Home » Archived » BIRT » build BIRT outside of eclipse?
build BIRT outside of eclipse? [message #157329] Sun, 30 April 2006 11:31 Go to next message
Does anyone have any suggestions about how to build BIRT exclusively
from the command line (i.e. outside of eclipse)? I've followed the
instructions on the web to get it built using eclipse, but we need to
automate the BIRT build process so that it can easily be invoked from
our own build.xml.
Some of the Build*.xml files mention a "top level build script", but I
couldn't find it anywhere. Does any one know what this refers to or
have any other pointers about how to do this? Thanks.
Holly
Re: build BIRT outside of eclipse? [message #157368 is a reply to message #157329] Sun, 30 April 2006 16:12 Go to previous messageGo to next message
Nevermind. I was being very stupid. BuildWebViewer.xml in
org.eclipse.birt.report.viewer/ does the trick.
Holly
> our own build.xml.
> Holly
Re: build BIRT outside of eclipse? [message #157411 is a reply to message #157368] Mon, 01 May 2006 11:08 Go to previous messageGo to next message
I'm trying to build BIRT from the command line as well. I want to build
from the head revision, so I have that checked out. Whenever I run the
build, I get an error that says
BUILD FAILED
....\workspace\org.eclipse.birt.report.viewer\BuildWebViewer .xml:252: The
following error occurred while executing
this line:
port.engine\BuildEngine.xml:220:
....\workspace\org.eclipse.birt.report.engine\plugins not found.
The plugins directory does not exist in what I have checked out. I'm not
sure if I have missed something from the repository, as I am not very
familiar with CVS, or if the build is just broken in the current development
version.
Can anyone help?
--floor
"Holly Devereux" <holly.devereux@gmail.com> wrote in message
news:e335na$s15$1@utils.eclipse.org...
> Holly
>> Does anyone have any suggestions about how to build BIRT exclusively from
>> automate the BIRT build process so that it can easily be invoked from our
>> own build.xml.
>> couldn't find it anywhere. Does any one know what this refers to or have
>> Holly
Re: build BIRT outside of eclipse? [message #160836 is a reply to message #157329] Mon, 15 May 2006 00:14 Go to previous message
hey if you build BIRT in eclipse can you help
i am unable to build BIRT in eclipse , i have followed
the following link to build BIRT
http://www.eclipse.org/birt/phoenix/build/buildInstructions. php
but i think this is 100% stable document
Previous Topic:Change data source and/or set at runtime
Next Topic:XLS Emitter on SourceForge
Current Time: Wed Nov 19 06:06:00 EST 2025
Powered by FUDForum. Page generated in 0.03247 seconds
