Home » Eclipse Projects » Eclipse Platform » Overide Syntax Coloring
Overide Syntax Coloring [message #157284] Sat, 15 November 2003 08:10 Go to next message
Originally posted by: glongman.intelligentworks.nospam.com
I have a text editor with the usual setup to provide syntax coloring.
Is it possible to override the coloring for a range in a SourceViewer?
If so, can anyone provide a pointer to how this is done?
Geoff
Re: Overide Syntax Coloring [message #157331 is a reply to message #157284] Sat, 15 November 2003 12:32 Go to previous messageGo to next message
If it is related to syntax colouring then adding a corresponding rule
would probably the appropriate thing. If you want to change text style
for some other feature (e.g. to mark occurrences) you should use the new
API ITextPresentationListener.
Dani
>Cheers,
>Geoff
Re: Overide Syntax Coloring [message #157347 is a reply to message #157331] Sat, 15 November 2003 16:01 Go to previous message
Thanks!
Geoff
"Daniel Megert" <daniel.megert@gmx.net> wrote in message
news:bp5nrm$mll$1@eclipse.org...
> Dani
> >Cheers,
> >Geoff
Previous Topic:Native Library already loaded in another classloader
Next Topic:REALLY Flat Buttons?
Current Time: Sat Jul 05 12:32:38 EDT 2025
Powered by FUDForum. Page generated in 0.07206 seconds
