| moving packages recursively - is it possible? [message #157305] |
Wed, 05 May 2004 05:48  |
I have not found the way to move package with subpackages
recursively. For example, there are packages:
a.b
a.c.d.e
a.c.d.f
And this result is needed:
a.b.d.e
a.b.d.f
a.c
i.e., to move d package with subpackages d.e and d.f from a.c
package into a.b package. Have I missed something?
I'm using 20040428 integration build.
Andrew
| Re: moving packages recursively - is it possible? [message #158592 is a reply to message #158583] |
Thu, 13 May 2004 11:29   |
Originally posted by: john.childress.entergykoch.com
Sure,
but when I rename that package, the child packages are still under the
original name.
com.test
com.test.test1
com.test.test1.test2
com.test.test1.test3
I want to rename com.test.test1 to com.test.fun and have both test2 and
test3 now be under com.test.fun
Clear or not really?
thanks,
John
"Jesper Kamstrup Linnet" <linnet@nospam.users.sourceforge.net> wrote in
message news:c802qv$un5$1@eclipse.org...
> Hi Andrew,
> Maybe I don't understand what you mean, but if I do I think you can do
> it by switching to Hierarchical view in the Package Explorer. That way,
> the packages will be shown as a tree and you should be able to select
> the d package (with all its contents).
> Best regards,
> Jesper
> > a.b
> > a.c.d.e
> > a.c.d.f
> > a.b.d.e
> > a.b.d.f
> > a.c
> > Andrew
FUDForum. Page generated in 0.03822 seconds
