Home » Language IDEs » Java Development Tools (JDT) » JDIDebugModel and Creating Invisible Breakpoints
JDIDebugModel and Creating Invisible Breakpoints [message #157348] Wed, 05 May 2004 12:40 Go to next message
I'm trying to create invisible breakpoints (i.e. breakpoints that
are not registered to the breakpointmanager) but somehow I'm not
able to receive events to my IJavaBreakpointListener from those
invisible breakpoints. I would like to record stack traces without
user seeing the breakpoints (those tiny blue balls). When I register the
breakpoint to the breakpointmanager everything works fine and I get
the events.
I register the breakpoint with following code:
JDIDebugModel.createLineBreakpoint(resource, typeName, line, -1, -1, 0,
false, null);
And I launch the program with following code:
ILaunchManager manager = DebugPlugin.getDefault().getLaunchManager();
ILaunchConfigurationType type
=manager.getLaunchConfigurationType(IJavaLaunchConfiguration Constants.ID_JAVA_APPLICATION);
ILaunchConfigurationWorkingCopy wc = type.newInstance(null, "SampleConfig");
wc.setAttribute(IJavaLaunchConfigurationConstants.ATTR_PROJE CT_NAME,
"Profiled Program");
wc.setAttribute(IJavaLaunchConfigurationConstants.ATTR_MAIN_ TYPE_NAME,
"Profileable");
ILaunchConfiguration config = wc.doSave();
ILaunch launch = config.launch(ILaunchManager.DEBUG_MODE, null);
- Sami
Re: JDIDebugModel and Creating Invisible Breakpoints [message #159099 is a reply to message #157348] Mon, 17 May 2004 11:05 Go to previous message
Unregistered breakpoints are not added to debug targets automatically. You
must add them yourself. Debug targets only add registered breakpoints
automatically.
Darin
"Sami Lakka" <sami.lakka@tut.fi> wrote in message
news:c7b566$jjf$1@eclipse.org...
> Hello,
> the events.
> false, null);
A_APPLICATION);
"SampleConfig");
> "Profileable");
> Best regards,
> - Sami
Previous Topic:Debugger is fine but steps are not visible
Next Topic:assert-try-finally-debugger interaction, stops in finally, not at assert
Current Time: Thu Nov 20 19:58:54 EST 2025
Powered by FUDForum. Page generated in 0.23539 seconds
