Home » Eclipse Projects » Eclipse Platform » Wizard Extension Id for Java Stuff ...
Wizard Extension Id for Java Stuff ... [message #157370] Sat, 15 November 2003 20:03 Go to next message
For adding a wizard at the "base" level, the extension point is
"org.eclipse.ui.newWizards". Can someone tell me how I extend the "Java"
section. I am adding a JDBC Configuration wizard.
David
David L. Whitehurst
aka. PiratePete
http://www.piratepetesoftware.com
dlwhitehurst@comcast.net
Re: Wizard Extension Id for Java Stuff ... [message #157379 is a reply to message #157370] Sat, 15 November 2003 20:14 Go to previous messageGo to next message
Extend the same extension-point but use "org.eclipse.jdt.ui.java" as
category.
Dani
>Thanks,
>David
Re: Wizard Extension Id for Java Stuff ... [message #157386 is a reply to message #157370] Sat, 15 November 2003 20:31 Go to previous message
Thanks. I used parentCategory and then appended "org.eclipse.jdt.ui.java/"
on the category element of the wizard tag. It worked!
David
David L. Whitehurst
aka. PiratePete
"David" <dlwhitehurst@comcast.net> wrote in message
news:bp6i8v$cvn$1@eclipse.org...
> David
> David L. Whitehurst
> aka. PiratePete
Previous Topic:REALLY Flat Buttons?
Next Topic:Source drop build problem? Completing Install splash always on (R-2.1.2-200311030802)
Current Time: Mon Sep 01 02:18:26 EDT 2025
Powered by FUDForum. Page generated in 0.26417 seconds
