6f5v8AQ/8AC3t/rF9Zeo4XWsPovTm4ld2TWbnZOe9zKo3G tlFfpe51z3tX
Q4z77MaqzIqFF72NdbSHbwx5Evr9UBvqbHe3euN6k7qX1r6NVcOi42XVfW8U /rIFuNfudX6r
rSxn6J1fpepRX799fpXeouo6Dg5fT+jYeFm3/acqiprLbtSC4fuud7nMZ9Bj 3q9Lh9uJBjf9
U8XF/WalSE5CQIrSpDh4T+6//9H1VcL9bOpfbertw2GcbpkOeOzsl40/9hqX f9u2rs8/LZhY
WRmWfQx632uHiGAvheW1WWOZ6lx3XXE3XO8X2H1LP+qVD4llMcQxjfJv/ddH 4ZhuUsp/Q9Mf
70/mP+L/ANNteol6irPuZWx1ljgxjBuc4mAAO5T4wz8wuGLjhjWjcbMlxZ/7 K41eVlN/9CGY
qyMXK5cp/VwMq3O0R/hS9LoZcuLEAckhG9hvL/Fi2PUS9RBfQ6kE5PWemVxy yqu+9zf5L/Tu
a1rlmZHWunUSG9XrucNIqxAZ/wA/Na5WR8J5g9Ij/Ca5+I8t3kf8F2fUS9Rc 3b9YrG0C+q1l
jNxYQ6r03SA0izZ6r2tpdv8AT99v86lZ9Zr8fDZfZXVZdfudSwhwYGMs+zep Z6Vm6/1bPU9P
bbjsq9H/ALU70j8Kzir4RZr5lf6Q5ejXEf8ABek9UbtkjeQXBk+7aDtc/b9L Y1x+kl6i4nL6
vdkYlPUjTWzIxcljA2s2hr2Q/L97H22fTe3ZtqdXWytn6OtSZ9cuo5G5npU0 TqbKw4va0a2P
rZdY6p9mz6G5GXwvJpwSEh+kZejh/wCkth8RxkHjiYn9ER9d/wDRe2l5EwYP BTFz2/SBHxC4
bG6qx4Lzi4+YXuInLrutsJBhgfZ69vvc1GPU8Wt20UHp1pEH7Ne+rU/nelkb NjP6z7VN/obT
+eF9uD0/43F/3DH/AKUjf80a/va/ZwvZeol6i5bF+s2QLA1+zLqgAtr0u7De zfbf6tjvp/Z/
+2fSXRb/ADVHmOTyYJATo38somwW5y+fHniTC9PmjIaxt2/ql1L7D1h2C8xi 9TlzB2bktHu/
9iam/wDblbF3a8lussaz1aTF9Dm3Uu8H1n1GfkXqeDl15uFRmV/QyK22tHgH gPhavw3KZYjA
749v7rS+J4alDKP0/TL+9D5T/hQ/6D//0rvVvrj1DqmBd0+3GqqrugOexzi6 GuD9sOb+ft2L
F+0P/cH3lOWalOK5IHE90/Jy3L5CDPGJEaby/wC+Rj5vmcceGGQxjfFVR3+s WVePlZ7X49VZ
Ie0hxay60gH2/wA1gVXX/wBR1v2Wj/u0pZP1forc+rrHU3tcz3sZk5GLgs3E 6+jTV+3MllzW
t/NpquWVX1HNz6jjiq/Kr1H2DD3egIJ1tZib25Vrvb612b61n/ntFxsTrOMb X4fQbmeoQ6DV
tAMNY5rS37K7b7UyGGGO/bAhGRvhjcv+kvyZsmWjklxyiKsiMf8Aoug3A+qT TXb6DchzDxXV
mZjyOz/tPVX9P6Qyz879YwrqP+ARzf0WtsUYGXyCHPxuk1AfvCcfCuVIf862 tLx0Pe0eL/TM
/wDFuussRKs3rTNL+gX6cuZaOfBrbP8Ayafwx7ljs+CV+XgNeyxmHkVue5jQ RjdLsJJd/g7r
Mejb+iZbs/RWfpf+L/SZv1iy7H4BY1r2M6jfVY264VN2spbbjCjZiMx6GX22 U/prMX08f0/0
f86r5fbY5hs6b1KnbYLi30Tc3c1pY3b9nL/SY3dvf6dX6Wz9J+kVfOtxXsbD Mh95c+vGx2VF
rrRYW5LnObazbXR78mn7Q/31b7LKaLLKlHkjoCO//cyXROurzdOI+3pHUmVs cW4jcfLftEgW
b31bHe7/AAmJk3ZHs9T2Y39dYz4xLHsrO+ws2l3O0uH6Vo2+1zm/ze5dR1C/ JyMZuPidOtDM
N74DarQavWrZV6Lzjj6WPYx/63l/5Qzv0Xq+nj/qqx8vM+sLq6sG716cSp0M x3NfXSDM7tha
z2+7/Cf4NNiD280mm59Weq5WP0rqGC2x7Kryx7YvtrYADtzK3Y+O9jbGZWNs quyLf6PWz9F+
lXS1/W5uM52PTXfU0UhzcajMurDL977LqvtN1V/ru+xupb6drPVptxvsta5v pAJysvKcLLa9
poxmsDdzz6jbfd9o/wAGzb9K1lnv2M/kK6/C6xi1my2plLXEkHKt32vLj6hs sa4Ns/8AZVSC
FgE6LSat07PrB0zIc8dTw8lwbuc31GYGYPd7tXZGJ0/M2Odv2elm1XJvt+Ef TOJktyq7SQGu
bZVdU6N3o305VmVc+t3+ByvteTv/AJr1P0a5y/1JPqvrJH7jnNOvb2s/6pRx 8jHpyK73usY5
o9wDQ5pbIcXeoCyz2f8AEvQy8vjnXHDiAOx/9A9S/Fny4yTjnwkitP8AvZPU faHfufj/ALFv
dG+ueR0rptPTxhtyG0bg2w2lh2uc57W7PRs+hu2fSWEA1wDmkOa7VpGoIPgk GahOx8ry+Mkw
xiJOnzT/AO6kty85zOWPDkycUb4q4YD1f4MX/9MJbqVC2o2U2VA7TYxzA46g FzSzdp+7KMRq
UoUlsThtvyWixufWwsx63k1Vs2uaaw1zrOXVux9uxtdtP87ZdT/MoAzc3IxD lVdGvsxTIblh
thbpIcK8jHr9P2x/plt5uBRm1Gq0uZuaWF7NHbXfSZ/V3e7aqmccTJy8b9r7 8PIpx2YYzaqX
ZOM+mn3UW1YdFuNk9OyPb+k+zO9L/Q+kmSnkG3q+i8CJ30eZGYzJftr9UF0+ wbLOS0N272/Q
b73ve99n+j/4RXLMem1lQoxcmkNn1bxkMsY8gRurqqx8f0Pf/bRet14Wdm0n EffaaqmMyOoX
Vim2+9rnudktol1m99Rqp9W39Nds9bI9S79Ldd6f0htL73dXoty8a2pzXNpL A5jz6bm5FFBc
2v1f0X6b3sekZTOuoTQGjkNwWF4DbLi6dsB2s87TDPa5FOPl7htvynNsDmO2 2OeCD9JujXt9
J239ItDJo6HZXtGd1i8tILWWPqDTB7l7n+k7Z9H2XIf2ToTWh1FXULeZqfkj TWG++vGrZud9
JNuXeX4p08Gq9mbZZ61mZmPtgD1Dc5zo/Nbvc3c1qg+3MpZAz8wF2jWjIIBP 3f8AUK/bh9Jd
Tspxs11hhx32ugOHjp7v3foIGd0rFfitsxsfJoy2kH1HvcWME6xLb32/vM/o mz/hEhxd5fkr
TwQW9Yfi7qGW2OyA0NOS15fa588eq4/o/wCoz3/mKo4ZuN+s5WNl1T7arrKw 1nqE/nerX6Tv
0fq/o/p+or3TGYeC/Jpz3P6fk2V1DCyg123Qxk0+q3bbX9qY7+dZ9ns/wFmR jVXW+pYx7ul9
Pxsl776czNzKHYjMXF9Q1NY4forMnex1T7anfTrqffZ/N+h+tfp2I5pDThUI jdxsWrIvbY9r
wK2+07q2WOAOv0rAPRd/wv6NFbgVHRhc97j/ADjjub8WsDdtrv3Fe6P0l10h /tADTZOoG0bW
+z6Pru/8DXR0YmPjj9EwB3d51cf7SdUjqT9FpIGzX6bivxsNlTpEfRaeWj81 qtBuoU4SA1Cf
ax//1JFlMn9Kf8z/AMyS2U/6U/5n/mS8oSTln2Pq+yn/AEp/zP8AzJRezH2n fb7e+5mn/Scv
KkklfY+oVN6Zv/Q2V7/5DGz/ANFyPsq/0p/zP/Ml5Qkkr7H1fbT/AKX/AKH/ AJknDK+1p/zP
/Ml5Okkr7H1jYz/Su/zD/wCSTbK/9Kf8z/zJeUJJK+x9QzKenPr25loDDwXj b9zi9Uq+n/V/
dLMoGBqAWjTz2ODl54kkr+XV9TorwhUBj2j0hxsbIn4h6Jsp/wBKf8z/AMyX lCSSvsfV9lP+
lP8Amf8AmSQZTI/Sn/M/8yXlCSSvsf/Z/+0aBFBob3Rvc2hvcCAzLjAAOEJJ TQQlAAAAAAAQ
AAAAAAAAAAAAAAAAAAAAADhCSU0D7QAAAAAAEAEsAAAAAQABASwAAAABAAE4 QklNBCYAAAAA
AA4AAAAAAAAAAAAAP4AAADhCSU0EDQAAAAAABAAAAB44QklNBBkAAAAAAAQA AAAeOEJJTQPz
AAAAAAAJAAAAAAAAAAABADhCSU0ECgAAAAAAAQAAOEJJTScQAAAAAAAKAAEA AAAAAAAAAThC
SU0D9QAAAAAASAAvZmYAAQBsZmYABgAAAAAAAQAvZmYAAQChmZoABgAAAAAA AQAyAAAAAQBa
AAAABgAAAAAAAQA1AAAAAQAtAAAABgAAAAAAAThCSU0D+AAAAAAAcAAA//// ////////////
/////////////wPoAAAAAP////////////////////////////8D6AAAAAD/ ////////////
////////////////A+gAAAAA/////////////////////////////wPoAAA4 QklNBAgAAAAA
ABAAAAABAAACQAAAAkAAAAAAOEJJTQQeAAAAAAAEAAAAADhCSU0EGgAAAAAD VwAAAAYAAAAA
AAAAAAAAAJ8AAADrAAAAEQBDAGwAYQBzAHMAaQBjAE0AbwBkAGUAbABzADEA MAAwACUAAAAB
AAAAAAAAAAAAAAAAAAAAAAAAAAEAAAAAAAAAAAAAAOsAAACfAAAAAAAAAAAA AAAAAAAAAAEA
AAAAAAAAAAAAAAAAAAAAAAAAEAAAAAEAAAAAAABudWxsAAAAAgAAAAZib3Vu ZHNPYmpjAAAA
AQAAAAAAAFJjdDEAAAAEAAAAAFRvcCBsb25nAAAAAAAAAABMZWZ0bG9uZwAA AAAAAAAAQnRv
bWxvbmcAAACfAAAAAFJnaHRsb25nAAAA6wAAAAZzbGljZXNWbExzAAAAAU9i amMAAAABAAAA
AAAFc2xpY2UAAAASAAAAB3NsaWNlSURsb25nAAAAAAAAAAdncm91cElEbG9u ZwAAAAAAAAAG
b3JpZ2luZW51bQAAAAxFU2xpY2VPcmlnaW4AAAANYXV0b0dlbmVyYXRlZAAA AABUeXBlZW51
bQAAAApFU2xpY2VUeXBlAAAAAEltZyAAAAAGYm91bmRzT2JqYwAAAAEAAAAA AABSY3QxAAAA
BAAAAABUb3AgbG9uZwAAAAAAAAAATGVmdGxvbmcAAAAAAAAAAEJ0b21sb25n AAAAnwAAAABS
Z2h0bG9uZwAAAOsAAAADdXJsVEVYVAAAAAEAAAAAAABudWxsVEVYVAAAAAEA AAAAAABNc2dl
VEVYVAAAAAEAAAAAAAZhbHRUYWdURVhUAAAAAQAAAAAADmNlbGxUZXh0SXNI VE1MYm9vbAEA
AAAIY2VsbFRleHRURVhUAAAAAQAAAAAACWhvcnpBbGlnbmVudW0AAAAPRVNs aWNlSG9yekFs
aWduAAAAB2RlZmF1bHQAAAAJdmVydEFsaWduZW51bQAAAA9FU2xpY2VWZXJ0 QWxpZ24AAAAH
ZGVmYXVsdAAAAAtiZ0NvbG9yVHlwZWVudW0AAAARRVNsaWNlQkdDb2xvclR5 cGUAAAAATm9u
ZQAAAAl0b3BPdXRzZXRsb25nAAAAAAAAAApsZWZ0T3V0c2V0bG9uZwAAAAAA AAAMYm90dG9t
T3V0c2V0bG9uZwAAAAAAAAALcmlnaHRPdXRzZXRsb25nAAAAAAA4QklNBBEA AAAAAAEBADhC
SU0EFAAAAAAABAAAABU4QklNBAwAAAAAFEgAAAABAAAAgAAAAFcAAAGAAACC gAAAFCwAGAAB
/9j/4AAQSkZJRgABAgEASABIAAD/7QAMQWRvYmVfQ00AAv/uAA5BZG9iZQBk gAAAAAH/2wCE
AAwICAgJCAwJCQwRCwoLERUPDAwPFRgTExUTExgRDAwMDAwMEQwMDAwMDAwM DAwMDAwMDAwM
DAwMDAwMDAwMDAwBDQsLDQ4NEA4OEBQODg4UFA4ODg4UEQwMDAwMEREMDAwM DAwRDAwMDAwM
DAwMDAwMDAwMDAwMDAwMDAwMDAwMDP/AABEIAFcAgAMBIgACEQEDEQH/3QAE AAj/xAE/AAAB
BQEBAQEBAQAAAAAAAAADAAECBAUGBwgJCgsBAAEFAQEBAQEBAAAAAAAAAAEA AgMEBQYHCAkK
CxAAAQQBAwIEAgUHBggFAwwzAQACEQMEIRIxBUFRYRMicYEyBhSRobFCIyQV UsFiMzRygtFD
ByWSU/Dh8WNzNRaisoMmRJNUZEXCo3Q2F9JV4mXys4TD03Xj80YnlKSFtJXE 1OT0pbXF1eX1
VmZ2hpamtsbW5vY3R1dnd4eXp7fH1+f3EQACAgECBAQDBAUGBwcGBTUBAAIR AyExEgRBUWFx
IhMFMoGRFKGxQiPBUtHwMyRi4XKCkkNTFWNzNPElBhaisoMHJjXC0kSTVKMX ZEVVNnRl4vKz
hMPTdePzRpSkhbSVxNTk9KW1xdXl9VZmdoaWprbG1ub2JzdHV2d3h5ent8f/ 2gAMAwEAAhED
EQA/APVUkkklKSSVHq3WcDpFAuzHkF5imlg3WWO/0dNQ9z3IEgAkmgOpXRjK chGIMpHYBvLO
6l9YejdLdszcpldukUtl9uv0f0FW+33f1FzeX1LrXVSfWtd0vDPGLju/WHD/ ALsZX+A/4qj/
AIuxDxMbDwhGJSyknl4EvP8AXudutd/nrI5n43ixkxwx90j9L5cf2t3HyIGu WVn9zH+3L/3k
Zuq/6332CcDpGVcOz8gsxmn+U02ue/8A8DQX/WD6zP1qwcOkeFmQ55/8CrYq /qk6kpeqs2fx
rnZbGER4R/azjBhG2KP+EZyP/T4f+a2GfWD6zs1twcO4eFeQ5h/8FY5FZ9cL 6hPUOkZVLf36
CzJYPNzqix3/AEFS9VIWkagwUofGudjvwSHjH9qjgwnfFH/BM4n/AKfD/wA1 6Hpv1h6L1Q7M
LLZZbr+hMss0+l+ht2W+3+qtFcLl4uFmj9bpZaezyIeP6tzNtv8A0kTE6n1v pJHo2O6rhDnG
vd+stH/dfJ/w/wDxd39StaXLfG8WQiOaPtSP6XzY/tYMnIg64pUf3Mn/AHOX 5f8AHjje2SVH
pPWen9XxzdhWSWGLanDbZW7/AEd1Z+g5XlrggiwbBaUoyhIxkDGQ3B3Ukkki tf/Q9J6v1Ojp
PTcjqN4Lq8du7a3lxJ2V1t/4yxzWLD6H1n639Trx+pOwcNnTMp7dtIssGSKX O2/ad72+hZsZ
+m9PbW+6v/RrZ690lnWekZPTXvNX2hsNsAna9pFlT9v5zW2MZuYsHF6n9YPq 90vGxupdPp+y
YDG1W5zMgEPYwenSMbG9IXuyLf0bGVvbs/4RSRMRjkTw8QNniNeikCMpTjEA nioREf30XTvr
5fkdKtuux6z1L7TZi4uNU4w/YGP+0Wb/AHVU1+p+lcsHB6mcvruU3KeMjOHt blzpDI9bGx6/
o0017/Zs/nP8IqXS8bPwRe/7Kw5GQXO9Q2t9kia69uv+E+mo19LysUYV9Lzb k0HdfW5zGs9/
uyBSdrPpPc/6b371l85k5fOc+OWXGITjw8rwZIyj7nD7nu5jCX6uPuQhh/Wf 5xv4Y5ccMXBj
lYN8yZR9c43w+3j/AHoRj6/S6OB1bLzL7XNpqGJU9zC0WH7QGtH8+6qNmzd+ j9P6abp3Vs7N
pfkmmgY8WFoZYTZXsBNX2lhH+Hj/AAaqWYmTb1GjKZSzFsqeXX5LHgi1o+jX 6Lffut+ja57U
zMPJd1AZTaGYY9N7cgNsBbc97XNaG117tlfqO9T9J/58VeeHkDHIQMMLxQlH 1xye1OHufqvT
l/XSz+j9bD9Zj/V/esH86iP3m4/PL1yB9Mo8YPD6/l/V+3+5/Nz/AMil/wCc lp6dj3txg/My
rHVVUNdDSWuFW7c7997m+3/wRaWNd1Hc5mbXSIEtsx3uc2Zg1FlzW2fyvU/m 1h4/S8qvEw3E
NGVhXPtFZcNrmucLNvqN3Na/2rUpyMmxz/Wx/s7ABsmxr3OP53tqlrW/2lBz 2LlRCf3WOExG
TLxy4/138/8AqPYjLJ68X3fg/moZP8p7jLywzGQ973AeGHCOH9X/ADf6z3Dw /P7v77MdVb+1
z0xzQCWNdXZOu8jea3t/qfQQK/rDS5+duZ+hwwHVvadbAXej3+j+l/O/cVLM 6dlX25mTUWsy
nW1vxH7o9rGGs7nf4P6W7+woN6IWXXY9ZDcOzGbU2yRu9Rhrf6j6/pe+1j3v /wCMU0OW+FcA
M5ji9vCMgB2njlhnzc4f182LJ7eOH+r5hZI87xERj6eLJwGukxk9kS/2c4+r +/jbzOsdRbhs
6lk41TcJ8H063uN7a3nbXcdw9F276fpqTurZlvU/sOCyixjqm3sttc9oLHBj v8G1/wDpPaqm
RT1O/p9XTW1Mqa1rGWZJsDmba/ouZU39M76P0NievEycPqIyMWr16asZuPUD Y1h9rWN3Wb/+
LR9nk/WSOXGcxzezAZI/d+Dixfdvcn7nB7387+n7nt/zqD7/AKaGX2+KHGeG Xu8XDP3eEfPw
fzf9Rlf1x9TP2thMON1XEtGPe0GdwO/9HZA25NT3Ve3f/wCQW836/wDUm0Yf r42MMu3OGJkY
7LHEip+z0sit2v579n+GrXLWdHy3dPva5zH5mXc220NdDWtaHjYx79u9/wCl c9yNfhWEY92L
g1Y1mNkNtNNbme9tey1v0NjN2+v0/wDSK9y2fksPDjxzh7RyzjLin/Nw4I8P D7s/c9n3fchj
n62LJj5nJE+7GZnHHD26j/X9cTwen+b/AEP/AAt7f6xfWXqOF1rD6L05uJXd k1m52TnvcyqN
xrZRX6Xudc97V0OM++zGqsyKhRe9jXW0h28MeRL6/VAb6mx3t3rjepO6l9a+ jVXDouNl1X1v
FP6yBbjX7nV+q60sZ+idX6XqUV+/fX6V3qLqOg4OX0/o2HhZt/2nKoqay27U guH7rne5zGfQ
Y96vS4fbiQY3/VPFxf1mpUhOQkCK0qQ4eE/uv//R9VXC/WzqX23q7cNhnG6Z Dnjs7JeNP/Ya
l3/btq7PPy2YWFkZln0Met9rh4hgL4XltVljmepcd11xN1zvF9h9Sz/qlQ+J ZTHEMY3yb/3X
R+GYblLKf0PTH+9P5j/i/wDTbXqJeoqz7mVsdZY4MYwbnOJgADuU+MM/MLhi 44Y1o3GzJcWf
+yuNXlZTf/QhmKsjFyuXKf1cDKtztEf4UvS6GXLixAHJIRvYby/xYtj1EvUQ X0OpBOT1nplc
csqrvvc3+S/07mta5ZmR1rp1EhvV67nDSKsQGf8APzWuVkfCeYPSI/wmufiP Ld5H/Bdn1EvU
XN2/WKxtAvqtZYzcWEOq9N0gNIs2eq9raXb/AE/fb/OpWfWa/Hw2X2V1WXX7 nUsIcGBjLPs3
qWelZuv9Wz1PT2247KvR/wC1O9I/Cs4q+EWa+ZX+kOXo1xH/AAXpPVG7ZI3k FwZPu2g7XP2/
S2NcfpJeouJy+r3ZGJT1I01syMXJYwNrNoa9kPy/ex9tn03t2banV1srZ+jr UmfXLqORuZ6V
NE6mysOL2tGtj62XWOqfZs+huRl8LyacEhIfpGXo4f8ApLYfEcZB44mJ/REf Xf8A0XtpeRMG
DwUxc9v0gR8QuGxuqseC84uPmF7iJy67rbCQYYH2evb73NRj1PFrdtFB6daR B+zXvq1P53pZ
GzYz+s+1Tf6G0/nhfbg9P+Nxf9wx/wClI3/NGv72v2cL2XqJeouWxfrNkCwN fsy6oALa9Luw
3s323+rY76f2f/tn0l0W/wA1R5jk8mCQE6N/LKJsFucvnx54kwvT5oyGsbdv 6pdS+w9YdgvM
YvU5cwdm5LR7v/Ympv8A25Wxd2vJbrLGs9WkxfQ5t1LvB9Z9Rn5F6ng5debh UZlf0MittrR4
B4D4Wr8NymWIwO+Pb+60vieGpQyj9P0y/vQ+U/4UP+g//9K71b649Q6pgXdP txqqq7oDnsc4
uhrg/bDm/n7dixftD/3B95TlmpTiuSBxPdPycty+QgzxiRGm8v8AvkY+b5nH HhhkMY3xVUd/
rFlXj5We1+PVWSHtIcWsutIB9v8ANYFV1/8AUdb9lo/7tKWT9X6K3Pq6x1N7 XM97GZORi4LN
xOvo01ftzJZc1rfzaarllV9Rzc+o44qvyq9R9gw93oCCdbWYm9uVa72+tdm+ tZ/57RcbE6zj
G1+H0G5nqEOg1bQDDWOa0t+yu2+1Mhhhjv2wIRkb4Y3L/pL8mbJlo5Jccoir IjH/AKLoNwPq
k012+g3Icw8V1ZmY8js/7T1V/T+kMs/O/WMK6j/gEc39FrbFGBl8ghz8bpNQ H7wnHwrlSH/O
trS8dD3tHi/0zP8AxbrrLESrN60zS/oF+nLmWjnwa2z/AMmn8Me5Y7Pglfl4 DXssZh5FbnuY
0EY3S7CSXf4O6zHo2/omW7P0Vn6X/i/0mb9Ysux+AWNa9jOo31WNuuFTdrKW 24wo2YjMehl9
tlP6azF9PH9P9H/Oq+X22OYbOm9Sp22C4t9E3N3NaWN2/Zy/0mN3b3+nV+ls /SfpFXzrcV7G
wzIfeXPrxsdlRa60WFuS5zm2s210e/Jp+0P99W+yymiyypR5I6Ajv/3Ml0Tr q83TiPt6R1Jl
bHFuI3Hy37RIFm99Wx3u/wAJiZN2R7PU9mN/XWM+MSx7KzvsLNpdztLh+laN vtc5v83uXUdQ
vycjGbj4nTrQzDe+A2q0Gr1q2Vei844+lj2Mf+t5f+UM79F6vp4/6qsfLzPr C6urBu9enEqd
DMdzX10gzO7YWs9vu/wn+DTYg9vNJpufVnquVj9K6hgtseyq8se2L7a2AA7c yt2PjvY2xmVj
bKrsi3+j1s/RfpV0tf1ubjOdj0131NFIc3GozLqwy/e+y6r7TdVf67vsbqW+ naz1abcb7LWu
b6QCcrLynCy2vaaMZrA3c8+o233faP8ABs2/StZZ79jP5CuvwusYtZstqZS1 xJByrd9ry4+o
bLGuDbP/AGVUghYBOi0mrdOz6wdMyHPHU8PJcG7nN9RmBmD3e7V2RidPzNjn b9npZtVyb7fh
H0ziZLcqu0kBrm2VXVOjd6N9OVZlXPrd/gcr7Xk7/wCa9T9Gucv9ST6r6yR+ 45zTr29rP+qU
cfIx6ciu97rGOaPcA0OaWyHF3qAss9n/ABL0MvL451xw4gDsf/QPUvxZ8uMk 458JIrT/AL2T
1H2h37n4/wCxb3RvrnkdK6bT08YbchtG4NsNpYdrnOe1uz0bPobtn0lhANcA 5pDmu1aRqCD4
JBmoTsfK8vjJMMYiTp80/wDupLcvOczljw5MnFG+KuGA9X+DF//TCW6lQtqN lNlQO02McwOO
oBc0s3afuyjEalKFJbE4bb8losbn1sLMet5NVbNrmmsNc6zl1bsfbsbXbT/O 2XU/zKAM3NyM
Q5VXRr7MUyG5YbYW6SHCvIx6/T9sf6ZbebgUZtRqtLmbmlhezR2130mf1d3u 2qpnHEycvG/a
+/DyKcdmGM2ql2TjPpp91FtWHRbjZPTsj2/pPszvS/0PpJkp5Bt6vovAid9H mRmMyX7a/VBd
PsGyzktDdu9v0G+973vfZ/o/+EVyzHptZUKMXJpDZ9W8ZDLGPIEbq6qsfH9D 3/20XrdeFnZt
JxH32mqpjMjqF1Yptvva57nZLaJdZvfUaqfVt/TXbPWyPUu/S3Xen9IbS+93 V6LcvGtqc1za
SwOY8+m5uRRQXNr9X9F+m97HpGUzrqE0Bo5DcFheA2y4unbAdrPO0wz2uRTj 5e4bb8pzbA5j
ttjngg/Sbo17fSdt/SLQyaOh2V7RndYvLSC1lj6g0we5e5/pO2fR9lyH9k6E 1odRV1C3man5
I01hvvrxq2bnfSTbl3l+KdPBqvZm2WetZmZj7YA9Q3Oc6PzW73N3NaoPtzKW QM/MBdo1oyCA
T93/AFCv24fSXU7KcbNdYYcd9roDh46e7936CBndKxX4rbMbHyaMtpB9R73F jBOsS299v7zP
6Js/4RIcXeX5K08EFvWH4u6hltjsgNDTkteX2ufPHquP6P8AqM9/5iqOGbjf rOVjZdU+2q6y
sNZ6hP53q1+k79H6v6P6fqK90xmHgvyac9z+n5NldQwsoNdt0MZNPqt221/a mO/nWfZ7P8BZ
kY1V1vqWMe7pfT8bJe++nMzcyh2IzFxfUNTWOH6KzJ3sdU+2p3066n32fzfo frX6diOaQ04V
CI3cbFqyL22Pa8CtvtO6tljgDr9KwD0Xf8L+jRW4FR0YXPe4/wA447m/FrA3 ba79xXuj9Jdd
If7QA02TqBtG1vs+j67v/A10dGJj44/RMAd3edXH+0nVI6k/RaSBs1+m4r8b DZU6RH0Wnlo/
NarQbqFOEgNQn2sf/9SRZTJ/Sn/M/wDMktlP+lP+Z/5kvKEk5Z9j6vsp/wBK f8z/AMyUXsx9
p32+3vuZp/0nLypJJX2PqFTemb/0Nle/+Qxs/wDRcj7Kv9Kf8z/zJeUJJK+x 9X20/wCl/wCh
/wCZJwyvtaf8z/zJeTpJK+x9Y2M/0rv8w/8Akk2yv/Sn/M/8yXlCSSvsfUMy npz69uZaAw8F
42/c4vVKvp/1f3SzKBgagFo089jg5eeJJK/l1fU6K8IVAY9o9IcbGyJ+Ieib Kf8ASn/M/wDM
l5Qkkr7H1fZT/pT/AJn/AJkkGUyP0p/zP/Ml5Qkkr7H/2ThCSU0EIQAAAAAA VQAAAAEBAAAA
DwBBAGQAbwBiAGUAIABQAGgAbwB0AG8AcwBoAG8AcAAAABMAQQBkAG8AYgBl ACAAUABoAG8A
dABvAHMAaABvAHAAIAA3AC4AMAAAAAEAOEJJTQQGAAAAAAAHAAgAAQABAQD/ 4RJIaHR0cDov
L25zLmFkb2JlLmNvbS94YXAvMS4wLwA8P3hwYWNrZXQgYmVnaW49J++7vycg aWQ9J1c1TTBN
cENlaGlIenJlU3pOVGN6a2M5ZCc/Pgo8P2Fkb2JlLXhhcC1maWx0ZXJzIGVz Yz0iQ1IiPz4K
PHg6eGFwbWV0YSB4bWxuczp4PSdhZG9iZTpuczptZXRhLycgeDp4YXB0az0n WE1QIHRvb2xr
aXQgMi44LjItMzMsIGZyYW1ld29yayAxLjUnPgo8cmRmOlJERiB4bWxuczpy ZGY9J2h0dHA6
Ly93d3cudzMub3JnLzE5OTkvMDIvMjItcmRmLXN5bnRheC1ucyMnIHhtbG5z OmlYPSdodHRw
Oi8vbnMuYWRvYmUuY29tL2lYLzEuMC8nPgoKIDxyZGY6RGVzY3JpcHRpb24g YWJvdXQ9J3V1
aWQ6YWY4ZmM5NDUtYTYwYi0xMWQ5LWFlNDUtYzViZTU4MDBkZTdhJwogIHht bG5zOnhhcE1N
PSdodHRwOi8vbnMuYWRvYmUuY29tL3hhcC8xLjAvbW0vJz4KICA8eGFwTU06 RG9jdW1lbnRJ
RD5hZG9iZTpkb2NpZDpwaG90b3Nob3A6NjI0MDAzNDgtYTYwYS0xMWQ5LWFl NDUtYzViZTU4
MDBkZTdhPC94YXBNTTpEb2N1bWVudElEPgogPC9yZGY6RGVzY3JpcHRpb24+ Cgo8L3JkZjpS
REY+CjwveDp4YXBtZXRhPgogICAgICAgICAgICAgICAgICAgICAgICAgICAg ICAgICAgICAg
ICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAg ICAgICAgICAg
ICAgICAgICAgCiAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAg ICAgICAgICAg
ICAKICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAg ICAgICAgICAg
ICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAg ICAgIAogICAg
ICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgCiAg ICAgICAgICAg
ICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAKICAgICAgICAg ICAgICAgICAg
ICAgICAgICAgICAgICAgICAgICAgICAgICAgIAogICAgICAgICAgICAgICAg ICAgICAgICAg
ICAgICAgICAgICAgICAgICAgICAgCiAgICAgICAgICAgICAgICAgICAgICAg ICAgICAgICAg
ICAgICAgICAgICAgICAKICAgICAgICAgICAgICAgICAgICAgICAgICAgICAg ICAgICAgICAg
ICAgICAgIAogICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAg ICAgICAgICAg
CiAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAg ICAgICAgICAg
ICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAg ICAKICAgICAg
ICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgIAogICAg ICAgICAgICAg
ICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgCiAgICAgICAgICAg ICAgICAgICAg
ICAgICAgICAgICAgICAgICAgICAgICAgICAKICAgICAgICAgICAgICAgICAg ICAgICAgICAg
ICAgICAgICAgICAgICAgICAgIAogICAgICAgICAgICAgICAgICAgICAgICAg ICAgICAgICAg
ICAgICAgICAgICAgCiAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAg ICAgICAgICAg
ICAgICAKICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAg ICAgICAgICAg
ICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAg ICAgICAgIAog
ICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAg CiAgICAgICAg
ICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAKICAgICAg ICAgICAgICAg
ICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgIAogICAgICAgICAgICAg ICAgICAgICAg
ICAgICAgICAgICAgICAgICAgICAgICAgCiAgICAgICAgICAgICAgICAgICAg ICAgICAgICAg
ICAgICAgICAgICAgICAgICAKICAgICAgICAgICAgICAgICAgICAgICAgICAg ICAgICAgICAg
ICAgICAgICAgIAogICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAg ICAgICAgICAg
ICAgCiAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAg ICAgICAgICAg
ICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAg ICAgICAKICAg
ICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgIAog ICAgICAgICAg
ICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgCiAgICAgICAg ICAgICAgICAg
ICAgICAgICAgICAgICAgICAgICAgICAgICAgICAKICAgICAgICAgICAgICAg ICAgICAgICAg
ICAgICAgICAgICAgICAgICAgICAgIAogICAgICAgICAgICAgICAgICAgICAg ICAgICAgICAg
ICAgICAgICAgICAgICAgCiAgICAgICAgICAgICAgICAgICAgICAgICAgICAg ICAgICAgICAg
ICAgICAgICAKICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAg ICAgICAgICAg
IAogICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAg ICAgICAgICAg
ICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAg ICAgCiAgICAg
ICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAKICAg ICAgICAgICAg
ICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgIAogICAgICAgICAg ICAgICAgICAg
ICAgICAgICAgICAgICAgICAgICAgICAgICAgCiAgICAgICAgICAgICAgICAg ICAgICAgICAg
ICAgICAgICAgICAgICAgICAgICAKICAgICAgICAgICAgICAgICAgICAgICAg ICAgICAgICAg
ICAgICAgICAgICAgIAogICAgICAgICAgICAgICAgICAgICAgICAgICAgICAg ICAgICAgICAg
ICAgICAgCiAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAg ICAgICAgICAg
ICAgICAgICAKPD94cGFja2V0IGVuZD0ndyc/Pv/uAA5BZG9iZQBkQAAAAAH/ 2wCEAAEBAQEB
AQEBAQEBAQEBAQEBAQEBAQEBAQEBAQEBAQEBAQEBAQEBAQEBAQECAgICAgIC AgICAgMDAwMD
AwMDAwMBAQEBAQEBAQEBAQICAQICAwMDAwMDAwMDAwMDAwMDAwMDAwMDAwMD AwMDAwMDAwMD
AwMDAwMDAwMDAwMDAwMDA//AABEIAJ8A6wMBEQACEQEDEQH/3QAEAB7/xADl AAABBAMBAQEA
AAAAAAAAAAAABgcICQQFCgEDAgEAAQMFAQEAAAAAAAAAAAAAAAUGBwECAwQI CQoQAAAGAQMB
BQMIBQUNAw0AAAECAwQFBgcAEQgSIRMUFQkxUSJBkaGxYtOVVvBhceEW0TJS IxhCojNjJER0
JUVVZRcKUzSFcoKSskOzZJQ1xTYnGREAAQMCBAQEAgUJAwUKDAcAAQIDBBEF ACESBjETBwhB
UWEUkSJxgaFiU7HBMkJSI1QVCfByFtGCkjMk4bLC0kOTs9PUF/GiY3OjlMQ1 VUdXGIPDNHS0
JUb/2gAMAwEAAhEDEQA/AO/jRgwaMGDRgwaMGDRgwaMGDRgwaMGDRgwaMGDR gwaMGGyumasO
Y4BQchZYxrRe5L1KhcLzWK0YhQDfcxJmUZmDs/VpHuG4bBaa/wA1vkONT8V5 tv8A36hhzWbZ
e8dx6f8AD+1LlOrw9vGeer/zaFYi9YvU64A1cVSyfKvEzgyIiBwgJlzbB3Ad h6P4VYzPe/8A
m76ZsvrF0whVD29oJp+wsu/9GF4k+3dsvX26BJjdK7skH8VtLHx56m6fXhs1 vWU9NdBQyZ+T
DExijsIo4wzW4TH/AMlVDGyiRw/YI6R1dfukaSQd3pr6R5Z+0R6YcqOzjuRW kKHTVdD5zbaD
8DMBwpIT1afTrsBypsOUVNbmN7Bm4K+Vkgez+cpZKnFJk9vyiGtuN1x6UyiA 1vOOD99Dzf8A
0jScJ03tN7iLekqf6YTFAfhuxXj8GX1nEhqZzF4n5DFMlK5J4PsS6ogCbKPy fThkhE380oxi
sulIFMI/IKQDp1W/f2yLrQW7d1tdUfBMhrV/olWr7MR7eej3Vfb2o3rpvfI7 Y4qVCkaP9MNl
H/jYkQ1dtXzdJ2yct3jVcgKIOWqybhusmYNynSWSMdNQhg9ggIgOnWhaHEpW 2sKQeBBqD9BG
I8dadYcW0+0pDqTQpUCCD5EHMYyNXYx4NGDBowYNGDBowYNGDBowYNGDBowY NGDBowYNGDH/
0O/jRgwaMGDRgwaMGDRgwaMGDRgwaMGDRgxXdyZ9U3hfxaNJRVyymzuF4jgU IpjzGJErnZk3
RAHdnJuGbhGt1xyUwABiST9ooAD2FH2aird/Wfp/s0ux515Ei5p/5CMOc5Xy UQeWg+ji0n0x
0N007W+s3VERpVm2suHY3KUlzSY7JSf1kBQLzw8iy04D5jFQFy9aDmrn5ZzH cO+LzWm1xZTu
m1+vqS1negl7AdpvJA9YocaoIjuKRglgLtsBja4y6m9+dm2xzmGJdttZHAOr MqWfoYaFEn0U
hY9cdhWPsr6ObGQ1I6u9S3JtxAqYsUhhFf2SlPOkrH3hyK+QxG6xYy9RvkGJ 1+QvNGwQEY8O
ZVzU6ZNy/lxQV36kT1+nfwRTfgKPSHYsAB8o9uuD99/1Brpd1PNQn73cUkn9 N1MGOf8A8JrU
SPpbBxKlrunbxsABGwejkZ6SgUS/IbbK8vHmyPcSM/pT9GNRA+mLgxsp4q43 fJ11fKm7x0qa
Siq+i4VMO6hzg0jnr8RMO/aLkR9/brmq7923UectxVss9riAnipLshf1qW4l JP8AmYVJvcRv
JaeVabPbobAySNC3SB4fpKSn/wATDwxfAjiNFlKA4xWljFAA72auFtenNt8p yJTDVuYR+X+r
0xJncT1olkkbtSyD4NRoyR9RLalfbhrSetnVCSSf8RJaHk2wwn7S2T9uFQTh lxLIXoDB1RMG
23Uo4n1D/t6zzImAf16SFdcusyjU9QZo+hLIHw5WE09Wup5Nf8YyR9AaH/5e NU/4OcRn5TFP
h2MaCPsNG2C3R5ij7y+Hnil3D9YCGtuP1+60RiCN8Or/AL7MZf8AvmcbLPWP qiyQRupxX99t
hX5W8NdYPTV4wyxTjEBkKqLG36TxdtCRQIPybNp+Nk9yB7usBH3hp3W3um6s wikTTbJiB+JG
0E/5zK2/yfVhxwe4LqLFKfdGBJSP22dJP1trR+TCIi+EGcsOuQk+M/MDIFDc Nz982jl39kqq
JzgO/drvKbMiyXIcewwKsDEEPaA+zU2bN75b/Y3GjMsk2EoHNdvmLSPp5Tmk H6C4a4U5vVvZ
G8GzG6j9JrfPbUKFWhl8/SEyG9Q9KOgjwIw+dV57+rvxj7sMhVus8naSxEwu HisSznJYrIob
mFOao5a7a0VigG4KyDB9t8oD8na/Tb+obEnLYiyd2xnlk05Nya9s79CX0aW1 HyKlufRiO7x2
9dp/UnWdvzpO2ryvglLim29Xq1J5rJH3WnGvSmLCOO/r18WMmvW1YzhX7Xxx t5jpNXK1gTVt
NHI8MAkOkrYIqPaTkP8A1xR3F/FN0Eij8a3YI67o2f3PbG3AlhF7actrzgFH CQ/GVXyebFQP
VTYSBxVjnTqH2G9Utssu3LZM+LuO0AFQDRDEnT5hla1NuZeDT61E8EYuqp12 p2Q69H22hWqu
3SryyQLRtiq0zHz0K+TEpTdTaSjHDloqJQMHUAH3KPYIAOuiYFxgXWK1Otk1 qRCWKpcbWlaD
9Ckkg/HHFt4st429cJFpv1qkQro0aLafbW04k/eQsJUPTLPwwp9bmEzBowYN GDBowYNGDBow
YNGDBowYNGDH/9Hv40YMGjBg0YMGjBg0YMGjBg0YMV+c0PUo418JYxVpfLCN tyau276GxHTV
2j62uBUJ1NnM+oZTwNQiFRMUQcPjFUVIIi3RcCUS6i/qB1c2j08ZLdylc+8l NURWiFOnyK/B
pP3l0JGaUqpTE/8ARntt6k9a5KXrFb/abZSqjk+QFJYFDmloU1SHBn8rQKUn JxbYIOOe7KXK
P1EfUL8S0dzX9lfjpLm3SrtdPIxkrPRBujpSkXpTsbnc/EphucFTxkKt7QQ7 A15Z9du+t1Zm
2eJcStVSn2UBdEj0lTM6/eQitfFoY9D9o9I+37oDyn2oP+KOoLXF54IWhpzz Qj5o8eh4aQ9I
Tw5mM7E3DXAOKfCP/wCGwvtnbCRX+JL0VGWEjkodq0fA9BYKPADdpf6lVUv/ AGgj2682N5db
+o+8OfHNzNvtS6jkRKt1T5Le/wBcv1+ZKT+yMbe5+rG+Nzc1j3/srcrLlR6o y8lOV5ivX5kg
/s4l2WUKmmmkn0popFAiSKZSppJEL2FIkmTYiZCh7AAAANQuYRUpS1JJWTUk 5knzJOZPqcRa
YxUVKUCVE5k5k/SfHHvmv2v0+fVPZfcwe1+7g81+1+nz6PZfcwe1+7g81+1+ nz6PZfcwe1+7
g81+1+nz6PZfcwe1+7g81+1+nz6PZfcwe1+7g81+1+nz6PZfcwe1+7g81+1+ nz6PZfcwe1+7
j0JYQEBA4gIdoCHYIfsEB0GCDkUZYp7Xw0YaLJ2HMRZjamb5EpELOORIYiM4 RDy2yM+oNgO0
sEeZvJkEvyFOodP3lHTz2nvXemyHg5tm/Px2q1LROthX95ldWz9IAV5EYdO3 d17p2o6F2G7v
Mt1zbrraV9LSqo+sAH1xD2EwVyc4h2VfI3CHN1lY7LFcyWO5h60TLNN0TkVB i/YPiHpV1S6U
wIUj9o3XKH+DU6+3XbXR/vPu+2pzAu7rtpmEgKfj6nIjn/n4ytRSD5gOgeGn jiTrnuvpp1bt
qNvdaNlRnRpoiUhKqtk5akLTSRHOdSW1qSf1k0yxbLxB9cykW2ZaYk5p1UOP 2UWyiUYrc/CS
LTHUk+ApUwNPsJEV5igrOlQ3BVU7yMHcTmcoE2Lr1t6W90+2N3RYLe5Xo8db wHLmMq1w3fVR
BUWSTxqVIH6ykcMcgdX+xy+WeG9uzozdDf8AbCgViNqQZiE8f3SkUblBI8Eh t7wDbhqcX7R0
lHTDBlKxD9lKRck1QfR0lHOkHzB+ydJlWbPGTxsdVu6auETgYihDGIcogICI Drq5p5qQ02+w
6lbK0gpUkgpUDmCCMiCMwRkccDyI0iHIeiS2FtSm1FK0LSUrSpJoUqSoApUD kQQCDkcZusmM
ODRgwaMGDRgwaMGDRgwaMGP/0u/jRgwaMGDRgwaMGDRgxivnzKMZPJKSeNY+ Oj2rh8/fvnCT
RkxZNEjrunjx0udNBs1bIJmOoocxSEIUREQANWOONstuPPOJS0lJKlEgAACp JJyAAzJOQGMr
DD0l5mNGZU5IcUEpSkFSlKUaJSlIqSokgAAEkmgxzYc1/WGu2TbRJ8cPTvRP MSZhcx9u5BFS
J5dHtuozZ2pQVXiRmTCPRHqAZ90BhUH/ALgiY3dOR4Y69d2tm2lbpsXbN0Qx ETVC5tNS3Ffh
wm+K1H8WlPFIAo5j0l6Jdnln27bYvUTuDUGo3yrj2qp1KPFPutJ1KUcv9lQR T/l1gamhArDn
FeqUaVUv+SpRbLmWpJ0aWkrRaFHMsyZS7g4runkejKncuZKSOuYTGkHwqOTm +IoJCI68Yupf
W/du/H5kaFIehWZ1StfzkyJFeKpD1dXzcShBpn8yl46M3V1JuF3iIsW3YybV tZpHLQyyAgqb
GSUqKKJQgDINN0QBkSrEvxlRMO4nERH2iJjCOoIEGmQGWIsEdIyHDHnmf2vp HR7I+WDkDB5n
9r6R0eyPlg5AweZ/a+kdHsj5YOQMHmf2vpHR7I+WDkDB5n9r6R0eyPlg5Awe Z/a+kdHsj5YO
QMHmf2vpHR7I+WDkDB5n9r6R0eyPlg5AweZ/a+kdHsj5YOQMHmf2vpHR7I+W DkDB5n9r6R0e
yPlg5AweZ/a+kdHsj5YOQMNJlvEWNs2RHll7g0XTtBIycVY2IlZ2WEMIfCaP lCpmUMiU3aLd
YFW5/lJ8unls7eG6NiTPd7fuBQyo1cZX8zDv99utK+S06VjwVh0bX3Vf9nyv c2ScUtKNVtK+
Zpz+8jhX7yaKHgcM7gXlTyv9LWeasPGO87cTXsoTx1XkHDgha6i5V2VVg3Kv jVce2EQMJuko
Kwr9TfrICpgOn6hduHd7IjqYtWslHF23PLrl+s5CdPxKKf32/wBcLnULpJ0r 7nYDsjlIsfVV
DR0PoA/ekDIOpGkS2vCp0yGh+irQClXWHxj5UYX5dY2ZZOwraUZ2JOZJrOwr oE2dop0ydIFV
IG1wveqrRcimXcSG3O3cph3iCqqQgcfV/Z29dvb6tDd529NDjGQWg5ONLpXQ 6ipKVeXFKhmk
qGePJzqZ0s3n0k3I9tnelrUxLFVNOJqpiQ3WgdYcoAtB8RktB+VxKVVGJFad eI7waMGDRgwa
MGDRgwaMGP/T7+NGDEC/UF9QTEnp64iZ5FyGyfWq02p+6hMbY2hXjZjM3OZZ NiOn6ij5yRdO
GrkKksiL9+KLjw4uESFSVVVTIZ6bL2XM3hMfQh8MW1gJLzxTq06q6EIRVOtx elRSkqSKJUSo
Uza259ztbdajNtx+fc39XKa1aAQimta10VobRqSCQlaipaUhJqSKG+PvrCes hzZk7PaeIPBL
FNzxLU5l7DSFnlWz6Lq/mzExfHVdjkG950xixuNjiinKV4WFYLFaqmAqxEzC BNS/eem3THa7
URvce434015AUG1OFb2k8FlDMVYZSrinmBRI4E54aNvvm/rq07JhsxFoTWlG lIQcsh875Kz6
hxoHjQAg4mvZfV/znBcBs3cip3jA4xVyG435up2D8p4xynHWVlSnk5Y/4WlF ZOpOCP4myuWY
1m4MVg74ehBdXYqjtLpVO02unFi/xXb7f/NlyLBMhLksqZdbLoSlZb0rXy1t 11JUahFSAKhB
rRSl7mvzO3USwww1ekyQ0vmNOcsZKVqDXNQvMBIpzSBWoUoUxKj0vvUmT518 Xsh52ybV4TEj
/DN+slFyXIoPvC0D/U1TreRy2CEcysrIyTKGj6TdI8j0z5UpwfouRIXuO6EW j1P2vb+n85lf
8wpaHYQlBTqgVNNhS0K5qwhtGSmlqqEgBBANSCcOrYcm8bwYhxWofPvbskx0 oYbUOa4V6UJb
bK3V1USEga1EnMUrpFH/AKgfqOZA51P71jHCUtK454c47av5HId5UTXj5PJj aGSUdipJJGM3
X8oembh5XBCYplxEjl/sPdot/Lnqf1sufVXfmzejexFqH8/urECK2KpXKW86 lCpMmnzNQIyS
p92oyabUtQKgEo9cdidKdj9oHTa9dbeq8du4dRodtelNRUlKhGKGyUMME1SZ LqyhgyKH944G
Y9albkLuAOe6Xb4afxjF0tjSrLXmRLIs6aPPFmusUL1GNcyTxdyJpFaXhHLt sVwBhBsBHqXc
EIUpyhAH9Sfs0f7f7nsrqJtvdNxu3Tq9OOQgmaWlPwJzLfO5ZVHYYY9vLZKl xqNh0LjyUurc
ohaob6E9z26O4uXuWN1DbiN71t4Q8hMRDjURUN5WhIYZeefcSth1JS8S4oLS 4wvJSlAOfzE5
itOLtWYOmMCNotc0ylZNhHKC4O0ZxUMUninzhuy2fPl11zgk2bpin3pwNuco F7Wx/T77B4Hd
3c92bh3xuiVaemtkebYc9qWm5UyStpT6225Eht5iIxFjhL0l9bLyjzWW22qK ceZQO5Xr/cuj
Z27tzalnjSt43RHMC5IWuPGZLoYaUplpxp2Q7If1ttNpdaQgNOuOLUQ206lM P8neSLm3Y3q3
IPjrM0VDLci4h6rNQabBz5DIt69J2gP45bR9qtDGCZKRUQuBgVcpPU1ukvhz fF0r/cJ2u9kP
/dd1H6gdp3ca5dL/ALQU05cLdc5AJlxVyGoanbXqtkB59SZD7OlxsyYriCqr jJ0a8HTHqD3E
J3tt7a3WXp3GatF3aX7aZCjrQGn0pU4lqSfdvtoq2hZU2tth5NAQHBrAa/J3 PzKLzOqWCON2
Ii5JsJHdjbKOXYoHTdI04WadpmFnL+yVODgoCJdP0UQWcPDKuFFCAmTc4AE+ 9P8A+ml239OO
3G1dfO8vq1d7OicxEc5UFxDLURy4N82LAS2LfcJk+fyyFv8AKbabZWl5vlut MmQuLrt3MdXd
+9TbrsPoNta1PQ4bjqA5LbcdekoYcU2uUVe5jMRorim18hKg4tbfLcW8046G ESQx7yXutpxv
nCTtmL5ShZLwQlJsp+FmCqlq1gmG9Q/jCOcVqR78zt9EOGKqILHIJ0yiqUUl lSmAQ5C6g9pX
R2y9yHbhsjpv1fG5uhvUmdAESXGeZVc4caTchbZDco+2Qw3JQ7rLXMituJKV tyYjTjSkqm2y
dWOoDnRvqfuvduzG7V1G2vClrdZcZdTEddYjKktqQ3z1ultSQNaUSVpUClbM hSHElKL4i803
nI6wXunz9Rb1mdpcBDW1SRjHh1YFxCTkk9hmrQQerKPySqL2KcqqGEAQBDo2 Hq6tnh3+9hG2
e1CL0w3F083Tcbpt7cUmRBEeaW3p4mxkpdUtBixIrJjuNPMNtthC3i9rJJSp ICX22dd751fa
3dF3dAgRrlbAh4uxkOMRhHWKUWH5MlYWlSXFrc5iWw3QaQUklkc2+pqtAXRp jvBOO3OTbLKT
o1mvAm3fy8hb50neiu2q1bjF2Kjhi3TROod46dINyJEE5xIQQEequjv9ITYd i6cy+pXd51Vk
2FmLCEudGhvxYUa0tmhDc65So8znyQVBtxiNHbSl/wDcsvySQowrubvG3jur dDG2+hGz4kmG
89y48mYy/IfmitOaxEZejCOyr9NpTzj7qmiHHWGCFIDm1DlbyXq8/RY3kbxu k6nC5Dttfo8T
O1BeKmV4iwWd63jocJ1CDttuh2jLxboBcCs9bKpoJKqEIqJOg0A9Se0vsW3x 096m7n7R+5WT
L3pta2P3J63Xp0tImQog1yTCD9qt0pbgZS4tpTHvEFwNtPpjpfQ6JQ2j1N7j 9vbt2pZetPTa
H/hu7yExkTLeyrVHfcBDQfUibJZCVOaEKS63HVpUpbS3S0tGLChkQARDr9g7 dg9nZ7teUYiV
ANMdi+2PliE9n5qRlI5MnwfaIdo2q641qKbXFJ8ZNeOsFkbRjhueZRXHwoQi Z5EE1Dk6TogP
emESFPr05sH9OlzfHY1aO5zZN8uD/UoRbhcpNrWG1R3rZAmTY7qYSG2Q+JiG Iwm1deW260l1
tDaVlsnkKX3KrsncZdeke4IENvZwlRoLEpIWH0TZEWK8hUhanS0WFvvKiBKG ULQ4ppSlqGsC
VWQMhxOOaXabtOqCSOq0O+lXKXeFTVcKtkxBswRE3Z4h87EiJA7fjOGuG+hv Ru+9durWwOk+
2Vabhe56Gi9pK0xoyQXpkxaQQVNxIjb0laQQVJb0g1UMdCdS95W7plsPdG+b s3qYt8bUhqoQ
X5DiksxYyVGulUiS40yFEEJ16zkk4jXxK5c/2kWVzZylcTrFnooV95KEZvBX hnsVa17GjELs
jOTi8SWbHq7grnvfgETFEg7dQB1d39dklr7SN1dPE7N3DNumy9zRJBjCXocm tSoTjLclpxTD
DDLiXPcMrYDbQWApSF6iEqVEnbb1ruPWbb+5ntxwYkbcFplJQ8Y6VtRlMut8 xpaUvPPrQU6X
EulbpSdIUNIJSI75w9SlxX72wxdgHHjnK9xl54avBEQSXkV7PPJAsZ43rUM0 eRhV4yORROqv
IO3jVomkmJzGKUSibsXov/SS2PY+mE/q13k9T5e2rdEhCXLiRXY8VFrZVp0J uE5+PMLsxSlB
tUGLGCkO0ZRIedJQiCd19327d07tj7S7f9qw57DrvLZly2nn1TSK1cjRmnYw ZjH9Jt95x1bj
Z5qo7TYqVYTmJyGxKaCf8o8CIVGpz79ONJYqlMRMmtFuzpC4FN00iLPbY5ws RApzdwZ02VUK
kcU+vpHdlQuxLst7koG67f2Xdw13d6iWlgvqhXppZYfaKuWhQ1223ymWFOlK FS2ffhhS2kvx
kF5rUuTeu/cF0imWWR126dWx7as5fLS/bv3byFgalpCjLkR3Hko+ZMd1EMPJ Cy1JIadKZIZy
5Dlx9gpzmjHpYO7sfEwIxx1Xi/lL2PlpUkWuuCrQyTkq7VwfoMmPSdNUpinK AlEA5H7V+0iJ
1T7n7j27dcG7zt+4wYdwMlqMWG5bUuGG1Jb1vMymC0pClOhxKHEPNaFMuaHE rxNHWbq/J2j0
htXVDpu7brjFmyoqWXX23XGFR5CHVFfLbdjOhwKQlBQpaFNLKkuI1IKMQuxt zq5XZZSm5bHv
Fttb6xWp0K7M2CLmmaDIsqSFiLAuxaNHlrSsj1VGNnG24oR63xn6SgbYdd99 XewL+nD0Ovtp
2T1T7mt1WLes+A3LYakOsup5DzjjTTri2NtrjtoU404DzJDekJJUUporHO2y eufdt1AtT+5t
odO9t3GwNSHGVcuLIQsuNEa0JDl7SpRAII0oUSCAAVfLiU2CuXVHz4vM0CyV 81KvrcHsdLY+
syiT5vNIoEcllmkeLtq2F8oxTaq+LZLokXTIUTbHKU5i8Y92/wDT/wB4dsVq s3VHZO7huno7
JW0UXSO2GX4K3qKiqkpZdfaVHkhSUxbhHdLLjlEONx1Oxg/O3QnuSt/VG6v7 YvNnVYuosYKc
QyHFKbfDJo6Y61oaeakMEanYrqS4hFVtuvBt/kwONzJyD6d/Lm42jj01kYMk JZ4avnpyLqSm
a9d4mwrw5WtVm60m2UdSsU9kJcncFKqC7MRBRuqkchTB67dnXbjsSZ0F6Z9d 751HvcK6SduC
4XR1UiG1B5bYUqQHWzAcUGmgkhRLinKpLgUlRyijrv3bdYd/7s3B0BldPdsX spvLlvtq1w5h
uYfClNsOofRdGGfcrABNGENOag2424knV0kcD/WhzryxwzzVudu46xNQtfGf BlxzHU5djFWu
Lx3OPIGszEnFUmwpWGdXsjiXfvYk6xlWZkW5mJFAKcFS66YaidI9y3TbrPTr qLEvMJ+czHkt
x5Tb77QdUAlyqWGw2FCqU621fOK5jIcy7p2l1q6Z2m6v9VthSLLcBGedjKkR lstO8lBKxT3D
2vQdJUEupOlQFE5KLuekN6uty9RW55ixnkfFddo1uxnWK7e2sxR15I1XeVuw Sa9eQjHiE9MS
sv5/5vGulgOQCNvCgUvaoBhFZ6i9PbftS3Wu8WqS8YUh5bJQ8pK3NaEhZUFI aaTo0qSKUKq1
NaHJpbP3Dc7wqdHu3IVJb0qCmW1tp0qqNJSt146gQTqCgCDTSKVKp9X71bB9 OCBptUx9QWGS
c3ZDhpWzRUZNkl3NdrNXi3YRyUrJQ8AsynLNJT8sRZrHsGrlr1HbqnUWKBCJ rV6Y9NUb3W9K
nyVt25LhbSEFKVLWlHMWS4pK0toaQUqUShRVqCU0+ZSdfeG7pVllRbXa22jP WEKWpwKUlCXH
C00AhKkFa3VpWkfOAjTqUFVSlSF4g+oH6kyudcIYY9QHg4ti6L5JlmWeM75j SMSVQqM7DU2x
5AUZZabtMpZLhq43XrlTfAKKr1lKtnJUyCzVA5zJ7O5dlbHNlvN22dupuQ7b ykuoWsgLSpaW
v3KVstrUda0nWFLbUK5pNK5bPdt0ouzFuv0BIjOtFSHEIOSga0UsK0/o/qFt Chx1K4Yvo1DW
H3g0YMf/1O/jRgxxDf8AU6zNlccvMJ14TujQEZxpj5ivtx7wzMLBO5KyQynV UCCPc+LWbV+N
Kr0h1CQiXV2dOuouiCG3bEhktghV1UFeoKI40n0ArT+8cQn1EAZvEyWp0gi2 o/zQlUhWoeRJ
Jr56U+WOpT0ysaVHEXp58LKHRwaGr0dxpxBKkesypFRmZe10qIttlsRzIlKR VzZLJOO36yna
KirgxhERER1B3UK4Srpvnds2ZXnquD6aH9VKHChCfoQhKUgeAGJbtLLbFsgN NU0BpJy4VIqT
9ZJOIqevaQgemBnkwEKBjWDDhhMBQ3EwZcpJAMI7biIE7N/d2aWek5P+MI/l 7d7/AHhw29+f
+5Wv/wBy3/wscc/DrJubci4SyLw0pskNWw695CHy3lSXjhXQdzysliXDkCyj Z50U3Q8jYxCq
lVYRwB3bh8oKywGBFMUuKv6qXV2Zsu/bF2uZGm3vbYjvhpBIXJeMqYlCFmv+ pa0a1UyqoVqp
LdPST+mztfZNg6Xbs6xXeIJO8UX+bAhIXQhoIQ06tbQ/VWsvBLjpzQ2jQgjm LCnv5yWZjiHj
zG4VxZHMW0lbgdFZRjh8zjwesIRMr5dxLyr5w1QBecmwbpruFjlAxesAEAAp dQL/AEiekMvq
R1v3n3Bb0UFQrGx7CG64QhAnXBtQkKaKvkpEtgdYKKp0G4sLrqNcRl/UR6sy /wCS7d2VKmPO
3C6yBcJwabW8tMKG4ExGg02FOBLk4h9pKUq1C2upIIKjiCeI7NDccM845mIe 8o3WtwzGpxVw
tbcSkSlIyfrMfE5DVedaTc3dQ0k6dPiFAod4oxQOAD2a9MO5PpdvLuY7Sepu 0N7bFZs/Ut1m
XcoEBqTGmBmbapcl626H4jshlTlwt7ZZLaHCW1T1NKopGXHXSDfO2umfXHa2 4Ns31+XsgyW4
UiQ9GkQ1Liz2mUv1ZltMvJRDlqbPMW2AtEQuJJSrOyrmxgSz5cYVy8Y/EX9x oqDtmaCTOkCs
7CuHBXoGiVVjlQVko5yBzkQEf8rSWMUm6hSJqeOf9NfvF2h28XHcvTbqg4Ye wb9KRLanaC4i
FNDSY7iZjSUrWqJKZQy2pwJUI7jQ5zZYeddj9592fbxfOqsS2bq2k0JG5LfG MZyNrCFSIwcW
82Y7hUlKX2HXHVhJUkupXVtaXWkIeavj9zktLG0x+MeQbdePk3ktE1mLsr2M ViZZnYpWUaQs
VGWqOWK3MmDyRepI9+CRTpHMAqF6eowdJd539Pbo9unpVe+4TtVhxY70OI5c ZUGBJTItNwtr
aFrlyrWAp1LEiOlKnyww97J5ht5DDLDzbaHoX7eO43qRt7qBa+lHWafJlwpD wisSJrJbucGY
aGOzMWUtqkR3v9UHJDZmNuraW4++04stNpmLGeaOMeXbFmnEiTyQqk09lZVe TaRpJcsChOPB
ey9es7ESLOWsWV1sVN38KKyXdgZQqwCQJe7au57t47w+im3u3fuDi21zeSWY sZy3z1qZbuUi
I3yY1xtUttbKm5y0qUSzHeZmNOOPtNodiKKnGb1h6DdUOhu+Z/U/pbKnx7E0 p51qZCopyEw8
rW7EnR1pdQ9ERpAKpDL0VaENPLLchIDcoqJyqg+QWEMwRbhsSGyDWsVWN9aI RIFBYLMJOHno
9nMw6xzGOozUcsRIskb42xzkARMU5RHjHqB2VyO1PvT7WLrtaXIm9Ib/AL+t H8tefWlcmM/H
uMNci3y1JQ2lxxtLqHWH0oSl9hfzAPNPDE5be65u9aO2nrpG3Gwyzvy07XuI lhlJQxIachP8
mWwhS3C2FlKm3mStXKeQSk8pxsCvzhjJP4oOZTyLMoSRR40V9RmdLqBUiqc1 kgxjpCT4gUIn
uYBDtAQ16Rd8Ua1Surv9OpF5CDBT1OkKor9FTqU2tUdKgciFSEtJoeNaeOOa OhKJjnSjutRB
1c5W1kJUU8QyvnokKB8NMdTqq+AFcK702a9Gu+Q+QLfJNkl5Co4dZMqmusQD nYL263qNrc5Z
CO/duFI2EYN1Dl2MCS/TvsoIDDv9Y/ct7gdAOju0IEhxFjvO7JbswJJCXjb4 TS4rblP0kpck
uPBJqNaErpVAIkfsPtFum753/dXm0qucK2R0tV4oTIdcSpY8iQ2pGrjRShwJ xd95kXYQEdwH
bcBDcNwEDFHYflKYAEPcIa+dP2lDUDP/AC5H4jI+Yx6fe3rxGPQkQEQDf2jt 8vy6tVFCUqUR
kBXFyYxUpKQMyaY53c/DYsh8geTNrYN0X1fx5KVBWUUL3gqJNJycttJSOqJR ADMir1NsiIAI
GDvhH2b7fX3253janSHor2c9K7oEs7pv20w7GbcALbz0K3W2dPjKbNdTizNl PKSRpLceQFk/
KD4VdSbRed97q6778huLXZYW5pLTy28ltNyZspqDJQsfopSllhtKsyHHY+gD M4erN/Jy1Zsx
Xx5wjU27uayNfp6EgbW1e94j508hXqrNOXdO0CiioyGtRbywPVADuk125kTb GDp1z/2+9oWw
Oyrqb3Ndxm+nWIvTFtwmxqCkuLi2GS4zJfbCf0kyXJjseyMEFDhMOSNJZkhS pF6j9aNz9y+3
elPSzbIdc3ZEiLcuoCShD17aaejs0JJCmGo6XLisEKRpnxlgh2OQlH8NLDI1 97ygZRa6qcpO
8apiSiyJmMU/jKHLPC96kJdxKqilfjiAhv2iGl/vp21arjvnsA3Jeo6XIEDq 6zFXqAKKzEwn
mELrUaFyISAoHIgGuLegM+Sdhd1NlgOqRIf2Qt/5ahWhAktPqTQg6kx3F0Iz BpnwwpfTcgY9
5yNu9rkW6az6pYZFtWF1QAxmbi23JkztDht1AIkXPGxDNA5y7CCa4l32OO8N /wBY3cV4gdu3
STakGQtFnvG8X3JYBIDvsIAcjIXT9JKXJCnQk5a0JVSqQRJ3YhaIEzf2/Lo6 2DcIVpZS391L
7ykqUB4EhCkV/ZUocCcT954vI5fjfZk3ndiv5/UzRQH/AJ4SAS6YHMj9sI0X AD9kR156f0oY
F5Pdmy9bAv2DW2LkqZTh7cqioRr9DMVFp94DHQ3e2uBG6LQ0TCn3Tt/hpjg8 S6GJi16fUR0v
19CcVsYmuM5NcKeUtWfqKrQVNzLjhCtHP1CigadhaRKz8c1MIiTu20gmRycp f5qzw4j2m161
dSNp7ftP9TLt93Zb0oRuO89M7oZwTQKV7Nx+NDeWBnqXGAZSo8UR0JH6OONL JPnyOzzd9tfU
pVth7yjcgngnnh119segdq5TwLpPjiZnpjuwQxDlYgj7c5PzfPi3FofJ+zXm d/WNYDnc3sVR
H/8Agrf/APzbljr3sXaK+jNxI4/4gm/kaxDDOtgUr/OJtK05UUZJXkLhxq08 EI9biRk7jR21
mblAuxjA8SXfFcAHYKRlN+zfXpx0w28bn/TBesnUNrVEX0fmuLDtPlYbt7sm 2Kz4cptEJxk8
QpDZGYxxzeJyUd4hm7WX8ze/1oBb8XDJcYmDLwW6qQhfgdRGP1ylk5CN5nzM lX4BS0WVDKmK
VKfCpuGrYr23kd0kaqVwo/kYpgZkWeKgK5V3CaJkQMBhEOwVjtSa2av+nVth nqcrT06V08nJ
uqtUhC0W9RkCSttUVKpAcS0SUcpJX+yCaApPVyPuhzuovzWwpvI3iN3kwlFt lxJkJBKUrTIB
a0qIIqsUBoagZh6q3JcyMQzOUr8ONlcOV244/tlFu56/NVeSg7DXslMn9YtF ee1Wv2ayt04Y
WD8XJVD9CbR2CKqQEOmUwcb7a352jWjrd24N9qHUyS9cpe4INvmwXm7orVHV JZ/frk3Rlouu
OhfKDSNWlTKHR85x6KR7r1w31209yGye7O3Rp8m37WuNys9wpBadEiJBdWiM lEABIU2Wy5zl
/vXm3XY6ipGRs+/6XQA/tOcxDbB1BgXDBQHbtAByJkoRAB9wiUPm16vdbK/4 L2qPD+ZSv+hY
x5T9Pf8A3hev7jX/AAsWd+uR6ZmYeWwY65IcbgGfy9h6uOavMY8B62jpS101 CYeWWMkKY9fL
tmBrRW5WRenOwWOQ0k3c9KB/EIpt3TD6Xb8j7aU5arg7yYq3i627SoQ4pKUK DgoaoWlCRWhS
KELBSolKnvTaZveqaw3zHiyG1orpKkJUtaChVRpWhS1EEEKrRSVBSRWJnpne tXm+GzfA8OfU
MZSrSxzlmg8aVHIVrrK1QyFWMkTkswrtbpmVoRy2i1HCVilZFBmjIGapPm71 ZMXffIqnXbuv
e3Tu03a1y9w7SitNSmWlPuNsqqw8yganFspGpKVoFVlLagyptKtCEKSAtv7U v93tVzj2S8zn
pEF1XLQXk1fYcpqSlxw6VONqA0hToW+HFJ1OLSr5OszXOeJhwaMGP//V7+NG DFTvquemNC+o
rjKsBXrHF0LOeLVpZ1jq3zDV4vASsdMoojLUi2jGgrINYSTfMWrhF8ig7cRq 6JjJoKlWWTUf
Wx96O7SmO81tTlseprSkjUkjgtFctQBIIqAoUqRQENvcW3mr4wnSoJloBCSR kQeKVeh8DQ0z
oMyDW7hPLXrecLcJVfjSTgLWsxNMbQgU7Gd/gbdXpdkNcjjqt4NJ4nXryi1L HRTQyaTNN4jF
KptUiEUTL06l6b/3JbwuT247xc5jNyfVzJCW30MNuuHNStLsR1balnNzll1B USUJQKARa3A6
y2KOmzWGbbF2lCdDK5MVx95lAFEp1tTmEvpQMkFxLbgSBzFuqqow9588t+bV 44gJcIeV1Bqy
HLHKOSG17lqhUJ2tSkpUsRRkqxuVFjbo6rE49pUVd7BOd/3Mci6UQja7Fs3D lUV5Dpbc09RO
4/oZ0Z6w2ZgXX221DBWqc+lt91qEVIKGEJTpVJc5hCFrWUKcJKyGihxtZ7B6 Z9pnVrqh0D3L
vh14SbnBkoEQPLZYVPcDtZS0n5GUpZSotNNp0oU4Q2lzWw4k1T4OieVvH6t2 GGqPHw0oay2M
LbOHkbtjwrmRlEIGGrqLVqctiHwLQYqAQIUDGU6FjqKAIdfSEA9f+pn9Ljub v1q3T1Q6o3X/
ABdDsgtceRGTfGYzLaXZDzT6oabP+9cackqUpJfSl5KEIVQVOMvTfp137dJI Ttg2PbLW1s9y
5mYuM+xbX31FwNB9oSl3L5EuhugWljU3qqNRSMK204TyhnTlLjK7ZgoMa3w9 Vq8hYZaEezEF
YIRWea1hQsdQ5GKM4M6mUUbdOLOXKh2pmaoR6YicesCBz/H7q+i3Q/sSvnRT t837PT1kkT3I
6pSI8qHJcEieXJt6ZfSgNRy5AjxocZAfEptrlgpCkKUZridAuoe+O5yV1Q6p bdiq2QphCmWC
4y+000xGS3Fty0KUXHC2+t6Q+rl8lbrr5SdKwMbflJxZYTsFWpHBONKlFy8Q /epzVcqcbWKk
nOMZBNp3LxVJU8NEO3Eaqz6R71QFDIrCAdQF20m9hPfg903v+87R3IdVL5Ks kwRpECdPdm3P
2cmOXA81kJMlCJSFMqToQptK4+YSXCTn7pe1lze9u29P6T7Nt7VxZS/Hlx46 WIZkMO6C0sEl
poqYVzgqqgspeFCQ3QKqEsfKyr0vEEn/AMu38m8qEFN02+UlSy1l5NzTSKfJ sqlaDuWrx42k
ReV5o3OoDRXxgOxVA5CkH4sFvT/Tc3Tu/uK2FvDdsiJs3cW42b1Yb5EjSmHL YHmdT1tbL8JS
kIjSHpjLjMyOIcmMqO6h1uSw2pGjfbR3nWq0dIt57Ot8R7dlosarbdbZLcbd jz1JdJMxxDUt
oa3224rjTsZ8yYzzbzakOsPLSpiZbDucOTvIOn5CyZjxTEmOqjMVCZmTS8jG Gn7I3oUwlYoO
uw0WzcrSveSkw1RB29ept00GaZiJgqYxemcd5d0XaT2v9rO5ug3bBvKburc9 ytk+Gy65zHQ0
7dUuIm3GZJMaLERy2nVCLChoX84b5przXnGTsLoP3AdVes0Lqx18tcO2MsTY 8hTMZAZQGoaW
0x4cdoyJUhQPLBekyHKqUta0aEpaZTISZyZypor29RRcRSGT2cpPzrumTkHJ xLhq3h5R06Va
Mlm4HRctAaouQKYr/oKAl6Sj3YdRos23t3+lh1Yh9K97bt3zdNnbns9qtzFy tTalRWbg9b2W
WkrkOGBIAed5ID8m2O6pSTzVtsTFuOnfvETv82G7vjae07faL7t+5zZrsW4y GTJkQUzXXXHB
GQJ7GplBdJjxpzSkxVfu0uPxUttJaPjHxfyPQ6znK43tGMhr7ljHzigVakIS TV6jWYFNOWfk
UsUpHKOYss5OzkimKiTVRwgzbNiF71Qwm23e63vz6XdTeuXbOjZTUuX0q2Hv CPe507kLZXOk
Jfj60wo7wS8I0eOyoIU8lpx9xxRDaEoSVuPpB2q7y2h0e6vWm8Pstb23Nt96 3MMqcDiY6FsO
ISX3UVSpxbikkhBWEBNSqqylH04VYNyjjG/5ZlMmUkYGuW7HlZqzMX0tWpYk u6irJZHMg1O0
hJiVVTZrxk0A/wBeVMDlESiG+4aSf6jndF0c627P6Enon1CXN3Vt+/zZjhaj zojsXmx4ZjvI
ckx2BzG34+RaUspWkKBpnhT7TOhm/unNx6kx+o+1kM2e6wGWUpU4w+2+lKnU utrS044dC23D
ULSkKSSDjOjcJZX425Mkb3heutMl1CVaSEeavHlmkdYoeLfuGbxaPWTfumgS ZEl2SXcqthXV
V7ghlE0zAAmfMLvC7Xe7zozbukPeQu4bd3JEkNSUXGEhYb9802tn3kN5qNNT H57Ti0y4UyMI
ykqSG31KbbcZj679tnXvoX1AkdQO2uXCuEJ5pbK4cwBwORVrDntZbKpERTvJ cSFRpcaSmQhW
vU1occbddWCy/wArrfkCqMEcFBRKKWWQLcbDcZRiim3gjGL5gvHRvj287JTB W5TEZopImQ74
5VFTgUgkUhLqz00/pk9P+iO9oPTfq1ed09X5DaVwH1KU86HWyS3HQ3Hgx7fC jOrKTNkSHJMl
bKC1G5JWomROmt174N09Ttv3TqVtuz2Xp7HC0vw4zPKaWHAEqfeefmSZkp1p NTFaZTGYQ4rW
8l6iSmZfmQgO5VO0O0u4+wwdpd/b7B15YiEhZSh5J5JICqcdNfmp60rT1x3U WnEArZSOcASm
vDUP0a+laVy4eGK9ONmBLnCT3KMcv1xNhGZaSrdfYOgkomUJPxzN1kCSkpVm Vi8dOGQNntuI
dDxREF+9KBwL2AOvW/vf7xun++9w9p28e3bcDqp+y1TZimHGZEcxHnXoJZhv FbbaHkOR4ymH
xHU40tpS2yaLIPCnbR227p2htHrBs7q1b21M35DDHNbW24HkIYcbXIbAUooW h0pfZLoStDgQ
oZprhPcS+Kdrxhmq85LyWzY9NWhRpGI1G71k+RkELF/ll0vCSSCqi8ao6Yt2 kWgk5Km4IUHQ
9PSoAmzd/PfNs3rz0f6a9NOkMyWmFOlfzO/IeaWy4y9FOiBbVFQCHkocLsxx bKnGVKTGorUl
SU7XbB2zX/pfuzdu5t9R2FTmkGLBU2sLQttwHnSUitUEoo0kLShwBboKaAEp vjlgLMWMOShb
BY6SYmPlKzkmoydiJN1l5DvY+xlhJKOEkWSYUn127yRrzdIQVZk6QE3WAF7d Sd3v94fb7197
YIll6f77kN9UY247Vd4sNUWcxJjrY9yzI/2nkCKl5luQHEqbkqroBQoqoMML tm7cuqnSrqvM
l7v26w7tB+zyYD76XWHWXwrlrbqyXOaWnChSFJW0Ml0UKVwvIzCGSuOOUJPI OGKy1yTU5hjJ
xpqyM21iLDBR0k5Yvl2BiyTlqhMs0XMegLc6JlXJu4KByEEBMqjRO73tn7vO i1q6Od5c26bb
3PAlMymrvAbJaVMaacY9yyW4sxLHuGXFpmw5EZEZR5a2JSShKWrLt25dduhP UOX1D7aF265W
ySwth23z6rCoy1pdDDwMmItamHEgxJbMgvJCnEPR3AtRWgM2seXPJ11E1Bli Ucb1ePeGdDLX
WWZxtebuzlFAJaRQTcq2WZUZIHMKTVo0OCgjsKyW/UWXOknVz+m92T7T3FN6 WdQ7lundlyQg
SXUpVLuk1DRK2YbRRFiW62xA4dbgW6Vrc0uurf5LDbbC3L0l7x+4rdFokdWL LbrRZYGsRo7K
fbQIhd0h+QrmSZcubLWhIQl0hKGmqtsstB19br0TfGdWgcRZHBWL+8ttjVkW 9pnpWRUYxcne
rY4mWs1Y5cRcOEI5i4fqNiIs251ioN2yKSInAC9euNOlPepb90d8rvcn1wKr XtyRbH7bFajp
ckM2qIUJahslKEl51tpHMXIdbbLjj7rjwbodA6Z6ldt9wj9usTpR03QiTdY9 wYmOqdUlpUxx
CXecQVHQhalKbDSVr0pabCFL1fMWewsz5U4EoNnqVQ49S72Rs9lc2txMP73j hwLSVcV6ArgA
wYI2FFuk1SaV5E4FWcGP3pjj3gAJQL2X1i6gf0s+4XqftXqz1X6sXWfdbVam IP8AL0Iusa2S
W4z776DJS3YvfLSsvqS60zMZ1pSAHE1NeYNn9P8Av96a7Qu+wOn1ksttscua 8+JnIiyLnH56
UJWGHXbwYSXElNWnnIDoQSCWlFNcbLjlxFvTfLDDPfIJ1HpTtekJCepdDZSS E65Rtsoi5bK3
a6SzMTxJpOLaPViR7Bmo5SQVVFY65jFIQsH9739RLaHUnpxduhPb3AkJ2vc0 Ns3K5uR/ZNrg
sqSpu2WyGQlxqKsttpeddbYPIQmMywlsqWZq7Z+0K69PL1B3x1EkIXeYgJjR g6ZC0vLB1yZc
ipDr1VKXkpwqdPOcXrFDoc04QzU+5Jvcp1zGj29Q7W1VO7QDqMtdQgkQkqqr DvoprIFnpdk8
Hw0hCE8QmVAxFkTbAoAmESzR24d4PZ7G7Tdv9DesW8Zdvbc2w9ZLjESxcEyF IdQpLz0aVEgT
mkpcKypoqGtOaVNigJiXq/239yC+td86k9LbfCVNF+NyhSXfbvspqtRQ0/Fe lw1qUlB0qosJ
1AKSpQyxKmpW7kZkWGyZUMo4lZ4/bSdDmm9XsRrRW5FJ9PSiCsWnBrMa/JSq jdJJJcXJnSnS
AAHQACOuJupyexTpV1Y7dOqvbHva6z7VZd0QJF3trqJ7z4jwpTcszWpU6JBQ VrCBGEVpulQH
SoVIx0Lsiyd1G9emnWTYfXWDbf51dbNLYt0xlqLFYSuTHVHEZyPFkSlFIUov F9ayqhKKUAxG
fidn7l/6Yd5uWQsf4tUbT2WayxoEivZ5SkTlQfxVZmXM3EuE2DWdM4ZzTB1K ujpKqOkAO2cm
BRA3TuX2Jj96vZN1Ft9vg3LqM9LdguOOhDbV1jJHuUMpUH0G1LLhbLNEradS ElSxVSVCvGdt
7Me8yY7d2dhbbt7MZYaLpc/l78kFovAKjuOXRgJbcDgDiFx3alts1QrLHUDb Mu+s1IR/FDlj
j3jjXJkh8P2yv5740QmWscT8PPyb25So1TJEbINLAEbJtLXTWENOxoV9+8fR pnqrBU66ALGW
kizSOi8lm72SRcFSLHJkJkRZrOptYQ400pCG3HGXKoaJdbVzUht9Kg4ChYQo QtuOxdVLdcIs
yE82xuKJHEWTGktqU2XW3HBI5rKH2NDi1BvSpB1sFtSNKkrWgwRqXp5c/vUa 9RrHvMPmJhKI
4r4ixxdcX3iYhHMzCOLLdE8KS8fY6NRqzAREzNz4BK2OJaqS8vMGYlIwKom1 KsYU00nbdN8b
B2btaZY9mSXJMtcN2O0FKLhT7jWHZDzvLab1aXFJbaZQafKFnJS16O3Nr7tm XNV43hIZVMVI
DquU2Wmk6UJbQ002p15ekJQCpbjhKlqUsaBpbT2Aa5exMWDRgx//1u/jRgwa MGI3ct+SVS4l
8fsiZztwpOEalEHLX4Q6wIrWi4SQ+Cq9abDv3gGlJZVMFjkAwt2pVVhDpSNp pb53bB2Pte67
knUKWG/kRWhcdVk22P7yiKkfop1K4A4kfpL03u3Vjf8At7Y1oqlct7965SoY jo+Z94+HyNg6
QaallCK1UMcUWOnVtyFarpyMys/UnMnZdmZGwupF2XY7RhJriqPg0jibwLd2 QpE26JNiN2CK
KRNidmvDDrDvS57w3DPEqUXFqfU4+rwceJ4U/YaHypTwByGSRj2uvzNp29ar L082rHDG2bSy
hlKE8FKQKfMf1inMrUc1uqWs1OeHp8eHvD59Q77U+WGhyfTB48PeHz6Panyw cn0wePD3h8+j
2p8sHJ9MHjw94fPo9qfLByfTB48PeHz6Panywcn0wePD3h8+j2p8sHJ9MHjw 94fPo9qfLByf
TB48PeHz6Panywcn0wePD3h8+j2p8sHJ9MHjw94fPo9qfLByfTB48PeHz6Pa nywcn0wePD3h
8+j2p8sHJ9MHjw94fPo9qfLByfTB48PeHz6Panywcn0wePD3h8+j2p8sHJ9M HmH7PnDVfany
wcj0wePD3h8+qe1Plg5Ppg8eHvD59HtT5YOT6YPHh7w+fR7U+WDk+mDx4e8P n0e1Plg5Ppg8
eHvD59HtT5YOT6YR19rUZf6tJ1mU6SkeJ94yd7AZSOk0QEzF+l8oCiqOxwD+ ekYxR7B0sWKf
LsF0jXOLUqQaKT4LQf0kH6Rw8iAfDCvYrlJsVzjXKMCSg0UnwWg/pJP0jh5E A+GLivQn5jyk
9XbNwhytImC8YiSfS2K136wmXlKGi7KScqaKyxupyeoP3RHLEoCYxot30kKV Jnr2L7Wep7W4
LINnTJWt1hrnQ1E5rjn9Nr+8yo1A46FFIADeONO+no7GgXG2dbNqx/8A+kux S3OCRkiUU/un
yBwEhCShw8A83Ukrex0Wa67x524NGDBowY//1+/jRgwaMGOSr1r+RA595N0n iNWn6qlAwXtb
MoHbL9TOTvcxHtlysVikASHUrFcdps0zdXUR1KuyCUBT153933Uz/bUbWt73 7m3iqqHJct1P
y5ePIbNfRS1pPDHrL2VdPBsPppeurdyYAv18/cQtQ+ZEVtZGoVzo+8kuEUoU MNKBIViCxHaa
RCJJAVJJIhE0kkwEqaaSZQImmQodhSJkKAAHyAGvNdUZSlKUrNRNSTxJOZP1 nE9FtSipSjVR
NSTxJPEn6cfrx/2/r1b7U+WKco+WDx/2/r0e1Plg5R8sHj/t/Xo9qfLByj5Y PH/b+vR7U+WD
lHyweP8At/Xo9qfLByj5YPH/AG/r0e1Plg5R8sHj/t/Xo9qfLByj5YPH/b+v R7U+WDlHyweP
+39ej2p8sHKPlg8f9v69HtT5YOUfLB4/7f16Panywco+WMdaaat1mbdw8QQX kVV0Y9BZciSz
5Zs3M7cpM0zmKd0q3akMqcpAMJEwEw7AG+txiy3CSxJlR4DrkVlILi0oUpLY JoCtQBCQSQAV
ECppxxqPSoMeRHiPzGUSnTRCFLSFrIFSEJJBUQATQA5Z4yPH/b+vWn7U+WNv lHyweP8At/Xq
vtT5YOV6YPH/AG/r1T2p8sHKPlg8f9v69HtT5YOUfLB4/wC39ej2p8sHKPlg 8f8Ab+vR7U+W
DlHyweP+39ej2p8sHKPlg8f9v69HtT5YOUfLB4/7f16Panywco+WDx/2/r1X 2p8sHKPlhqpC
/WrjvmzFHKbHRxSsmP7RFOJZAhzIoyzNITN1o6QMQBMMfYoNZzFOx9oorlAO 3YdTh0W3ncNo
36BIiOUlRHg+0K0Ck8Hmj91aSQR5KVhyt2C1dQ9lbq6X7iTW23CKsINKltRz C0V/XZdCH2/v
JPhjvSxVkqr5kxrRMrUp4D+qZCqsLbYJxuUVAYTbFF6m3clIJgRfMjKii4TH 4kl0zkHtKOvb
WyXeFf7Rbb3bnNUKUwh1B+6tIND5EVooeBBGPBvdW2rps7ct92remeXdbfKc YdHhqbUUkp80
qpqSeCkkEZHC/wBKmEDBowY//9Dv40YMNJnrLkFgTC+UMzWQSDD42pM/bF25 j92Mg4i2Cq0b
EImDt8VMyfctEQ+VVYoaQ9zX2Ntnb153BL/1ESOt0j9opSSlI9VqokepGHbs PaU7fm89sbNt
oPvLlNaYB46AtQC3D91tGpxX3UnHBLR5+yXiYveZry/Ulbvlu2TVrnJJYNlH C0hJu3zpYgdv
doupF0qYhA+EiZSFANgDXiH1Gvc3cm4JUqc8XJKnFuuq/addOpR+qoAHhwx7 zXqBbbHDsezb
GwGrJaYjbDSBwAQhKUj1KUJSCeJJUTmcOP44feHz/v1H/tcN7kjB44feHz/v 0e1wckYPHD7w
+f8Afo9rg5IweOH3h8+j2uDlDCJtGWscUcSBdsh0WmioCpkgtdvr9cFUEREF e685kWXeCmIC
AgXcQHs057ZsDeN6QXLPtS5Sm8vmajPOD5uGaUEZ+GeeGnc977Hsq1N3beFs jOg0KXJTKFAj
iNKlg1H0Ya1fmTxXbk7xTkhg8wBuIlQyjTHShdhAPiRbTKypd9+zcvxfJvp4 p7f+sStGnpvd
vm4f7Orx8/L66Uw03Ot/R9oOKV1EthCeNHgr4BIJV/m1xg/20+M5xMDfMFZf lAekFYpOXl0D
jsU26LiMjXaCxdjB2kMYNLTPa/1zfbDjfTidpP7RZSfgp0H7MJS+4jok2rSr qBFr6IfP5GTj
5DzX40lN0GypHFPvt0DBW/q3/XtXxAobfKOwa2R2q9eClSv+7uVQf+UjfZ++ zxgV3IdDkqSk
7/j1P/kpP2/uMsfVvzR43OkVnLfKMcq1bgJnLskJaxatygOwnXc+Q9yiQBHY RMYAAdUHat13
PDp1K4fiRvt/fZYD3IdDhx6gR/8AmpP/AFGMj+2RxwACmPlivpEOQFCqrN5p BEUzbbKCstGE
RKmID2CJgAQ1hV2vddEhSj05mUH3mK/UObU/VjMO4roiopA6gxc/uP0+s8mg +vCppXJTCeRr
dC0GjZMq9pu9iceGhalDvVHdifj1AXxKUOml48I7t38UZMGwlARA+wCOtGT2 49Y4IC52xZTL
NRVa1MhCdRAGpXMIHHhxrlSuWLv/ALhuixbW43vqOsgE6Utv6jTwSC0Kk+Hh 60zxjZU5H8cc
WDL1TKfJvGeNMntGL9A+LE1bHa7ZCTq7NMIaLyROUKt3WPxy4K8UE7hk0bzs so3DpKRmpuoT
oLYPaV7NyLdN5suXJOsEMxyUMaQfm5i3OU46KcAgtAHJSlA0xzT1D7t5U5t+ 29P4vsmyCDJf
CVv58OW2krbbP3ll004JSRXEIuZNnirIwxLmbCvKXBOeGuBMZ8m8kztwxZj2 IqkLhjIdtqlZ
isawafnTuftlslX6FfMmkvZHkg/Udh1qpJkEhE+nrLbbIhp/pxJ2ki12mcWm 0x1oq2/HQHC8
hZSAmqtXAZAqqFa8zym9fb6/cxvJ2/yJF6YWXOfzDzkPVToWFElXyn7BSmnL Cj4O8zIO4ceY
aw8hs/Y5LkcbZcYuRG22Kh0abTYMZgxIRN7CIDXWwdUYqkci6bVMiqZw3ETl OOuM+4HoDd4P
UMt9MunM87dehsrpFadfZS8dQcCVAL5fBJKCqlaqSADQd8dA+t1nuGw3l9SO oEJN+YmuoBku
tMvKZohTaiklJczKwFAE0ASokiplX/a54zCjIrpcgsOOkolE68kMfkWrSajV MpgTKBm8bJu3
Cq7lcxUkEkyHVcrmKkiU6hilGH4nb91fmLZS309uaErI+ZxlTaRUgVUpdAkC tc/Cp8MSnJ6+
dGorb7it/wAFfLSTRClLUqgrRASg6ieAArU5YrquXqLWbIsqLXG96xzx/wAf quVmsfcrygjd
smzZGyyZF5JtVW6UlUae2RN1EOi8LMrdIlMp4ZQRSL3p0o7GNiwYsa49Ur/7 260BVFZcKGWz
x0kt/vnKClVam0nOiSM8cUdSO8nd9ylSoHT21iBawSEvLQHJKx+181Wmq+CQ lah+3h2qlYcQ
3lu1b2j1PXjifdlFwZ5FZSqeMwIIJlN4VOJiq5X4gqSQdv8Ag+8OI9ojsGuo rd269t1pY0s7
CtzqzU1WyHTn6vcyg8vLHPU/r11suC6v73uiBlkh1TY+DWgYcyMxVkt6nJPs B8+3mRWMG2LI
yDE2QcG5RkjoKEKURWjbDTnk4kkmcQKAJugEx+0Cj2iOOZ2w9tm4VFpWxI7b yhQhlBZNPQs6
KH1xfD7iOtNn+f8AxzcD5cxfOHweCx9mGwd515mY0IoR4XGmWmrUx1FSWuoz dAsbxNPqN4Vp
YahNPaw2dONgImorBmSAw/F2DuET7s/p+dKLm245thy6W5xR+WjqXUA+FUva 1EemsGvjTLEl
7e72OqNveZF4EKexqFQ4yltRHjRTBaofUpVTyOHGrHqI4VGDrsvki7YyqTqY YKkn6nXbZe7Z
kbGttbKbSFSyFjqUxHTp9u0jyFOAzkMM1GHMTrVFshusHKW+eyK8WqIo7HvE i43dv9KO8yhr
XpFVFt0OaQr9ltSc+GuvHo3ZHeVaLncEx97WJu32xfCQy4t0Ir+iFtcvUU+a 0qy46KYmxWrr
XblBxtmqU9EWWvTDVN7FTcHINpOLkGqobkWavWaqqCxBEBAdjbgYBAdhAQ1x ZeNtXfb1wkWq
+W1+JcmjRbbqChYP0KAy8iMjxBx2dZbxZdx29i7WG6MTLa4KpcaWlaT6VFaE eKTQjgQMb3xw
+8Pn/fpL9rhW5IweOH3h8/79HtcHJGNNYWbexwcrBO+nuJNms1Ew9vdKmDqb rl39hm7gpTgP
vLraglyBMjTGv021g/SPEfWKjG3Afct02LOa/TaWFfSPEfWKjF+3/T88iHds wlkjjJaHpj2L
BVmPNVduuocVf4Guj16o+YtinMYToQNzau1DiGwELKIlANttesnatvEXfa1x 2u89qcgrDrNT
xYfqqg9EO6ifLmJGOBu/7p4zat7bb6mWtmluvsblvEDL3MZKQlR9XY6mwPMs rOOhHXVWPPvB
owY//9Hv40YMUMf9QFmVeo8WqJhOIdGSms85JYNnrdNboOvUaEDadkSHTL8Z 0zWp9Ce34RAD
b7+zXMfdNuUWnY0KyIco5cJNVCvFmOOYr/0hax3f2BbORd+qN93rLarCsNtU UkioEiVqaRn4
HkJk+vDHNxGlQio5hGNh6UI9o3ZpAG/aVBMqYm/acwCYf1jrypfQ5IedfX+m tRJ+s49HpKnJ
ch+U4DrcWVH6zXGb40P6X16xe2PljDyT5HB40P6X16PbHywck+RxG2zZgvlq utpxlhKMr5Za
jKxjK/ZAv/mCFQq0nNRbCbj4aNjmirF1ZpbyWSRdLmK5QbNSKEKJllOtInbP bz2hu9TLSzvT
eU9Uba66llppSQ6+ASkqUvPlI1AgAArVSvyihPDXcJ3Zf93N5mbK2VAbe3Aw dL8h5JLbKyAd
DTYI5iwCKqUdCT8uldDR7MKcI43JCh7HyFyzys5IRC6eyjeo1yC408bUVyD/ AJQxYz9xyJjW
EuTduAd2Lk8fKmVEPhE4COu7Ns9HOmWwEJj2LZELW2oHmutB50qHBRdc1LqP DMAeAGOCdz9X
epO+VrkX3eM51ldf3aXC20AeIDTZQ0kfQjPxriTlYxj6N2CnUkOT8d45YumD oqxaXgWxROfM
xzzsgbFj58mMMPo1uDcJHADGAsoqYggInW3AR1KrM66BtIisx2muAIbSDQeA oCfyYjNbEcrU
XVvOK8fmNPiSBj6ZH5/elJjQpVcXcWTtV0GpCKDlbIFUp0iGxepE7mJtdlNJ NgE+wKAEeKgD
/NIO2+toTrkV8x65qNPAKoB8T+bGNbCFJAaaUgepJOIK5G9Z7BMcZyhRMaY2 YKHMqQgxzW73
9g0WMmUiBW5K3VKrFyCqa+/X/rEExIAD1gPZrdVe5DxSgkuKpSpqo/R/Y4wK tql/MSaepp+f
EMLz6wGSrUdmwpsRBwviDERWbs8ZUGvPXC3WomJ2rm2ZGtL1NssAB8JmR1SD t29u2qidPNA2
kj6kg/VVR/JjKi1IoSsJJ8MyfyD8+G+xvzIv94yC0aZumjVPEa7C5tbk3rWR G1LXdy40yeUx
/GuLRUaREvKexkbj4Iki7SVVAhFC9oE331Z0m+iFJcjOI5gUKioCwnPgaAZ/ TWtMZmrfGbXr
eKTThkfzk1/yYiBZ8kZG80Qg18vu6c0ko6zv2iTLkfN2CvRcdGSFdCDaFsVp QVXeulWcymUi
6iBe+Epj9AgBhDXakXBhppqTPWHSipospHgRlmBkRXPjjd5TJqUMpIr+z54k FDXy64a4ZXnI
itjlH8hnXlzUYuqXFW6P3TxrUsDx8sJ3tYvcUopKKVWftZ3Pj2yKqLVdEvSY gCACMO7pvE+8
9QGtnuhblpFtVIXqPMSFqWlAXQ5A/KdKqVB+gYc8KMyzYFzEq/2jn6MsiE0J p9GefoMVm5Tm
LGFys8epWnFYI1sz3w8WiwXZw7CSbNk0lpdoC6wS01bpZy4UdPV3KiqiPeAA GEC9u8wzF9s2
409qQhFKk5lNcgfBKaDIAZ4wtIUpSiQQCa/WPynEgcCsPLeGnqBV1xArrkZx eG8gx667xwAL
xxbDMVGQfpPItRE4gnLPiukt90FO4EigGJvu17uESt3bDuWurKHnmiBT9Itl SQoEHKnEChBp
Qg4W2WBGtd3ad/TWhCkZ+Z/Sy8OII+OKs55rKIuEHMo7K+O/Q8Qg8I88aRVI qh0dgWERN1Jm
T2Eo9odmpNZdadSrkp0pBpSlKelMNt1lxlQDnE514g+tcL7FKzJ9JGprh7YI 8l4ctYCTPFTC
zJi8ZKqpnj2UlFolEswgE0VFQxVOoEgKChQ6i761rnIkRYb78dILiUk0PoM/ oy+PDFraELUA
sYee68hstxdnpVWsFmduaLjGUXYxFSRjmMTGt2bZZSCmWrlnFotUZB0LJuZM FjbgfYpwApt9
adiixmEpnRwUy1gFS9RKiDQ8a1oRxH1ZjF8psBTiEkacxUCniRieUdgrNtti 4+WbcReS12ql
obt39XnKlx5yvMw1hg5MhHMPIwk83rZWj5F81XTORZExinE3t9upAdukJTIQ 3cknM8EGg8v7
Dh64SEBRSFIpwyzGeEyrx5yRCM1HJ8GZrg3zJEnmUVBV8w5CZMXEurApupWn V2SRyVENjyYJ
oHByyTOCyxS9G46bj+5LEzJagP3ZtEtSglJpp1KP6oOVVeSa1PgMbSIst5tT qmxoAqfHh4/7
vDG2Rs+UcfRLaEnHufaLTo2QYpuXFuxBl+VXSZt3qKr1m5NaoyKZrFMUgkOk LtMRT6gAwDsO
lMXWQwNEW4BTY8M6/bjTVb2HFKK46CSOIArhtFcs1u1rqy8w7pZrA6XfN5Jp FRsdFzaCZ3Tl
JvEC2fuIqwSCEYkmn/WkVeKGTOQwlEBATKDG4ZYcTIU3rkprTgFfQFcQaeNf PGM2llSFMhxe
g+FTT4cMPFxfl8h0HMlLR4/z8hOs5q6RpMw4kTfvE40lNk3jVhYLOtV5kjFI klAtl/MEJKNJ
1902WBc/diZNTnjr/tfp3vfYN4uO6bemHc2GHFomKSOY0tAKkUWBUpUoaCg1 CtRFNVCJ06C7
y3zs7fm3YW1H3n2pcptlyLUlt9C1BKgpFaBSU1UlziggGumoPQ540P6X168a vbHyx7Vck+Rw
eND+l9ej2x8sHJPkcHjQ/pfXo9sfLByT5HEmPTHy2OCfUmxa5VdC0rOcWz7F 06Xve5RXcXJF
NCDKoAj3ZzBfYiLP29oAoOw7jrqnth3Oqxb82+y65SPJK4a88iHc2f8A0obG I07mdp/467bt
0tpb13KxqTNayqQI5Jdp4j/ZXHx9Qx3E69TseIeDRgx//9LrHN6wvp1EUMmb kQ2KchjFMA45
yzsBiiICHV/AnSOwh79OM7R3KBX+Tu0/zf8AjYRhuKxE0/mrXxP+THOb6tvL bFvK/lFiuexR
dG1qxLjLGyTNnNDHT8SRa4zE1MyU6BIydio2TTEjdCLTE4oAQ3c7gYfk497j Og3W7qHe4C9r
bKckWqPCDaVF+M1+8W4pTvyuvIUPlDY4Z0yx6I9qHcZ2/wDSbphuq3bs383G 3bc7kVKbEaW7
SO222hr940wtBzLxpqqNWYGK+gtsEIb+ctP2CVyA/S3DXL57Mu44f/LhR+iX CP8A7Rifk95/
bIr/AOZSB9MScP8A2bB/FkH/AL4afMv9xq3/AOzTuO/+mzn/AK1C/wC0Yu/+ 83tl/wDqW3/6
pO/7Nj0LXCGMUhZdqYxhACgALjuI9gB/gPaI6tX2b9xjaFOL6cLCEipJlwqA DiT/ALTi5P
Re: One Row Per Page [message #158819 is a reply to message #158559] |
Fri, 05 May 2006 12:14   |
Milton,
I must have misunderstood you earlier, I thought you said you wanted one row
per page in "PDF", which this does. If you want it in HTML (preview) as
well try setting the page interval to 1.
Jason
news:e3eppg$a5t$1@utils.eclipse.org...
> Jason,
> Milton
>> Milton,
>> Jason
>>>- JDK 1.5.0_05
>>>result.
>>>that
>>>and very capable.
>>>Milton
>>>>the
>>>>right place.
>>>>to
>>>>Jason
>>>>>repeatedly.
>>>>>reason.
>>>>>Thanks again.
>>>>>Milton
>>>>>>Here is an example.
>>>>>>Jason
>>>>>>>enhance
>>>>>>>the
>>>>>>>the
>>>>>>>reports framework?
>>>>>>>running
>>>>>>>the report"
>>>>>>>Thanks,
>>>>>>>Milton
> <!-- Written by Eclipse BIRT 2.0 -->
> <report xmlns="http://www.eclipse.org/birt/2005/design" version="3.2.1"
> id="1">
> <property name="createdBy">Eclipse BIRT Designer Version 2.0.1 Build
> <20060222-1204></property>
> <property name="units">in</property>
> <data-sources>
> <oda-data-source
> extensionID="org.eclipse.birt.report.data.oda.jdbc" name="Data Source"
> id="4">
> <property
> name="odaDriverClass">org.eclipse.birt.report.data.oda.sampledb.Driver </property>
> <property name="odaURL">jdbc:classicmodels:sampledb</property>
> <property name="odaUser">ClassicModels</property>
> </oda-data-source>
> </data-sources>
> <data-sets>
> <oda-data-set
> extensionID="org.eclipse.birt.report.data.oda.jdbc.JdbcSelectDataSet "
> name="Data Set" id="5">
> <structure name="cachedMetaData">
> <list-property name="resultSet">
> <structure>
> <property name="position">1</property>
> <property name="name">OFFICECODE</property>
> <property name="dataType">string</property>
> </structure>
> <structure>
> <property name="position">2</property>
> <property name="name">CITY</property>
> </structure>
> <structure>
> <property name="position">3</property>
> <property name="name">PHONE</property>
> </structure>
> <structure>
> <property name="position">4</property>
> <property name="name">ADDRESSLINE1</property>
> </structure>
> <structure>
> <property name="position">5</property>
> <property name="name">ADDRESSLINE2</property>
> </structure>
> <structure>
> <property name="position">6</property>
> <property name="name">STATE</property>
> </structure>
> <structure>
> <property name="position">7</property>
> <property name="name">COUNTRY</property>
> </structure>
> <structure>
> <property name="position">8</property>
> <property name="name">POSTALCODE</property>
> </structure>
> <structure>
> <property name="position">9</property>
> <property name="name">TERRITORY</property>
> </structure>
> </list-property>
> </structure>
> <property name="dataSource">Data Source</property>
> <property name="queryText">select *
> from offices</property>
> </oda-data-set>
> </data-sets>
> <styles>
> <style name="NewStyle" id="77">
> <property name="pageBreakAfter">always</property>
> <property name="pageBreakBefore">avoid</property>
> <property name="pageBreakInside">avoid</property>
> </style>
> </styles>
> <page-setup>
> <simple-master-page name="Simple MasterPage" id="2">
> <property name="type">custom</property>
> <property name="height">4in</property>
> <property name="width">8.5in</property>
> <property name="topMargin">0.25in</property>
> <property name="leftMargin">0.25in</property>
> <property name="bottomMargin">0.25in</property>
> <property name="rightMargin">0.25in</property>
> <page-footer>
> <text id="3">
> <property name="contentType">html</property>
> <text-property name="content"><![CDATA[<value-of>new
> Date()</value-of>]]></text-property>
> </text>
> </page-footer>
> </simple-master-page>
> </page-setup>
> <body>
> <table id="6">
> <property name="width">100%</property>
> <property name="dataSet">Data Set</property>
> <list-property name="boundDataColumns">
> <structure>
> <expression
> name="expression">dataSetRow["OFFICECODE"]</expression>
> </structure>
> <structure>
> <property name="name">COLUMN_1</property>
> <expression
> name="expression">row["OFFICECODE"]</expression>
> </structure>
> <structure>
> <expression
> name="expression">dataSetRow["CITY"]</expression>
> </structure>
> <structure>
> <property name="name">COLUMN_2</property>
> <expression name="expression">row["CITY"]</expression>
> </structure>
> </list-property>
> <column id="55"/>
> <detail>
> <row id="26">
> <property name="style">NewStyle</property>
> <cell id="27">
> <grid id="64">
> <structure>
> <expression
> name="expression">dataSetRow["PHONE"]</expression>
> <property
> </structure>
> </list-property>
> <column id="65"/>
> <column id="66"/>
> <row id="73">
> <cell id="74">
> <property name="colSpan">2</property>
> <property name="rowSpan">1</property>
> <image id="76">
> <property
> name="imageName">ClassicLogo.jpg</property>
> </image>
> </cell>
> </row>
> <row id="67">
> <cell id="68">
> <label id="9">
> <text-property
> name="text">OFFICECODE</text-property>
> </label>
> </cell>
> <cell id="69">
> <data id="78">
> <property
> name="resultSetColumn">PHONE</property>
> </data>
> </cell>
> </row>
> <row id="70">
> <cell id="71">
> <label id="11">
> <text-property
> name="text">CITY</text-property>
> </label>
> </cell>
> <cell id="72">
> <data id="30">
> <property
> name="resultSetColumn">COLUMN_2</property>
> </data>
> </cell>
> </row>
> </grid>
> </cell>
> </row>
> </detail>
> </table>
> </body>
> <list-property name="images">
> <structure>
> <property name="name">ClassicLogo.jpg</property>
> <property name="data">
> /9j/4AAQSkZJRgABAgEBLAEsAAD/4RVaRXhpZgAATU0AKgAAAAgABwESAAMA AAABAAEAAAEaAAUAAAAB
> AAAAYgEbAAUAAAABAAAAagEoAAMAAAABAAIAAAExAAIAAAAUAAAAcgEyAAIA AAAUAAAAhodpAAQAAAAB
> AAAAnAAAAMgAAAEsAAAAAQAAASwAAAABQWRvYmUgUGhvdG9zaG9wIDcuMAAy MDA1OjA0OjA1IDEyOjU1
> OjQ0AAAAAAOgAQADAAAAAf//AACgAgAEAAAAAQAAAOugAwAEAAAAAQAAAJ8A AAAAAAAABgEDAAMAAAAB
> AAYAAAEaAAUAAAABAAABFgEbAAUAAAABAAABHgEoAAMAAAABAAIAAAIBAAQA AAABAAABJgICAAQAAAAB
> AAAULAAAAAAAAABIAAAAAQAAAEgAAAAB/9j/4AAQSkZJRgABAgEASABIAAD/ 7QAMQWRvYmVfQ00AAv/u
> AA5BZG9iZQBkgAAAAAH/2wCEAAwICAgJCAwJCQwRCwoLERUPDAwPFRgTExUT ExgRDAwMDAwMEQwMDAwM
> DAwMDAwMDAwMDAwMDAwMDAwMDAwMDAwBDQsLDQ4NEA4OEBQODg4UFA4ODg4U EQwMDAwMEREMDAwMDAwR
> DAwMDAwMDAwMDAwMDAwMDAwMDAwMDAwMDAwMDP/AABEIAFcAgAMBIgACEQED EQH/3QAEAAj/xAE/AAAB
> BQEBAQEBAQAAAAAAAAADAAECBAUGBwgJCgsBAAEFAQEBAQEBAAAAAAAAAAEA AgMEBQYHCAkKCxAAAQQB
> AwIEAgUHBggFAwwzAQACEQMEIRIxBUFRYRMicYEyBhSRobFCIyQVUsFiMzRy gtFDByWSU/Dh8WNzNRai
> soMmRJNUZEXCo3Q2F9JV4mXys4TD03Xj80YnlKSFtJXE1OT0pbXF1eX1VmZ2 hpamtsbW5vY3R1dnd4eX
> p7fH1+f3EQACAgECBAQDBAUGBwcGBTUBAAIRAyExEgRBUWFxIhMFMoGRFKGx QiPBUtHwMyRi4XKCkkNT
> FWNzNPElBhaisoMHJjXC0kSTVKMXZEVVNnRl4vKzhMPTdePzRpSkhbSVxNTk 9KW1xdXl9VZmdoaWprbG
> 1ub2JzdHV2d3h5ent8f/2gAMAwEAAhEDEQA/APVUkkklKSSVHq3WcDpFAuzH kF5imlg3WWO/0dNQ9z3I
> EgAkmgOpXRjKchGIMpHYBvLO6l9YejdLdszcpldukUtl9uv0f0FW+33f1Fze X1LrXVSfWtd0vDPGLju/
> WHD/ALsZX+A/4qj/AIuxDxMbDwhGJSyknl4EvP8AXudutd/nrI5n43ixkxwx 90j9L5cf2t3HyIGuWVn9
> zH+3L/3kZuq/6332CcDpGVcOz8gsxmn+U02ue/8A8DQX/WD6zP1qwcOkeFmQ 55/8CrYq/qk6kpeqs2fx
> rnZbGER4R/azjBhG2KP+EZyP/T4f+a2GfWD6zs1twcO4eFeQ5h/8FY5FZ9cL 6hPUOkZVLf36CzJYPNzq
> ix3/AEFS9VIWkagwUofGudjvwSHjH9qjgwnfFH/BM4n/AKfD/wA16Hpv1h6L 1Q7MLLZZbr+hMss0+l+h
> t2W+3+qtFcLl4uFmj9bpZaezyIeP6tzNtv8A0kTE6n1vpJHo2O6rhDnGvd+s tH/dfJ/w/wDxd39StaXL
> fG8WQiOaPtSP6XzY/tYMnIg64pUf3Mn/AHOX5f8AHjje2SVHpPWen9XxzdhW SWGLanDbZW7/AEd1Z+g5
> XlrggiwbBaUoyhIxkDGQ3B3Ukkkitf/Q9J6v1OjpPTcjqN4Lq8du7a3lxJ2V 1t/4yxzWLD6H1n639Trx
> +pOwcNnTMp7dtIssGSKXO2/ad72+hZsZ+m9PbW+6v/RrZ690lnWekZPTXvNX 2hsNsAna9pFlT9v5zW2M
> ZuYsHF6n9YPq90vGxupdPp+yYDG1W5zMgEPYwenSMbG9IXuyLf0bGVvbs/4R SRMRjkTw8QNniNeikCMp
> TjEAnioREf30XTvr5fkdKtuux6z1L7TZi4uNU4w/YGP+0Wb/AHVU1+p+lcsH B6mcvruU3KeMjOHtblzp
> DI9bGx6/o0017/Zs/nP8IqXS8bPwRe/7Kw5GQXO9Q2t9kia69uv+E+mo19Ly sUYV9Lzbk0HdfW5zGs9/
> uyBSdrPpPc/6b371l85k5fOc+OWXGITjw8rwZIyj7nD7nu5jCX6uPuQhh/Wf 5xv4Y5ccMXBjlYN8yZR9
> c43w+3j/AHoRj6/S6OB1bLzL7XNpqGJU9zC0WH7QGtH8+6qNmzd+j9P6abp3 Vs7NpfkmmgY8WFoZYTZX
> sBNX2lhH+Hj/AAaqWYmTb1GjKZSzFsqeXX5LHgi1o+jX6Lffut+ja57UzMPJ d1AZTaGYY9N7cgNsBbc9
> 7XNaG117tlfqO9T9J/58VeeHkDHIQMMLxQlH1xye1OHufqvTl/XSz+j9bD9Z j/V/esH86iP3m4/PL1yB
> 9Mo8YPD6/l/V+3+5/Nz/AMil/wCclp6dj3txg/MyrHVVUNdDSWuFW7c7997m +3/wRaWNd1Hc5mbXSIEt
> sx3uc2Zg1FlzW2fyvU/m1h4/S8qvEw3ENGVhXPtFZcNrmucLNvqN3Na/2rUp yMmxz/Wx/s7ABsmxr3OP
> 53tqlrW/2lBz2LlRCf3WOExGTLxy4/138/8AqPYjLJ68X3fg/moZP8p7jLyw zGQ973AeGHCOH9X/ADf6
> z3Dw/P7v77MdVb+1z0xzQCWNdXZOu8jea3t/qfQQK/rDS5+duZ+hwwHVvadb AXej3+j+l/O/cVLM6dlX
> 25mTUWsynW1vxH7o9rGGs7nf4P6W7+woN6IWXXY9ZDcOzGbU2yRu9Rhrf6j6 /pe+1j3v/wCMU0OW+FcA
> M5ji9vCMgB2njlhnzc4f182LJ7eOH+r5hZI87xERj6eLJwGukxk9kS/2c4+r +/jbzOsdRbhs6lk41TcJ
> 8H063uN7a3nbXcdw9F276fpqTurZlvU/sOCyixjqm3sttc9oLHBjv8G1/wDp PaqmRT1O/p9XTW1Mqa1r
> GWZJsDmba/ouZU39M76P0NievEycPqIyMWr16asZuPUDY1h9rWN3Wb/+LR9n k/WSOXGcxzezAZI/d+Di
> xfdvcn7nB7387+n7nt/zqD7/AKaGX2+KHGeGXu8XDP3eEfPwfzf9Rlf1x9TP 2thMON1XEtGPe0GdwO/9
> HZA25NT3Ve3f/wCQW836/wDUm0Yfr42MMu3OGJkY7LHEip+z0sit2v579n+G rXLWdHy3dPva5zH5mXc2
> 20NdDWtaHjYx79u9/wClc9yNfhWEY92Lg1Y1mNkNtNNbme9tey1v0NjN2+v0 /wDSK9y2fksPDjxzh7Ry
> zjLin/Nw4I8PD7s/c9n3fchjn62LJj5nJE+7GZnHHD26j/X9cTwen+b/AEP/ AAt7f6xfWXqOF1rD6L05
> uJXdk1m52TnvcyqNxrZRX6Xudc97V0OM++zGqsyKhRe9jXW0h28MeRL6/VAb 6mx3t3rjepO6l9a+jVXD
> ouNl1X1vFP6yBbjX7nV+q60sZ+idX6XqUV+/fX6V3qLqOg4OX0/o2HhZt/2n Koqay27UguH7rne5zGfQ
> Y96vS4fbiQY3/VPFxf1mpUhOQkCK0qQ4eE/uv//R9VXC/WzqX23q7cNhnG6Z Dnjs7JeNP/Yal3/btq7P
> Py2YWFkZln0Met9rh4hgL4XltVljmepcd11xN1zvF9h9Sz/qlQ+JZTHEMY3y b/3XR+GYblLKf0PTH+9P
> 5j/i/wDTbXqJeoqz7mVsdZY4MYwbnOJgADuU+MM/MLhi44Y1o3GzJcWf+yuN XlZTf/QhmKsjFyuXKf1c
> DKtztEf4UvS6GXLixAHJIRvYby/xYtj1EvUQX0OpBOT1nplccsqrvvc3+S/0 7mta5ZmR1rp1EhvV67nD
> SKsQGf8APzWuVkfCeYPSI/wmufiPLd5H/Bdn1EvUXN2/WKxtAvqtZYzcWEOq 9N0gNIs2eq9raXb/AE/f
> b/OpWfWa/Hw2X2V1WXX7nUsIcGBjLPs3qWelZuv9Wz1PT2247KvR/wC1O9I/ Cs4q+EWa+ZX+kOXo1xH/
> AAXpPVG7ZI3kFwZPu2g7XP2/S2NcfpJeouJy+r3ZGJT1I01syMXJYwNrNoa9 kPy/ex9tn03t2banV1sr
> Z+jrUmfXLqORuZ6VNE6mysOL2tGtj62XWOqfZs+huRl8LyacEhIfpGXo4f8A pLYfEcZB44mJ/REfXf8A
> 0XtpeRMGDwUxc9v0gR8QuGxuqseC84uPmF7iJy67rbCQYYH2evb73NRj1PFr dtFB6daRB+zXvq1P53pZ
> GzYz+s+1Tf6G0/nhfbg9P+Nxf9wx/wClI3/NGv72v2cL2XqJeouWxfrNkCwN fsy6oALa9Luw3s323+rY
> 76f2f/tn0l0W/wA1R5jk8mCQE6N/LKJsFucvnx54kwvT5oyGsbdv6pdS+w9Y dgvMYvU5cwdm5LR7v/Ym
> pv8A25Wxd2vJbrLGs9WkxfQ5t1LvB9Z9Rn5F6ng5debhUZlf0MittrR4B4D4 Wr8NymWIwO+Pb+60vieG
> pQyj9P0y/vQ+U/4UP+g//9K71b649Q6pgXdPtxqqq7oDnsc4uhrg/bDm/n7d ixftD/3B95TlmpTiuSBx
> PdPycty+QgzxiRGm8v8AvkY+b5nHHhhkMY3xVUd/rFlXj5We1+PVWSHtIcWs utIB9v8ANYFV1/8AUdb9
> lo/7tKWT9X6K3Pq6x1N7XM97GZORi4LNxOvo01ftzJZc1rfzaarllV9Rzc+o 44qvyq9R9gw93oCCdbWY
> m9uVa72+tdm+tZ/57RcbE6zjG1+H0G5nqEOg1bQDDWOa0t+yu2+1Mhhhjv2w IRkb4Y3L/pL8mbJlo5Jc
> coirIjH/AKLoNwPqk012+g3Icw8V1ZmY8js/7T1V/T+kMs/O/WMK6j/gEc39 FrbFGBl8ghz8bpNQH7wn
> HwrlSH/OtrS8dD3tHi/0zP8AxbrrLESrN60zS/oF+nLmWjnwa2z/AMmn8Me5 Y7Pglfl4DXssZh5FbnuY
> 0EY3S7CSXf4O6zHo2/omW7P0Vn6X/i/0mb9Ysux+AWNa9jOo31WNuuFTdrKW 24wo2YjMehl9tlP6azF9
> PH9P9H/Oq+X22OYbOm9Sp22C4t9E3N3NaWN2/Zy/0mN3b3+nV+ls/SfpFXzr cV7GwzIfeXPrxsdlRa60
> WFuS5zm2s210e/Jp+0P99W+yymiyypR5I6Ajv/3Ml0Trq83TiPt6R1JlbHFu I3Hy37RIFm99Wx3u/wAJ
> iZN2R7PU9mN/XWM+MSx7KzvsLNpdztLh+laNvtc5v83uXUdQvycjGbj4nTrQ zDe+A2q0Gr1q2Vei844+
> lj2Mf+t5f+UM79F6vp4/6qsfLzPrC6urBu9enEqdDMdzX10gzO7YWs9vu/wn +DTYg9vNJpufVnquVj9K
> 6hgtseyq8se2L7a2AA7cyt2PjvY2xmVjbKrsi3+j1s/RfpV0tf1ubjOdj013 1NFIc3GozLqwy/e+y6r7
> TdVf67vsbqW+naz1abcb7LWub6QCcrLynCy2vaaMZrA3c8+o233faP8ABs2/ StZZ79jP5CuvwusYtZst
> qZS1xJByrd9ry4+obLGuDbP/AGVUghYBOi0mrdOz6wdMyHPHU8PJcG7nN9Rm BmD3e7V2RidPzNjnb9np
> ZtVyb7fhH0ziZLcqu0kBrm2VXVOjd6N9OVZlXPrd/gcr7Xk7/wCa9T9Gucv9 ST6r6yR+45zTr29rP+qU
> cfIx6ciu97rGOaPcA0OaWyHF3qAss9n/ABL0MvL451xw4gDsf/QPUvxZ8uMk 458JIrT/AL2T1H2h37n4
> /wCxb3RvrnkdK6bT08YbchtG4NsNpYdrnOe1uz0bPobtn0lhANcA5pDmu1aR qCD4JBmoTsfK8vjJMMYi
> Tp80/wDupLcvOczljw5MnFG+KuGA9X+DF//TCW6lQtqNlNlQO02McwOOoBc0 s3afuyjEalKFJbE4bb8l
> osbn1sLMet5NVbNrmmsNc6zl1bsfbsbXbT/O2XU/zKAM3NyMQ5VXRr7MUyG5 YbYW6SHCvIx6/T9sf6Zb
> ebgUZtRqtLmbmlhezR2130mf1d3u2qpnHEycvG/a+/DyKcdmGM2ql2TjPpp9 1FtWHRbjZPTsj2/pPszv
> S/0PpJkp5Bt6vovAid9HmRmMyX7a/VBdPsGyzktDdu9v0G+973vfZ/o/+EVy zHptZUKMXJpDZ9W8ZDLG
> PIEbq6qsfH9D3/20XrdeFnZtJxH32mqpjMjqF1Yptvva57nZLaJdZvfUaqfV t/TXbPWyPUu/S3Xen9Ib
> S+93V6LcvGtqc1zaSwOY8+m5uRRQXNr9X9F+m97HpGUzrqE0Bo5DcFheA2y4 unbAdrPO0wz2uRTj5e4b
> b8pzbA5jttjngg/Sbo17fSdt/SLQyaOh2V7RndYvLSC1lj6g0we5e5/pO2fR 9lyH9k6E1odRV1C3man5
> I01hvvrxq2bnfSTbl3l+KdPBqvZm2WetZmZj7YA9Q3Oc6PzW73N3NaoPtzKW QM/MBdo1oyCAT93/AFCv
> 24fSXU7KcbNdYYcd9roDh46e7936CBndKxX4rbMbHyaMtpB9R73FjBOsS299 v7zP6Js/4RIcXeX5K08E
> FvWH4u6hltjsgNDTkteX2ufPHquP6P8AqM9/5iqOGbjfrOVjZdU+2q6ysNZ6 hP53q1+k79H6v6P6fqK9
> 0xmHgvyac9z+n5NldQwsoNdt0MZNPqt221/amO/nWfZ7P8BZkY1V1vqWMe7p fT8bJe++nMzcyh2IzFxf
> UNTWOH6KzJ3sdU+2p3066n32fzfofrX6diOaQ04VCI3cbFqyL22Pa8CtvtO6 tljgDr9KwD0Xf8L+jRW4
> FR0YXPe4/wA447m/FrA3ba79xXuj9JddIf7QA02TqBtG1vs+j67v/A10dGJj 44/RMAd3edXH+0nVI6k/
> RaSBs1+m4r8bDZU6RH0Wnlo/NarQbqFOEgNQn2sf/9SRZTJ/Sn/M/wDMktlP +lP+Z/5kvKEk5Z9j6vsp
> /wBKf8z/AMyUXsx9p32+3vuZp/0nLypJJX2PqFTemb/0Nle/+Qxs/wDRcj7K v9Kf8z/zJeUJJK+x9X20
> /wCl/wCh/wCZJwyvtaf8z/zJeTpJK+x9Y2M/0rv8w/8Akk2yv/Sn/M/8yXlC SSvsfUMynpz69uZaAw8F
> 42/c4vVKvp/1f3SzKBgagFo089jg5eeJJK/l1fU6K8IVAY9o9IcbGyJ+Ieib Kf8ASn/M/wDMl5Qkkr7H
> 1fZT/pT/AJn/AJkkGUyP0p/zP/Ml5Qkkr7H/2f/tGgRQaG90b3Nob3AgMy4w ADhCSU0EJQAAAAAAEAAA
> AAAAAAAAAAAAAAAAAAA4QklNA+0AAAAAABABLAAAAAEAAQEsAAAAAQABOEJJ TQQmAAAAAAAOAAAAAAAA
> AAAAAD+AAAA4QklNBA0AAAAAAAQAAAAeOEJJTQQZAAAAAAAEAAAAHjhCSU0D 8wAAAAAACQAAAAAAAAAA
> AQA4QklNBAoAAAAAAAEAADhCSU0nEAAAAAAACgABAAAAAAAAAAE4QklNA/UA AAAAAEgAL2ZmAAEAbGZm
> AAYAAAAAAAEAL2ZmAAEAoZmaAAYAAAAAAAEAMgAAAAEAWgAAAAYAAAAAAAEA NQAAAAEALQAAAAYAAAAA
> AAE4QklNA/gAAAAAAHAAAP////////////////////////////8D6AAAAAD/ ////////////////////
> ////////A+gAAAAA/////////////////////////////wPoAAAAAP////// ////////////////////
> //8D6AAAOEJJTQQIAAAAAAAQAAAAAQAAAkAAAAJAAAAAADhCSU0EHgAAAAAA BAAAAAA4QklNBBoAAAAA
> A1cAAAAGAAAAAAAAAAAAAACfAAAA6wAAABEAQwBsAGEAcwBzAGkAYwBNAG8A ZABlAGwAcwAxADAAMAAl
> AAAAAQAAAAAAAAAAAAAAAAAAAAAAAAABAAAAAAAAAAAAAADrAAAAnwAAAAAA AAAAAAAAAAAAAAABAAAA
> AAAAAAAAAAAAAAAAAAAAABAAAAABAAAAAAAAbnVsbAAAAAIAAAAGYm91bmRz T2JqYwAAAAEAAAAAAABS
> Y3QxAAAABAAAAABUb3AgbG9uZwAAAAAAAAAATGVmdGxvbmcAAAAAAAAAAEJ0 b21sb25nAAAAnwAAAABS
> Z2h0bG9uZwAAAOsAAAAGc2xpY2VzVmxMcwAAAAFPYmpjAAAAAQAAAAAABXNs aWNlAAAAEgAAAAdzbGlj
> ZUlEbG9uZwAAAAAAAAAHZ3JvdXBJRGxvbmcAAAAAAAAABm9yaWdpbmVudW0A AAAMRVNsaWNlT3JpZ2lu
> AAAADWF1dG9HZW5lcmF0ZWQAAAAAVHlwZWVudW0AAAAKRVNsaWNlVHlwZQAA AABJbWcgAAAABmJvdW5k
> c09iamMAAAABAAAAAAAAUmN0MQAAAAQAAAAAVG9wIGxvbmcAAAAAAAAAAExl ZnRsb25nAAAAAAAAAABC
> dG9tbG9uZwAAAJ8AAAAAUmdodGxvbmcAAADrAAAAA3VybFRFWFQAAAABAAAA AAAAbnVsbFRFWFQAAAAB
> AAAAAAAATXNnZVRFWFQAAAABAAAAAAAGYWx0VGFnVEVYVAAAAAEAAAAAAA5j ZWxsVGV4dElzSFRNTGJv
> b2wBAAAACGNlbGxUZXh0VEVYVAAAAAEAAAAAAAlob3J6QWxpZ25lbnVtAAAA D0VTbGljZUhvcnpBbGln
> bgAAAAdkZWZhdWx0AAAACXZlcnRBbGlnbmVudW0AAAAPRVNsaWNlVmVydEFs aWduAAAAB2RlZmF1bHQA
> AAALYmdDb2xvclR5cGVlbnVtAAAAEUVTbGljZUJHQ29sb3JUeXBlAAAAAE5v bmUAAAAJdG9wT3V0c2V0
> bG9uZwAAAAAAAAAKbGVmdE91dHNldGxvbmcAAAAAAAAADGJvdHRvbU91dHNl dGxvbmcAAAAAAAAAC3Jp
> Z2h0T3V0c2V0bG9uZwAAAAAAOEJJTQQRAAAAAAABAQA4QklNBBQAAAAAAAQA AAAVOEJJTQQMAAAAABRI
> AAAAAQAAAIAAAABXAAABgAAAgoAAABQsABgAAf/Y/+AAEEpGSUYAAQIBAEgA SAAA/+0ADEFkb2JlX0NN
> AAL/7gAOQWRvYmUAZIAAAAAB/9sAhAAMCAgICQgMCQkMEQsKCxEVDwwMDxUY ExMVExMYEQwMDAwMDBEM
> DAwMDAwMDAwMDAwMDAwMDAwMDAwMDAwMDAwMAQ0LCw0ODRAODhAUDg4OFBQO Dg4OFBEMDAwMDBERDAwM
> DAwMEQwMDAwMDAwMDAwMDAwMDAwMDAwMDAwMDAwMDAz/wAARCABXAIADASIA AhEBAxEB/90ABAAI/8QB
> PwAAAQUBAQEBAQEAAAAAAAAAAwABAgQFBgcICQoLAQABBQEBAQEBAQAAAAAA AAABAAIDBAUGBwgJCgsQ
> AAEEAQMCBAIFBwYIBQMMMwEAAhEDBCESMQVBUWETInGBMgYUkaGxQiMkFVLB YjM0coLRQwclklPw4fFj
> czUWorKDJkSTVGRFwqN0NhfSVeJl8rOEw9N14/NGJ5SkhbSVxNTk9KW1xdXl 9VZmdoaWprbG1ub2N0dX
> Z3eHl6e3x9fn9xEAAgIBAgQEAwQFBgcHBgU1AQACEQMhMRIEQVFhcSITBTKB kRShsUIjwVLR8DMkYuFy
> gpJDUxVjczTxJQYWorKDByY1wtJEk1SjF2RFVTZ0ZeLys4TD03Xj80aUpIW0 lcTU5PSltcXV5fVWZnaG
> lqa2xtbm9ic3R1dnd4eXp7fH/9oADAMBAAIRAxEAPwD1VJJJJSkklR6t1nA6 RQLsx5BeYppYN1ljv9HT
> UPc9yBIAJJoDqV0YynIRiDKR2AbyzupfWHo3S3bM3KZXbpFLZfbr9H9BVvt9 39Rc3l9S611Un1rXdLwz
> xi47v1hw/wC7GV/gP+Ko/wCLsQ8TGw8IRiUspJ5eBLz/AF7nbrXf56yOZ+N4 sZMcMfdI/S+XH9rdx8iB
> rllZ/cx/ty/95Gbqv+t99gnA6RlXDs/ILMZp/lNNrnv/APA0F/1g+sz9asHD pHhZkOef/Aq2Kv6pOpKX
> qrNn8a52WxhEeEf2s4wYRtij/hGcj/0+H/mthn1g+s7NbcHDuHhXkOYf/BWO RWfXC+oT1DpGVS39+gsy
> WDzc6osd/wBBUvVSFpGoMFKHxrnY78Eh4x/ao4MJ3xR/wTOJ/wCnw/8ANeh6 b9Yei9UOzCy2WW6/oTLL
> NPpfobdlvt/qrRXC5eLhZo/W6WWns8iHj+rczbb/ANJExOp9b6SR6Njuq4Q5 xr3frLR/3Xyf8P8A8Xd/
> UrWly3xvFkIjmj7Uj+l82P7WDJyIOuKVH9zJ/wBzl+X/AB443tklR6T1np/V 8c3YVklhi2pw22Vu/wBH
> dWfoOV5a4IIsGwWlKMoSMZAxkNwd1JJJIrX/0PSer9To6T03I6jeC6vHbu2t 5cSdldbf+Msc1iw+h9Z+
> t/U68fqTsHDZ0zKe3bSLLBkilztv2ne9voWbGfpvT21vur/0a2evdJZ1npGT 017zV9obDbAJ2vaRZU/b
> +c1tjGbmLBxep/WD6vdLxsbqXT6fsmAxtVuczIBD2MHp0jGxvSF7si39Gxlb 27P+EUkTEY5E8PEDZ4jX
> opAjKU4xAJ4qERH99F076+X5HSrbrses9S+02YuLjVOMP2Bj/tFm/wB1VNfq fpXLBwepnL67lNynjIzh
> 7W5c6QyPWxsev6NNNe/2bP5z/CKl0vGz8EXv+ysORkFzvUNrfZImuvbr/hPp qNfS8rFGFfS825NB3X1u
> cxrPf7sgUnaz6T3P+m9+9ZfOZOXznPjllxiE48PK8GSMo+5w+57uYwl+rj7k IYf1n+cb+GOXHDFwY5WD
> fMmUfXON8Pt4/wB6EY+v0ujgdWy8y+1zaahiVPcwtFh+0BrR/PuqjZs3fo/T +mm6d1bOzaX5JpoGPFha
> GWE2V7ATV9pYR/h4/wAGqlmJk29RoymUsxbKnl1+Sx4ItaPo1+i337rfo2ue 1MzDyXdQGU2hmGPTe3ID
> bAW3Pe1zWhtde7ZX6jvU/Sf+fFXnh5AxyEDDC8UJR9ccntTh7n6r05f10s/o /Ww/WY/1f3rB/Ooj95uP
> zy9cgfTKPGDw+v5f1ft/ufzc/wDIpf8AnJaenY97cYPzMqx1VVDXQ0lrhVu3 O/fe5vt/8EWljXdR3OZm
> 10iBLbMd7nNmYNRZc1tn8r1P5tYeP0vKrxMNxDRlYVz7RWXDa5rnCzb6jdzW v9q1KcjJsc/1sf7OwAbJ
> sa9zj+d7apa1v9pQc9i5UQn91jhMRky8cuP9d/P/AKj2IyyevF934P5qGT/K e4y8sMxkPe9wHhhwjh/V
> /wA3+s9w8Pz+7++zHVW/tc9Mc0AljXV2TrvI3mt7f6n0ECv6w0ufnbmfocMB 1b2nWwF3o9/o/pfzv3FS
> zOnZV9uZk1FrMp1tb8R+6PaxhrO53+D+lu/sKDeiFl12PWQ3Dsxm1NskbvUY a3+o+v6XvtY97/8AjFND
> lvhXADOY4vbwjIAdp45YZ83OH9fNiye3jh/q+YWSPO8REY+niycBrpMZPZEv 9nOPq/v428zrHUW4bOpZ
> ONU3CfB9Ot7je2t5213HcPRdu+n6ak7q2Zb1P7DgsosY6pt7LbXPaCxwY7/B tf8A6T2qpkU9Tv6fV01t
> TKmtaxlmSbA5m2v6LmVN/TO+j9DYnrxMnD6iMjFq9emrGbj1A2NYfa1jd1m/ /i0fZ5P1kjlxnMc3swGS
> P3fg4sX3b3J+5we9/O/p+57f86g+/wCmhl9vihxnhl7vFwz93hHz8H83/UZX 9cfUz9rYTDjdVxLRj3tB
> ncDv/R2QNuTU91Xt3/8AkFvN+v8A1JtGH6+NjDLtzhiZGOyxxIqfs9LIrdr+ e/Z/hq1y1nR8t3T72ucx
> +Zl3NttDXQ1rWh42Me/bvf8ApXPcjX4VhGPdi4NWNZjZDbTTW5nvbXstb9DY zdvr9P8A0ivctn5LDw48
> c4e0cs4y4p/zcOCPDw+7P3PZ933IY5+tiyY+ZyRPuxmZxxw9uo/1/XE8Hp/m /wBD/wALe3+sX1l6jhda
> w+i9ObiV3ZNZudk573Mqjca2UV+l7nXPe1dDjPvsxqrMioUXvY11tIdvDHkS +v1QG+psd7d643qTupfW
> vo1Vw6LjZdV9bxT+sgW41+51fqutLGfonV+l6lFfv31+ld6i6joODl9P6Nh4 Wbf9pyqKmstu1ILh+653
> ucxn0GPer0uH24kGN/1TxcX9ZqVITkJAitKkOHhP7r//0fVVwv1s6l9t6u3D YZxumQ547OyXjT/2Gpd/
> 27auzz8tmFhZGZZ9DHrfa4eIYC+F5bVZY5nqXHddcTdc7xfYfUs/6pUPiWUx xDGN8m/910fhmG5Syn9D
> 0x/vT+Y/4v8A0216iXqKs+5lbHWWODGMG5ziYAA7lPjDPzC4YuOGNaNxsyXF n/srjV5WU3/0IZirIxcr
> lyn9XAyrc7RH+FL0uhly4sQBySEb2G8v8WLY9RL1EF9DqQTk9Z6ZXHLKq773 N/kv9O5rWuWZkda6dRIb
> 1eu5w0irEBn/AD81rlZHwnmD0iP8Jrn4jy3eR/wXZ9RL1Fzdv1isbQL6rWWM 3FhDqvTdIDSLNnqva2l2
> /wBP32/zqVn1mvx8Nl9ldVl1+51LCHBgYyz7N6lnpWbr/Vs9T09tuOyr0f8A tTvSPwrOKvhFmvmV/pDl
> 6NcR/wAF6T1Ru2SN5BcGT7toO1z9v0tjXH6SXqLicvq92RiU9SNNbMjFyWMD azaGvZD8v3sfbZ9N7dm2
> p1dbK2fo61Jn1y6jkbmelTROpsrDi9rRrY+tl1jqn2bPobkZfC8mnBISH6Rl 6OH/AKS2HxHGQeOJif0R
> H13/ANF7aXkTBg8FMXPb9IEfELhsbqrHgvOLj5he4icuu62wkGGB9nr2+9zU Y9Txa3bRQenWkQfs176t
> T+d6WRs2M/rPtU3+htP54X24PT/jcX/cMf8ApSN/zRr+9r9nC9l6iXqLlsX6 zZAsDX7MuqAC2vS7sN7N
> 9t/q2O+n9n/7Z9JdFv8ANUeY5PJgkBOjfyyibBbnL58eeJML0+aMhrG3b+qX UvsPWHYLzGL1OXMHZuS0
> e7/2Jqb/ANuVsXdryW6yxrPVpMX0ObdS7wfWfUZ+Rep4OXXm4VGZX9DIrba0 eAeA+Fq/DcpliMDvj2/u
> tL4nhqUMo/T9Mv70PlP+FD/oP//Su9W+uPUOqYF3T7caqqu6A57HOLoa4P2w 5v5+3YsX7Q/9wfeU5ZqU
> 4rkgcT3T8nLcvkIM8YkRpvL/AL5GPm+Zxx4YZDGN8VVHf6xZV4+Vntfj1Vkh 7SHFrLrSAfb/ADWBVdf/
> AFHW/ZaP+7Slk/V+itz6usdTe1zPexmTkYuCzcTr6NNX7cyWXNa382mq5ZVf Uc3PqOOKr8qvUfYMPd6A
> gnW1mJvblWu9vrXZvrWf+e0XGxOs4xtfh9BuZ6hDoNW0Aw1jmtLfsrtvtTIY YY79sCEZG+GNy/6S/Jmy
> ZaOSXHKIqyIx/wCi6DcD6pNNdvoNyHMPFdWZmPI7P+09Vf0/pDLPzv1jCuo/ 4BHN/Ra2xRgZfIIc/G6T
> UB+8Jx8K5Uh/zra0vHQ97R4v9Mz/AMW66yxEqzetM0v6Bfpy5lo58Gts/wDJ p/DHuWOz4JX5eA17LGYe
> RW57mNBGN0uwkl3+Dusx6Nv6Jluz9FZ+l/4v9Jm/WLLsfgFjWvYzqN9Vjbrh U3ayltuMKNmIzHoZfbZT
> +msxfTx/T/R/zqvl9tjmGzpvUqdtguLfRNzdzWljdv2cv9Jjd29/p1fpbP0n 6RV863FexsMyH3lz68bH
> ZUWutFhbkuc5trNtdHvyaftD/fVvsspossqUeSOgI7/9zJdE66vN04j7ekdS ZWxxbiNx8t+0SBZvfVsd
> 7v8ACYmTdkez1PZjf11jPjEseys77CzaXc7S4fpWjb7XOb/N7l1HUL8nIxm4 +J060Mw3vgNqtBq9atlX
> ovOOPpY9jH/reX/lDO/Rer6eP+qrHy8z6wurqwbvXpxKnQzHc19dIMzu2FrP b7v8J/g02IPbzSabn1Z6
> rlY/SuoYLbHsqvLHti+2tgAO3Mrdj472NsZlY2yq7It/o9bP0X6VdLX9bm4z nY9Nd9TRSHNxqMy6sMv3
> vsuq+03VX+u77G6lvp2s9Wm3G+y1rm+kAnKy8pwstr2mjGawN3PPqNt932j/ AAbNv0rWWe/Yz+Qrr8Lr
> GLWbLamUtcSQcq3fa8uPqGyxrg2z/wBlVIIWATotJq3Ts+sHTMhzx1PDyXBu 5zfUZgZg93u1dkYnT8zY
> 52/Z6WbVcm+34R9M4mS3KrtJAa5tlV1To3ejfTlWZVz63f4HK+15O/8AmvU/ RrnL/Uk+q+skfuOc069v
> az/qlHHyMenIrve6xjmj3ANDmlshxd6gLLPZ/wAS9DLy+OdccOIA7H/0D1L8 WfLjJOOfCSK0/wC9k9R9
> od+5+P8AsW90b655HSum09PGG3IbRuDbDaWHa5zntbs9Gz6G7Z9JYQDXAOaQ 5rtWkagg+CQZqE7HyvL4
> yTDGIk6fNP8A7qS3LznM5Y8OTJxRvirhgPV/gxf/0wlupULajZTZUDtNjHMD jqAXNLN2n7soxGpShSWx
> OG2/JaLG59bCzHreTVWza5prDXOs5dW7H27G120/ztl1P8ygDNzcjEOVV0a+ zFMhuWG2FukhwryMev0/
> bH+mW3m4FGbUarS5m5pYXs0dtd9Jn9Xd7tqqZxxMnLxv2vvw8inHZhjNqpdk 4z6afdRbVh0W42T07I9v
> 6T7M70v9D6SZKeQber6LwInfR5kZjMl+2v1QXT7Bss5LQ3bvb9Bvve9732f6 P/hFcsx6bWVCjFyaQ2fV
> vGQyxjyBG6uqrHx/Q9/9tF63XhZ2bScR99pqqYzI6hdWKbb72ue52S2iXWb3 1Gqn1bf012z1sj1Lv0t1
> 3p/SG0vvd1ei3LxranNc2ksDmPPpubkUUFza/V/Rfpvex6RlM66hNAaOQ3BY XgNsuLp2wHazztMM9rkU
> 4+XuG2/Kc2wOY7bY54IP0m6Ne30nbf0i0Mmjodle0Z3WLy0gtZY+oNMHuXuf 6Ttn0fZch/ZOhNaHUVdQ
> t5mp+SNNYb768atm530k25d5finTwar2ZtlnrWZmY+2APUNznOj81u9zdzWq D7cylkDPzAXaNaMggE/d
> /wBQr9uH0l1OynGzXWGHHfa6A4eOnu/d+ggZ3SsV+K2zGx8mjLaQfUe9xYwT rEtvfb+8z+ibP+ESHF3l
> +StPBBb1h+LuoZbY7IDQ05LXl9rnzx6rj+j/AKjPf+Yqjhm436zlY2XVPtqu srDWeoT+d6tfpO/R+r+j
> +n6ivdMZh4L8mnPc/p+TZXUMLKDXbdDGTT6rdttf2pjv51n2ez/AWZGNVdb6 ljHu6X0/GyXvvpzM3Mod
> iMxcX1DU1jh+isyd7HVPtqd9Oup99n836H61+nYjmkNOFQiN3Gxasi9tj2vA rb7TurZY4A6/SsA9F3/C
> /o0VuBUdGFz3uP8AOOO5vxawN22u/cV7o/SXXSH+0ANNk6gbRtb7Po+u7/wN dHRiY+OP0TAHd3nVx/tJ
> 1SOpP0WkgbNfpuK/Gw2VOkR9Fp5aPzWq0G6hThIDUJ9rH//UkWUyf0p/zP8A zJLZT/pT/mf+ZLyhJOWf
> Y+r7Kf8ASn/M/wDMlF7Mfad9vt77maf9Jy8qSSV9j6hU3pm/9DZXv/kMbP8A 0XI+yr/Sn/M/8yXlCSSv
> sfV9tP8Apf8Aof8AmScMr7Wn/M/8yXk6SSvsfWNjP9K7/MP/AJJNsr/0p/zP /Ml5Qkkr7H1DMp6c+vbm
> WgMPBeNv3OL1Sr6f9X90sygYGoBaNPPY4OXniSSv5dX1OivCFQGPaPSHGxsi fiHomyn/AEp/zP8AzJeU
> JJK+x9X2U/6U/wCZ/wCZJBlMj9Kf8z/zJeUJJK+x/9k4QklNBCEAAAAAAFUA AAABAQAAAA8AQQBkAG8A
> YgBlACAAUABoAG8AdABvAHMAaABvAHAAAAATAEEAZABvAGIAZQAgAFAAaABv AHQAbwBzAGgAbwBwACAA
> NwAuADAAAAABADhCSU0EBgAAAAAABwAIAAEAAQEA/+ESSGh0dHA6Ly9ucy5h ZG9iZS5jb20veGFwLzEu
> MC8APD94cGFja2V0IGJlZ2luPSfvu78nIGlkPSdXNU0wTXBDZWhpSHpyZVN6 TlRjemtjOWQnPz4KPD9h
> ZG9iZS14YXAtZmlsdGVycyBlc2M9IkNSIj8+Cjx4OnhhcG1ldGEgeG1sbnM6 eD0nYWRvYmU6bnM6bWV0
> YS8nIHg6eGFwdGs9J1hNUCB0b29sa2l0IDIuOC4yLTMzLCBmcmFtZXdvcmsg MS41Jz4KPHJkZjpSREYg
> eG1sbnM6cmRmPSdodHRwOi8vd3d3LnczLm9yZy8xOTk5LzAyLzIyLXJkZi1z eW50YXgtbnMjJyB4bWxu
> czppWD0naHR0cDovL25zLmFkb2JlLmNvbS9pWC8xLjAvJz4KCiA8cmRmOkRl c2NyaXB0aW9uIGFib3V0
> PSd1dWlkOmFmOGZjOTQ1LWE2MGItMTFkOS1hZTQ1LWM1YmU1ODAwZGU3YScK ICB4bWxuczp4YXBNTT0n
> aHR0cDovL25zLmFkb2JlLmNvbS94YXAvMS4wL21tLyc+CiAgPHhhcE1NOkRv Y3VtZW50SUQ+YWRvYmU6
> ZG9jaWQ6cGhvdG9zaG9wOjYyNDAwMzQ4LWE2MGEtMTFkOS1hZTQ1LWM1YmU1 ODAwZGU3YTwveGFwTU06
> RG9jdW1lbnRJRD4KIDwvcmRmOkRlc2NyaXB0aW9uPgoKPC9yZGY6UkRGPgo8 L3g6eGFwbWV0YT4KICAg
> ICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAg ICAgICAgICAgICAgICAg
> ICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgIAogICAgICAg ICAgICAgICAgICAgICAg
> ICAgICAgICAgICAgICAgICAgCiAgICAgICAgICAgICAgICAgICAgICAgICAg ICAgICAgICAgICAgICAg
> ICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAg ICAgICAgICAgICAgICAK
> ICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgIAogICAg ICAgICAgICAgICAgICAg
> ICAgICAgICAgICAgICAgICAgICAgCiAgICAgICAgICAgICAgICAgICAgICAg ICAgICAgICAgICAgICAg
> ICAKICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAg ICAgICAgICAgICAgICAg
> ICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgIAog ICAgICAgICAgICAgICAg
> ICAgICAgICAgICAgICAgICAgICAgICAgCiAgICAgICAgICAgICAgICAgICAg ICAgICAgICAgICAgICAg
> ICAgICAKICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAg ICAgICAgICAgICAgICAg
> ICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAg IAogICAgICAgICAgICAg
> ICAgICAgICAgICAgICAgICAgICAgICAgICAgCiAgICAgICAgICAgICAgICAg ICAgICAgICAgICAgICAg
> ICAgICAgICAKICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAg ICAgICAgICAgICAgICAg
> ICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAg ICAgIAogICAgICAgICAg
> ICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgCiAgICAgICAgICAgICAg ICAgICAgICAgICAgICAg
> ICAgICAgICAgICAKICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAg ICAgICAgICAgICAgICAg
> ICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAg ICAgICAgIAogICAgICAg
> ICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgCiAgICAgICAgICAg ICAgICAgICAgICAgICAg
> ICAgICAgICAgICAgICAKICAgICAgICAgICAgICAgICAgICAgICAgICAgICAg ICAgICAgICAgICAgICAg
> ICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAg ICAgICAgICAgIAogICAg
> ICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgCiAgICAgICAg ICAgICAgICAgICAgICAg
> ICAgICAgICAgICAgICAgICAKICAgICAgICAgICAgICAgICAgICAgICAgICAg ICAgICAgICAgICAgICAg
> ICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAg ICAgICAgICAgICAgIAog
> ICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgCiAgICAg ICAgICAgICAgICAgICAg
> ICAgICAgICAgICAgICAgICAgICAKICAgICAgICAgICAgICAgICAgICAgICAg ICAgICAgICAgICAgICAg
> IAogICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAg ICAgICAgICAgICAgICAg
> ICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgCiAg ICAgICAgICAgICAgICAg
> ICAgICAgICAgICAgICAgICAgICAgICAKICAgICAgICAgICAgICAgICAgICAg ICAgICAgICAgICAgICAg
> ICAgIAogICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAg ICAgICAgICAgICAgICAg
> ICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAg CiAgICAgICAgICAgICAg
> ICAgICAgICAgICAgICAgICAgICAgICAgICAKICAgICAgICAgICAgICAgICAg ICAgICAgICAgICAgICAg
> ICAgICAgIAogICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAg ICAgICAgICAgICAgICAg
> ICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAg ICAgCiAgICAgICAgICAg
> ICAgICAgICAgICAgICAgICAgICAgICAgICAgICAKICAgICAgICAgICAgICAg ICAgICAgICAgICAgICAg
> ICAgICAgICAgIAogICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAg ICAgICAgICAgICAgICAg
> ICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAg ICAgICAgCiAgICAgICAg
> ICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAKICAgICAgICAgICAg ICAgICAgICAgICAgICAg
> ICAgICAgICAgICAgIAogICAgICAgICAgICAgICAgICAgICAgICAgICAgICAg ICAgICAgICAgICAgICAg
> ICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAg ICAgICAgICAgCiAgICAg
> ICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAKICAgICAgICAg ICAgICAgICAgICAgICAg
> ICAgICAgICAgICAgICAgIAogICAgICAgICAgICAgICAgICAgICAgICAgICAg ICAgICAgICAgICAgICAg
> ICAgICAgICAgICAgCjw/eHBhY2tldCBlbmQ9J3cnPz7/7gAOQWRvYmUAZEAA AAAB/9sAhAABAQEBAQEB
> AQEBAQEBAQEBAQEBAQEBAQEBAQEBAQEBAQEBAQEBAQEBAQEBAgICAgICAgIC AgIDAwMDAwMDAwMDAQEB
> AQEBAQEBAQECAgECAgMDAwMDAwMDAwMDAwMDAwMDAwMDAwMDAwMDAwMDAwMD AwMDAwMDAwMDAwMDAwMD
> AwP/wAARCACfAOsDAREAAhEBAxEB/90ABAAe/8QA5QAAAQQDAQEBAAAAAAAA AAAAAAYHCAkEBQoBAwIB
> AAEDBQEBAAAAAAAAAAAAAAAFBgcBAgMECAkKEAAABgEDAQUDCAUFDQMNAAAB AgMEBQYHABEIEiETFBUJ
> MVEiQZGhsWLTlVbwYXHhFtEyUiMYQqIzYyREdCVFVWUXClM0hXKCkrJDs2SU NcU2JxkRAAEDAgQEBAIF
> CQMFCgwHAAECAwQRBQAhEgYxEwcIQVFhFJEicYGhYlOxwTJCUiNUFQnwchbR gpIzJOGywtJDk7PT1Bfx
> omNzo5TENVVHVxiDwzR0tCVG/9oADAMBAAIRAxEAPwDv40YMGjBg0YMGjBg0 YMGjBg0YMGjBg0YMGjBg
> 0YMGjBhsrpmrDmOAUHIWWMa0XuS9SoXC81itGIUA33MSZlGZg7P1aR7huGwW mv8ANb5DjU/Febb/AN+o
> Yc1m2XvHcen/AA/tS5Tq8Pbxnnq/82hWIvWL1OuANXFUsnyrxM4MiIgcICZc 2wdwHYej+FWMz3v/AJu+
> mbL6xdMIVQ9vaCafsLLv/RheJPt3bL19ugSY3Su7JB/FbSx8eepun14bNb1l PTXQUMmfkwxMYo7CKOMM
> 1uEx/wDJVQxsokcP2COkdXX7pGkkHd6a+keWftEemHKjs47kVpCh01XQ+c22 g/AzAcKSE9Wn067AcqbD
> lFTW5jewZuCvlZIHs/nKWSpxSZPb8ohrbjdcelMogNbzjg/fQ83/ANI0nCdN 7Te4i3pKn+mExQH4bsV4
> /Bl9ZxIamcxeJ+QxTJSuSeD7EuqIAmyj8n04ZIRN/NKMYrLpSBTCPyCkA6dV v39si60Fu3dbXVHwTIa1
> f6JVq+zEe3no91X29qN66b3yO2OKlQpGj/TDZR/42JENXbV83SdsnLd41XIC iDlqsm4brJmDcp0lkjHT
> UIYPYICIDp1oWhxKVtrCkHgQag/QRiPHWnWHFtPtKQ6k0KVAgg+RBzGMjV2M eDRgwaMGDRgwaMGDRgwa
> MGDRgwaMGDRgwaMGDRgx/9Dv40YMGjBg0YMGjBg0YMGjBg0YMGjBg0YMV3cm fVN4X8WjSUVcsps7heI4
> FCKY8xiRK52ZN0QB3Zybhm4RrdcclMAAYkk/aKAA9hR9moq3f1n6f7NLsede RIuaf+QjDnOV8lEHloPo
> 4tJ9MdDdNO1vrN1REaVZtrLh2NylJc0mOyUn9ZAUC88PIstOA+YxUBcvWg5q 5+Wcx3Dvi81ptcWU7ptf
> r6ktZ3oJewHabyQPWKHGqCI7ikYJYC7bAY2uMupvfnZtsc5hiXbbWRwDqzKl n6GGhRJ9FIWPXHYVj7K+
> jmxkNSOrvUtybcQKmLFIYRX9kpTzpKx94civkMRusWMvUb5BidfkLzRsEBGP DmVc1OmTcv5cUFd+pE9f
> p38EU34Cj0h2LAAfKPbrg/ff9Qa6XdTzUJ+93FJJ/TdTBjn/APCa1Ej6WwcS pa7p28bAARsHo5GekoFE
> vyG2yvLx5sj3EjP6U/RjUQPpi4MbKeKuN3yddXypu8dKmkoqvouFTDuoc4NI 56/ETDv2i5Eff265qu/d
> t1HnLcVbLPa4gJ4qS7IX9aluJST/AJmFSb3EbyWnlWmz26GwMkjQt0geH6Sk p/8AEw8MXwI4jRZSgOMV
> pYxQAO9mrhbXpzbfKciUw1bmEfl/q9MSZ3E9aJZJG7Usg+DUaMkfUS2pX24a 0nrZ1Qkkn/ESWh5NsMJ+
> 0tk/bhUE4ZcSyF6AwdUTBtt1KOJ9Q/7es8yJgH9ekhXXLrMo1PUGaPoSyB8O VhNPVrqeTX/GMkfQGh/+
> XjVP+DnEZ+UxT4djGgj7DRtgt0eYo+8vh54pdw/WAhrbj9futEYgjfDq/wC+ zGX/AL5nGyz1j6oskEbq
> cV/fbYV+VvDXWD01eMMsU4xAZCqixt+k8XbQkUCD8mzafjZPcge7rAR94ad1 t7purMIpE02yYgfiRtBP
> +cytv8n1YccHuC6ixSn3RgSUj9tnST9ba0fkwiIvhBnLDrkJPjPzAyBQ3Dc/ fNo5d/ZKqic4Dv3a7ymz
> IslyHHsMCrAxBD2gPs1Nmze+W/2NxozLJNhKBzXb5i0j6eU5pB+guGuFOb1b 2RvBsxuo/Sa3z21ChVoZ
> fP0hMhvUPSjoI8CMPnVee/q78Y+7DIVbrPJ2ksRMLh4rEs5yWKyKG5hTmqOW u2tFYoBuCsgwfbfKA/J2
> v02/qGxJy2IsndsZ5ZNOTcmvbO/Ql9GltR8ipbn0Yju8dvXaf1J1nb86Ttq8 r4JS4ptvV6tSeayR91px
> r0piwjjv69fFjJr1tWM4V+18cbeY6TVytYE1bTRyPDAJDpK2CKj2k5D/ANcU dxfxTdBIo/Gt2COu6Nn9
> z2xtwJYRe2nLa84BRwkPxlV8nmxUD1U2EgcVY506h9hvVLbLLty2TPi7jtAB UA0QxJ0+YZWtTbmXg0+t
> RPBGLqqddqdkOvR9toVqrt0q8skC0bYqtMx89CvkxKU3U2koxw5aKiUDB1AB 9yj2CADromBcYF1itTrZ
> NakQliqXG1pWg/QpJIPxxxbeLLeNvXCRab9apEK6NGi2n21tOJP3kLCVD0yz 8MKfW5hMwaMGDRgwaMGD
> RgwaMGDRgwaMGDRgx//R7+NGDBowYNGDBowYNGDBowYNGDFfnND1KONfCWMV aXywjbcmrtu+hsR01do+
> trgVCdTZzPqGU8DUIhUTFEHD4xVFSCIt0XAlEuov6gdXNo9PGS3cpXPvJTVE VohTp8ivwaT95dCRmlKq
> UxP/AEZ7bepPWuSl6xW/2m2Uqo5PkBSWBQ5paFNUhwZ/K0ClJycW2CDjnuyl yj9RH1C/EtHc1/ZX46S5
> t0q7XTyMZKz0Qbo6UpF6U7G53PxKYbnBU8ZCre0EOwNeWfXbvrdWZtniXErV Up9lAXRI9JUzOv3kIrXx
> aGPQ/aPSPt+6A8p9qD/ijqC1xeeCFoac80I+aPHoeGkPSE8OZjOxNw1wDinw j/8AhsL7Z2wkV/iS9FRl
> hI5KHatHwPQWCjwA3aX+pVVL/wBoI9uvNjeXW/qPvDnxzczb7Uuo5ESrdU+S 3v8AXL9fmSk/sjG3ufqx
> vjc3NY9/7K3Ky5UeqMvJTleYr1+ZIP7OJdllCppppJ9KaKRQIkimUqaSRC9h SJJk2ImQoewAAADULmEV
> KUtSSVk1JOZJ8yTmT6nEWmMVFSlAlROZOZP0nxx75r9r9Pn1T2X3MHtfu4PN ftfp8+j2X3MHtfu4PNft
> fp8+j2X3MHtfu4PNftfp8+j2X3MHtfu4PNftfp8+j2X3MHtfu4PNftfp8+j2 X3MHtfu4PNftfp8+j2X3
> MHtfu49CWEBAQOICHaAh2CH7BAdBgg5FGWKe18NGGiydhzEWY2pm+RKRCzjk SGIjOEQ8tsjPqDYDtLBH
> mbyZBL8hTqHT95R089p713psh4ObZvz8dqtS0TrYV/eZXVs/SAFeRGHTt3de 6dqOhdhu7zLdc2662lfS
> 0qqPrAB9cQ9hMFcnOIdlXyNwhzdZWOyxXMljuYetEyzTdE5FQYv2D4h6VdUu lMCFI/aN1yh/g1Ovt121
> 0f7z7vtqcwLu67aZhICn4+pyI5/5+MrUUg+YDoHhp44k657r6adW7ajb3WjZ UZ0aaIlISqrZOWpC00kR
> znUltakn9ZNMsWy8QfXMpFtmWmJOadVDj9lFsolGK3Pwki0x1JPgKVMDT7CR FeYoKzpUNwVVO8jB3E5n
> KBNi69belvdPtjd0WC3uV6PHW8By5jKtcN31UQVFkk8alSB+spHDHIHV/scv lnhvbs6M3Q3/AGwoFYja
> kGYhPH90pFG5QSPBIbe8A24anF+0dJR0wwZSsQ/ZSkXJNUH0dJRzpB8wfsnS ZVmzxk8bHVbumrhE4GIo
> QxiHKICAiA66uaeakNNvsOpWytIKVJIKVA5ggjIgjMEZHHA8iNIhyHokthbU ptRStC0lK0qSaFKkqAKV
> A5EEAg5HGbrJjDg0YMGjBg0YMGjBg0YMGjBj/9Lv40YMGjBg0YMGjBg0YMYr 58yjGTySknjWPjo9q4fP
> 375wk0ZMWTRI67p48dLnTQbNWyCZjqKHMUhCFEREADVjjjbLbjzziUtJSSpR IAAAqSScgAMyTkBjKww9
> JeZjRmVOSHFBKUpBUpSlGiUpSKkqJIAABJJoMc2HNf1hrtk20SfHD070TzEm YXMfbuQRUieXR7bqM2dq
> UFV4kZkwj0R6gGfdAYVB/wC4ImN3TkeGOvXdrZtpW6bF2zdEMRE1QubTUtxX 4cJvitR/FpTxSAKOY9Je
> iXZ5Z9u22L1E7g1BqN8q49qqdSjxT7rSdSlHL/ZUEU/5dYGpoQKw5xXqlGlV L/kqUWy5lqSdGlpK0WhR
> zLMmUu4OK7p5Hoyp3LmSkjrmExpB8Kjk5viKCQiOvGLqX1v3bvx+ZGhSHoVm dUrX85MiRXiqQ9XV83Eo
> QaZ/MpeOjN1dSbhd4iLFt2Mm1bWaRy0MsgIKmxklKiiiUIAyDTdEAZEqxL8Z UTDuJxER9oiYwjqCBBpk
> BliLBHSMhwx55n9r6R0eyPlg5AweZ/a+kdHsj5YOQMHmf2vpHR7I+WDkDB5n 9r6R0eyPlg5AweZ/a+kd
> Hsj5YOQMHmf2vpHR7I+WDkDB5n9r6R0eyPlg5AweZ/a+kdHsj5YOQMHmf2vp HR7I+WDkDB5n9r6R0eyP
> lg5AweZ/a+kdHsj5YOQMHmf2vpHR7I+WDkDDSZbxFjbNkR5Ze4NF07QSMnFW NiJWdlhDCHwmj5QqZlDI
> lN2i3WBVuf5SfLp5bO3hujYkz3e37gUMqNXGV/Mw7/fbrSvktOlY8FYdG191 X/Z8r3NknFLSjVbSvmac
> /vI4V+8mih4HDO4F5U8r/S1nmrDxjvO3E17KE8dV5Bw4IWuouVdlVYNyr41X HthEDCbpKCsK/U36yAqY
> Dp+oXbh3eyI6mLVrJRxdtzy65frOQnT8Sin99v8AXC51C6SdK+52A7I5SLH1 VQ0dD6AP3pAyDqRpEtrw
> qdMhofoq0ApV1h8Y+VGF+XWNmWTsK2lGdiTmSazsK6BNnaKdMnSBVSBtcL3q q0XIpl3Ehtzt3KYd4gqq
> kIHH1f2dvXb2+rQ3edvTQ4xkFoOTjS6V0OoqSlXlxSoZpKhnjyc6mdLN59JN yPbZ3pa1MSxVTTiaqYkN
> 1oHWHKALQfEZLQflcSlVRiRWnXiO8GjBg0YMGjBg0YMGjBj/0+/jRgxAv1Bf UExJ6euImeRchsn1qtNq
> fuoTG2NoV42YzNzmWTYjp+oo+ckXThq5CpLIi/fii48OLhEhUlVVUyGemy9l zN4TH0IfDFtYCS88U6tO
> quhCEVTrcXpUUpKkiiVEqFM2tufc7W3Wozbcfn3N/VymtWgEIprWtdFaG0ak gkJWoqWlISakihvj76wn
> rIc2ZOz2niDwSxTc8S1OZew0hZ5Vs+i6v5sxMXx1XY5BvedMYsbjY4opyleF hWCxWqpgKsRMwgTUv3np
> t0x2u1Eb3HuN+NNeQFBtThW9pPBZQzFWGUq4p5gUSOBOeGjb75v66tOyYbMR aE1pRpSEHLIfO+Ss+oca
> B40AIOJr2X1f85wXAbN3Iqd4wOMVchuN+bqdg/KeMcpx1lZUp5OWP+FpRWTq Tgj+JsrlmNZuDFYO+HoQ
> XV2Ko7S6VTtNrpxYv8V2+3/zZciwTIS5LKmXWy6EpWW9K18tbddSVGoRUgCo Qa0Upe5r8zt1EsMMNXpM
> kNL5jTnLGSlag1zULzASKc0gVqFKFMSo9L71Jk+dfF7Iedsm1eExI/wzfrJR clyKD7wtA/1NU63kctgh
> HMrKyMkyho+k3SPI9M+VKcH6LkSF7juhFo9T9r2/p/OZX/MKWh2EJQU6oFTT YUtCuasIbRkppaqhIAQQ
> DUgnDq2HJvG8GIcVqHz727JMdKGG1DmuFelCW2yt1dVEhIGtRJzFK6RR/wCo H6jmQOdT+9YxwlLSuOeH
> OO2r+RyHeVE14+TyY2hklHYqSSRjN1/KHpm4eVwQmKZcRI5f7D3aLfy56n9b Ln1V35s3o3sRah/P7qxA
> itiqVylvOpQqTJp8zUCMkqfdqMmm1LUCoBKPXHYnSnY/aB02vXW3qvHbuHUa HbXpTUVJSoRihslDDBNU
> mS6soYMih/eOBmPWpW5C7gDnul2+Gn8YxdLY0qy15kSyLOmjzxZrrFC9RjXM k8XciaRWl4Ry7bFcAYQb
> AR6l3BCFKcoQB/Un7NH+3+57K6ibb3Tcbt06vTjkIJmlpT8Ccy3zuWVR2GGP by2SpcajYdC48lLq3KIW
> qG+hPc9ujuLl7ljdQ24je9beEPITEQ41EVDeVoSGGXnn3ErYdSUvEuKC0uML yUpQDn8xOYrTi7VmDpjA
> jaLXNMpWTYRyguDtGcVDFJ4p84bstnz5ddc4JNm6Yp96cDbnKBe1sf0++weB 3d3Pdm4d8bolWnprZHm2
> HPalpuVMkraU+ttuRIbeYiMRY4S9JfWy8o81lttqinHmUDuV6/3Lo2du7c2p Z40reN0RzAuSFrjxmS6G
> GlKZacadkOyH9bbTaXWkIDTrji1ENtOpTD/J3ki5t2N6tyD46zNFQy3IuIeq zUGmwc+QyLevSdoD+OW0
> farQxgmSkVELgYFXKT1NbpL4c3xdK/3CdrvZD/3XdR+oHad3GuXS/wC0FNOX C3XOQCZcVchqGp216rZA
> efUmQ+zpcbMmK4gqq4ydGvB0x6g9xCd7be2t1l6dxmrRd2l+2mQo60Bp9KVO Jakn3b7aKtoWVNrbYeTQ
> EBwawGvydz8yi8zqlgjjdiIuSbCR3Y2yjl2KB03SNOFmnaZhZy/slTg4KAiX T9FEFnDwyrhRQgJk3OAB
> PvT/APppdt/TjtxtXXzvL6tXezonMRHOVBcQy1EcuDfNiwEti33CZPn8shb/ ACm2m2Vpeb5brTJkLi67
> dzHV3fvU267D6DbWtT0OG46gOS23HXpKGHFNrlFXuYzEaK4ptfISoOLW3y3F vNOOhhEkMe8l7racb5wk
> 7Zi+UoWS8EJSbKfhZgqpatYJhvUP4wjnFake/M7fRDhiqiCxyCdMoqlFJZUp gEOQuoPaV0dsvch24bI6
> b9Xxubob1JnQBElxnmVXOHGk3IW2Q3KPtkMNyUO6y1zIrbiSlbcmI040pKpt snVjqA50b6n7r3bsxu1d
> Rtrwpa3WXGXUxHXWIypLakN89bpbUkDWlElaVApWzIUhxJSi+IvNN5yOsF7p 8/UW9ZnaXAQ1tUkYx4dW
> BcQk5JPYZq0EHqyj8kqi9inKqhhAEAQ6Nh6urZ4d/vYRtntQi9MNxdPN03G6 be3FJkQRHmlt6eJsZKXV
> LQYsSKyY7jTzDbbYQt4vaySUqSAl9tnXe+dX2t3Rd3QIEa5WwIeLsZDjEYR1 ilFh+TJWFpUlxa3OYlsN
> 0GkFJJZHNvqarQF0aY7wTjtzk2yyk6NZrwJt38vIW+dJ3ortqtW4xdio4Yt0 0TqHeOnSDciRBOcSEEBH
> qro7/SE2HYunMvqV3edVZNhZiwhLnRob8WFGtLZoQ3OuUqPM58kFQbcYjR20 pf8A3LL8kkKMK7m7xt47
> q3QxtvoRs+JJhvPcuPJmMvyH5orTmsRGXowjsq/TaU84+6pohx1hghSA5tQ5 W8l6vP0WN5G8bpOpwuQ7
> bX6PEztQXipleIsFnet46HCdQg7bbodoy8W6AXArPWyqaCSqhCKiToNAPUnt L7Ft8dPepu5+0fuVky96
> bWtj9yet16dLSJkKINckwg/ardKW4GUuLaUx7xBcDbT6Y6X0OiUNo9Te4/b2 7dqWXrT02h/4bu8hMZEy
> 3sq1R33AQ0H1ImyWQlTmhCkutx1aVKW0t0tLRiwoZEAEQ6/YO3YPZ2e7XlGI lQDTHYvtj5YhPZ+akZSO
> TJ8H2iHaNquuNaim1xSfGTXjrBZG0Y4bnmUVx8KEImeRBNQ5Ok6ID3phEhT6 9ObB/Tpc3x2NWjuc2TfL
> g/1KEW4XKTa1htUd62QJk2O6mEhtkPiYhiMJtXXltutJdbQ2lZbJ5Cl9yq7J 3GXXpHuCBDb2cJUaCxKS
> Fh9E2RFivIVIWp0tFhb7yogShlC0OKaUpahrAlVkDIcTjml2m7TqgkjqtDvp Vyl3hU1XCrZMQbMERN2e
> IfOxIiQO34zhrhvob0bvvXbq1sDpPtlWm4XuehovaStMaMkF6ZMWkEFTcSI2 9JWkEFSW9INVDHQnUveV
> u6ZbD3Rvm7N6mLfG1IaqEF+Q4pLMWMlRrpVIkuNMhRBCdes5JOI18SuXP9pF lc2cpXE6xZ6KFfeShGbw
> V4Z7FWtexoxC7Izk4vElmx6u4K5734BExRIO3UAdXd/XZJa+0jdXTxOzdwzb psvc0SQYwl6HJrUqE4y3
> JacUwwwy4lz3DK2A20FgKUheohKlRJ229a7j1m2/uZ7ccGJG3BaZSUPGOlbU ZTLrfMaWlLzz60FOlxLp
> W6UnSFDSCUiO+cPUpcV+9sMXYBx45yvcZeeGrwREEl5FezzyQLGeN61DNHkY VeMjkUTqryDt41aJpJic
> xilEom7F6L/0ktj2PphP6td5PU+Xtq3RIQly4kV2PFRa2VadCbhOfjzC7MUp QbVBixgpDtGUSHnSUIgn
> dfd9u3dO7Y+0u3/asOew67y2Zctp59U0itXI0Zp2MGYx/SbfecdW42eaqO02 KlWE5ichsSmgn/KPAiFR
> qc+/TjSWKpTETJrRbs6QuBTdNIiz22OcLEQKc3cGdNlVCpHFPr6R3ZULsS7L e5KBuu39l3cNd3eolpYL
> 6oV6aWWH2irloUNdtt8plhTpShUtn34YUtpL8ZBea1Lk3rv3BdIpllkddunV se2rOXy0v27928hYGpaQ
> oy5Edx5KPmTHdRDDyQstSSGnSmSGcuQ5cfYKc5ox6WDu7HxMCMcdV4v5S9j5 aVJFrrgq0Mk5Ku1cH6DJ
> j0nTVKYpygJRAOR+1ftIidU+5+49u3XBu87fuMGHcDJajFhuW1LhhtSW9bzM pgtKQpTocShxDzWhTLmh
> xK8TR1m6vydo9IbV1Q6bu264xZsqKll19t1xhUeQh1RXy23YzocCkJQUKWhT SypLiNSCjELsbc6uV2WU
> puWx7xbbW+sVqdCuzNgi5pmgyLKkhYiwLsWjR5a0rI9VRjZxtuKEet8Z+koG 2HXffV3sC/pw9Dr7adk9
> U+5rdVi3rPgNy2GpDrLqeQ8440064tjba47aFONOA8yQ3pCSVFKaKxztsnrn 3bdQLU/ubaHTvbdxsDUh
> xlXLiyELLjRGtCQ5e0qUQCCNKFEggAFXy4lNgrl1R8+LzNAslfNSr63B7HS2 PrMok+bzSKBHJZZpHi7a
> thfKMU2qvi2S6JF0yFE2xylOYvGPdv8A0/8AeHbFarN1R2Tu4bp6OyVtFF0j thl+Ct6ioqpKWXX2lR5I
> UlMW4R3Sy45RDjcdTsYPzt0J7krf1Rur+2LzZ1WLqLGCnEMhxSm3wyaOmOta GnmpDBGp2K6kuIRVbbrw
> bf5MDjcycg+nfy5uNo49NZGDJCWeGr56ci6kpmvXeJsK8OVrVZutJtlHUrFP ZCXJ3BSqguzEQUbqpHIU
> weu3Z1247EmdBemfXe+dR73CuknbguF0dVIhtQeW2FKkB1swHFBpoJIUS4py qS4FJUcoo67923WHf+7N
> wdAZXT3bF7Kby5b7atcOYbmHwpTbDqH0XRhn3KwATRhDTmoNuNuJJ1dJHA/1 oc68scM81bnbuOsTULXx
> nwZccx1OXYxVri8dzjyBrMxJxVJsKVhnV7I4l372JOsZVmZFuZiRQCnBUuum GonSPct026z066ixLzCf
> nMx5LceU2++0HVAJcqlhsNhQqlOttXziuYyHMu6dpdaumdpur/VbYUiy3ARn nYypEZbLTvJQSsU9w9r0
> HSVBLqTpUBROSi7npDerrcvUVueYsZ5HxXXaNbsZ1iu3trMUdeSNV3lbsEmv XkIx4hPTErL+f+bxrpYD
> kAjbwoFL2qAYRWeovT237Ut1rvFqkvGFIeWyUPKStzWhIWVBSGmk6NKkilCq tTWhyaWz9w3O8KnR7tyF
> SW9KgpltbadKqjSUrdeOoEE6goAg00ilSqfV+9WwfTggabVMfUFhknN2Q4aV s0VGTZJdzXazV4t2EclK
&g
Re: One Row Per Page [message #159360 is a reply to message #158559] |
Tue, 09 May 2006 04:25   |
Milton,
I apologize, I was using 2.0.1 where this report worked.
I have logged a bugzilla entry for 2.1 Bug id 140751.
Jason
"Milton Hagler" <milton@corigo.com> wrote in message
> Jason,
> Here is a screen shot of Eclipse after running Preview and a PDF of the
> same report showing the incorrect data. I assume this is what you
> wanted. I've also reattached the report's rptdesign file for convenience.
> Please let me know if there's anything else you need.
> Milton
> Jason Weathersby wrote:
>> Milton,
>> Can you upload a screenshot of the error you are getting?
>> Jason
>> news:e3cbo8$vlt$1@utils.eclipse.org...
>>>Interesting. I confirmed that the iText-1.3.jar file is in the correct
>>>location and even tried running the report again and had the same problem
>>>of the phone number not stepping over the record set.
>>>My environment is the following:
>>>- eclipse 3.2.0 Birt 2.1 All-in-One
>>>- JDK 1.5.0_05
>>>- Windows 2000 Server SP4
>>>I even tried downloading the latest iText-1.4.jar and had the same
>>>result.
>>>Also tried installing JDK 1.4.2 running with both iText-1.3 and iText-1.4
>>>and that also didn't help.
>>>At this point I'm at a loss, but will go ahead and solve my report
>>>directly with iText and will use Birt for other more standard reports
>>>that
>>>I'll be needing. BTW, the Birt tool is quite nice, easy enough to learn
>>>and very capable.
>>>Thanks again for your help.
>>>Milton
>>>>The report works fine for me. It appears that you dont have iText in
>>>>the
>>>>right place.
>>>>The pagination example was setup for PDF not html. Copy the iText jar
>>>>to
>>>>the lowagie plugin lib directory and this should fix the problem.
>>>>Jason
>>>>news:e39akg$dok$1@utils.eclipse.org...
>>>>>Thanks for the help again. The report you sent works and steps over the
>>>>>data correctly. However, when I change the OFFICECODE to display phone
>>>>>numbers the numbers don't step with the result set and displays the
>>>>>first number repeatedly. The city name steps normally though. I've
>>>>>attached the report file for you to look at.
>>>>>I found the same problem when I tried to duplicate your report using my
>>>>>data where only the first row of the result set is displayed
>>>>>repeatedly.
>>>>>Also when setting up the report I'm receiving the error message quite
>>>>>frequently "Error happened while running the report" for no apparent
>>>>>reason.
>>>>>Thanks again.
>>>>>Milton
>>>>>>Here is an example.
>>>>>>I added a grid to the detail row of a table to format the cells.
>>>>>>I added a style to the detail row to page break after.
>>>>>>Jason
>>>>>>news:82ecc722c082e0614722b9851ece7c6c$1@www.eclipse.org...
>>>>>>>Great, that worked for a simple table. Now what I need to do is
>>>>>>>enhance
>>>>>>>the report so it has these characteristics:
>>>>>>>1. Each row of data has a separate page
>>>>>>>2. Each page has a header also fed from the data with a static image
>>>>>>>3. Each page has 2 columns beneath the header with data
>>>>>>>| static image field8 |
>>>>>>>| label field0 | label field1 | one page per row
>>>>>>>| label field2 | label field3 |
>>>>>>>| label field4 | label field5 |
>>>>>>>| label field6 | label field7 |
>>>>>>>I've tried many different combinations but have been unable to make
>>>>>>>the
>>>>>>>report generate a page for each row. Any hints on how to construct
>>>>>>>the
>>>>>>>reports framework?
>>>>>>>BTW, how to chase down the error message: "Error happened while
>>>>>>>running
>>>>>>>the report"
>>>>>>>Thanks,
>>>>>>>Milton
> id="1">
> <data-sources>
> <oda-data-source
> id="4">
> <property
> </oda-data-source>
> </data-sources>
> <data-sets>
> <oda-data-set
> <structure>
> </structure>
> <structure>
> </structure>
> <structure>
> </structure>
> <structure>
> </structure>
> <structure>
> </structure>
> <structure>
> </structure>
> <structure>
> </structure>
> <structure>
> </structure>
> <structure>
> </structure>
> </list-property>
> </structure>
> </oda-data-set>
> </data-sets>
> <styles>
> </style>
> </styles>
> <page-setup>
> <page-footer>
> <text id="3">
> </text>
> </page-footer>
> </page-setup>
> <body>
> <table id="6">
> <structure>
> <expression
> </structure>
> <structure>
> <expression
> </structure>
> <structure>
> <expression
> </structure>
> <structure>
> </structure>
> </list-property>
> <column id="55"/>
> <detail>
> <row id="26">
> <cell id="27">
> <grid id="64">
> <structure>
> <expression
> <property
> </structure>
> </list-property>
> <column id="65"/>
> <column id="66"/>
> <row id="73">
> <cell id="74">
> <image id="76">
> <property
> </image>
> </cell>
> </row>
> <row id="67">
> <cell id="68">
> <label id="9">
> <text-property
> </label>
> </cell>
> <cell id="69">
> <data id="78">
> <property
> </data>
> </cell>
> </row>
> <row id="70">
> <cell id="71">
> <label id="11">
> <text-property
> </label>
> </cell>
> <cell id="72">
> <data id="30">
> <property
> </data>
> </cell>
> </row>
> </grid>
> </cell>
> </row>
> </detail>
> </table>
> </body>
> <structure>
> yUPALMpyzSU/LEWax7Bq5a9R26p1FigQia1emPTVG91vSp8lbduS4W0hBSlS 1pRzFkuKStLaGkFKlEoU
FUDForum. Page generated in 0.05597 seconds
