Home » Language IDEs » C / C++ IDE (CDT) » standard include paths not recognized
standard include paths not recognized [message #157317] Sat, 05 November 2005 06:00 Go to next message
Originally posted by: gentoo.aloetscher.ch
I have installed eclipse cdt 3.0 with eclipse 3.1 on gentoo linux. When
I make a new c++-project (managed or standard), no include path appear.
When I type the following code:
#include <iostream>
using namespace std;
int main() {
cout << "Hello world" << endl;
the project is compiled successfully, but in the first line "#include
<iostream>" appears a "?" with the following message:
"C/C++ Indexer Problem: Preprocessor Inclusion not found: iostream in
file: /path/to/workspace/path_to_project/hello.cpp".
Also, the binary is created successfully, but is not recognized as a
binary. I have tried all binary parsers, especially the ELF parser, but
no of them recognizes the binary.
Surprisingly, i can however run the binary file with "Run as ..." -->
"Run as Local C/C++ Application".
Is there someone, who could imagine, what's going wrong with my eclipse
cdt installation? Maybe I have to set some environment variables, but I
don't know which of them.
In my gentoo installation, the includes are found in the following path:
/usr/lib/gcc-lib/i686-pc-linux-gnu/3.3.6/include/g++-v3.
Thank you a lot for your help.
Adrian
Re: standard include paths not recognized [message #158108 is a reply to message #157317] Wed, 16 November 2005 08:57 Go to previous messageGo to next message
Hi Adrian,
I have the same problem with eclipse and the c++ indexer.
Have you allready solved the indexer problem?
Ruben
Re: standard include paths not recognized [message #158332 is a reply to message #158108] Thu, 17 November 2005 17:53 Go to previous messageGo to next message
Hi Ruben
Unfortunately, I couldn't solve the problem. But perhaps, I have found,
in which code line the parser is configurated.
In the file ".cdtproject" I have noticed the following line:
<runAction useDefault="true" command="gcc" arguments="-E -P -v -dD
${plugin_state_location}/${specs_file}"/>
But I don't know, how I can find out, witch value the variables
${plugin_state_location} and ${specs_file} have. Perhaps you or someone
else can help me.
When I type the command "gcc -E -P -v -dD" on the bash shell, I receive
the following information, which seems to be okay.
gcc -E -P -v -dD
Lese Spezifikationen von /usr/lib/gcc-lib/i686-pc-linux-gnu/3.3.6/specs
Konfiguriert mit: /var/tmp/portage/gcc-3.3.6/work/gcc-3.3.6/configure
--prefix=/usr --bindir=/usr/i686-pc-linux-gnu/gcc-bin/3.3.6
--includedir=/usr/lib/gcc-lib/i686-pc-linux-gnu/3.3.6/includ e
--datadir=/usr/share/gcc-data/i686-pc-linux-gnu/3.3.6
--mandir=/usr/share/gcc-data/i686-pc-linux-gnu/3.3.6/man
--infodir=/usr/share/gcc-data/i686-pc-linux-gnu/3.3.6/info
--with-gxx-include-dir=/usr/lib/gcc-lib/i686-pc-linux-gnu/3. 3.6/include/g++-v3
--host=i686-pc-linux-gnu --build=i686-pc-linux-gnu --disable-altivec
--enable-nls --without-included-gettext --with-system-zlib
--disable-checking --disable-werror --disable-libunwind-exceptions
--disable-multilib --enable-java-awt=gtk
--enable-languages=c,c++,java,f77 --enable-shared --enable-threads=posix
--enable-__cxa_atexit --enable-clocale=gnu
Thread-Modell: posix
gcc-Version 3.3.6 (Gentoo 3.3.6, ssp-3.3.6-1.0, pie-8.7.8)
Adrian
Ruben Jenster wrote:
> Hi Adrian,
> Ruben
Re: standard include paths not recognized [message #159791 is a reply to message #158332] Fri, 02 December 2005 08:01 Go to previous messageGo to next message
Originally posted by: _spaaam_usenet.laliluna.de_spaam_
The solution to the problem is to add the directory where the iostream etc
are located.
under my linux this is
/usr/include/c++/4.0.2/iostream
open the project properties
-> c/c++ build -> Tool Setting --> GCC C++ Compiler --> Directories
and simple add your path.
Best Regards
Sebastian
Tutorials and Seminars for Java
http://www.laliluna.de
Re: standard include paths not recognized [message #159823 is a reply to message #157317] Sat, 03 December 2005 06:06 Go to previous message
Originally posted by: void.void.com
See also the post "Preprocessor inclusion not found" from 11/22/2005.
This is a bug in the indexer which has been around for a long time now
(I have seen it filed on bugzilla several times now, but it looks as if
it isn't being classified high priority for the devs, unfortunately).
Matthias
Previous Topic:New project template
Next Topic:*** [Proj1.exe] Error 1
Current Time: Sun Jul 06 03:35:45 EDT 2025
Powered by FUDForum. Page generated in 0.06171 seconds
