Home » Archived » BIRT » Reoort Engine can't produce chart
Reoort Engine can't produce chart [message #157280] Sat, 29 April 2006 06:38 Go to next message
Originally posted by: wcleung9.ie.cuhk.edu.hk
I made a report template with a bar chart, by Eclipse 3.0.1 and
birt-report-framework 2.0.1 . It shows no problem when rendered in
Eclipse's preview window or when deployed to the Web Viewer Example of
birt-runtime-2.0.1 on JBoss 4.0.3.
But when I try to use the Report Engine API (also from birt-runtime-2.0.1)
to write my own webapp, I could generate the report but could not generate
the chart image in it. No Exception is thrown in the server log.
Did I missed some methods to call?
Below is my Servlet code:
OutputStream out = resp.getOutputStream();
String reportName = "barchart.rptdesign";
try
EngineConfig config = new EngineConfig();
config.setEngineHome(this.getServletContext().getRealPath("/WEB-INF/lib "));
// Create the emitter configuration.
HTMLEmitterConfig hc = new HTMLEmitterConfig( );
// Use the "HTML complete" image handler to write the files to disk.
HTMLServerImageHandler imageHandler = new HTMLServerImageHandler( );
hc.setImageHandler( imageHandler );
// Associate the configuration with the HTML output format.
config.setEmitterConfiguration( HTMLRenderOption.OUTPUT_FORMAT_HTML, hc );
engine = new ReportEngine(config);
IReportRunnable report =
engine.openReportDesign(reportReposPath+"/"+reportName);
//Create task to run the report and render the report
IRunAndRenderTask task = engine.createRunAndRenderTask(report);
//Set Render context to handle url and image locataions
HTMLRenderContext renderContext = new HTMLRenderContext();
renderContext.setImageDirectory("image");
HashMap contextMap = new HashMap();
contextMap.put( EngineConstants.APPCONTEXT_HTML_RENDER_CONTEXT,
renderContext );
task.setAppContext( contextMap );
//Set rendering options - such as file or stream output,
//output format, whether it is embeddable, etc
HTMLRenderOption options = new HTMLRenderOption();
options.setOutputStream(out);
//options.setOutputFileName("/example.html");
options.setOutputFormat("html");
task.setRenderOption(options);
task.run();
engine.destroy();
out.flush();
}catch(Exception e)
log(e);
Re: Reoort Engine can't produce chart [message #157288 is a reply to message #157280] Sat, 29 April 2006 08:04 Go to previous messageGo to next message
And this problem only happens when the output format is html. Pdf output
shows the bar chart normally.
Re: Reoort Engine can't produce chart [message #157293 is a reply to message #157280] Sat, 29 April 2006 11:02 Go to previous messageGo to next message
What did you set the BIRT_HOME variable to? Can you show your directory
structure with the plugins?
David
"Henry Leung " <wcleung9.ie.cuhk.edu.hk> wrote in message
news:14877151219b2e7c4049acd5a701b49e$1@www.eclipse.org...
> try
> renderContext );
> //Set rendering options - such as file or stream output, //output format,
> task.run();
> engine.destroy();
> out.flush();
> }catch(Exception e)
> log(e);
Re: Reoort Engine can't produce chart [message #157309 is a reply to message #157293] Sat, 29 April 2006 12:24 Go to previous messageGo to next message
You mean there should be an OS environment variable BIRT_HOME? No, I
haven't set that.....
Is that necessary?
Re: Reoort Engine can't produce chart [message #157316 is a reply to message #157309] Sun, 30 April 2006 02:14 Go to previous messageGo to next message
Yes, set it to the *parent* directory of "plugins" dir where you have your
BIRT plugins.
David
"Henry Leung" <wcleung9.ie.cuhk.edu.hk> wrote in message
news:5b672fed013d2e100a2ac90b819a23d5$1@www.eclipse.org...
> Is that necessary?
Re: Reoort Engine can't produce chart [message #157475 is a reply to message #157316] Mon, 01 May 2006 12:06 Go to previous messageGo to next message
Originally posted by: sheehana.gmail.com
I'm having somewhat of the same problem with a bar chart that is generated
using an xml data source. I can view the chart fine in the Birt Viewer
using
http://ramsrvr1.raleigh.ibm.com:8080/birt-viewer/frameset?__ report=test.rptdesign
but the chart is not rendered when I try
http://ramsrvr1.raleigh.ibm.com:8080/birt-viewer/run?__repor t=Report\JVEDemo01.rptdesign
The problem is occurring with Birt 2.1RC1a and Tomcat 5.5.
I tried setting the environmental variable you suggested and it did not
work. Any suggestions? Thanks
Re: Reoort Engine can't produce chart [message #157501 is a reply to message #157475] Mon, 01 May 2006 12:18 Go to previous messageGo to next message
Did you see anything in the log? That would be helpful to find the reason it
doesn't work. This sounds like a viewer configuration problem.
David
"sra" <sheehana@gmail.com> wrote in message
news:5b74aa366429ac512843268010b1533d$1@www.eclipse.org...
> using
Re: Reoort Engine can't produce chart [message #157542 is a reply to message #157501] Mon, 01 May 2006 13:42 Go to previous messageGo to next message
The exception in the logs is,
org.eclipse.birt.chart.exception.ChartException: The dataset used by the
Chart is invalid. This only occurs when I use run? and not when I use
frameset?. The datasets are xml files on a remote machine.
Here is the full stack trace.
May 1, 2006 12:18:38 PM org.eclipse.birt.chart.datafeed.ResultSetWrapper
setup
SEVERE: Unable to determine data types from resultset
May 1, 2006 12:18:38 PM org.eclipse.birt.chart.exception.ChartException
logThis
SEVERE: Exception
Chart is invalid
org.eclipse.birt.chart.datafeed.DataSetProcessorImpl.populat e(DataSetProcessorImpl.java:254)
org.eclipse.birt.chart.internal.factory.DataProcessor.fillSe riesDataSet(DataProcessor.java:1843)
org.eclipse.birt.chart.internal.factory.DataProcessor.fillSe riesDataSet(DataProcessor.java:1807)
org.eclipse.birt.chart.internal.factory.DataProcessor.genera teRuntimeSeries(DataProcessor.java:1282)
org.eclipse.birt.chart.internal.factory.DataProcessor.genera teRuntimeSeries(DataProcessor.java:1016)
at org.eclipse.birt.chart.factory.Generator.bindData(Generator. java:568)
org.eclipse.birt.chart.reportitem.ChartReportItemPresentatio nImpl.onRowSets(ChartReportItemPresentationImpl.java:407)
org.eclipse.birt.report.engine.presentation.LocalizedEmitter .startExtendedContent(LocalizedEmitter.java:660)
org.eclipse.birt.report.engine.presentation.LocalizedEmitter .startForeign(LocalizedEmitter.java:439)
org.eclipse.birt.report.engine.presentation.WrappedEmitter.s tartForeign(WrappedEmitter.java:209)
org.eclipse.birt.report.engine.presentation.DefaultPaginatio nEmitter.startForeign(DefaultPaginationEmitter.java:490)
org.eclipse.birt.report.engine.executor.ExtendedItemExecutor .execute(ExtendedItemExecutor.java:100)
org.eclipse.birt.report.engine.executor.ReportExecutorVisito r.visitExtendedItem(ReportExecutorVisitor.java:82)
org.eclipse.birt.report.engine.ir.ExtendedItemDesign.accept( ExtendedItemDesign.java:30)
org.eclipse.birt.report.engine.executor.ReportExecutor.execu te(ReportExecutor.java:125)
org.eclipse.birt.report.engine.executor.ReportExecutor.execu te(ReportExecutor.java:89)
org.eclipse.birt.report.engine.api.impl.RunAndRenderTask.run (RunAndRenderTask.java:171)
org.eclipse.birt.report.service.ReportEngineService.runAndRe nderReport(Unknown
Source)
org.eclipse.birt.report.presentation.aggregation.layout.Engi neFragment.doService(Unknown
Source)
org.eclipse.birt.report.presentation.aggregation.BaseFragmen t.service(Unknown
Source)
at org.eclipse.birt.report.servlet.ViewerServlet.doGet(Unknown Source)
at javax.servlet.http.HttpServlet.service(HttpServlet.java:689)
org.apache.axis.transport.http.AxisServletBase.service(AxisS ervletBase.java:327)
at javax.servlet.http.HttpServlet.service(HttpServlet.java:802)
org.apache.catalina.core.ApplicationFilterChain.internalDoFi lter(ApplicationFilterChain.java:252)
org.apache.catalina.core.ApplicationFilterChain.doFilter(App licationFilterChain.java:173)
org.apache.catalina.core.StandardWrapperValve.invoke(Standar dWrapperValve.java:213)
org.apache.catalina.core.StandardContextValve.invoke(Standar dContextValve.java:178)
org.apache.catalina.core.StandardHostValve.invoke(StandardHo stValve.java:126)
org.apache.catalina.valves.ErrorReportValve.invoke(ErrorRepo rtValve.java:105)
org.apache.catalina.core.StandardEngineValve.invoke(Standard EngineValve.java:107)
org.apache.catalina.connector.CoyoteAdapter.service(CoyoteAd apter.java:148)
org.apache.coyote.http11.Http11Processor.process(Http11Proce ssor.java:869)
org.apache.coyote.http11.Http11BaseProtocol$Http11Connection Handler.processConnection(Http11BaseProtocol.java:664)
org.apache.tomcat.util.net.PoolTcpEndpoint.processSocket(Poo lTcpEndpoint.java:527)
org.apache.tomcat.util.net.LeaderFollowerWorkerThread.runIt( LeaderFollowerWorkerThread.java:80)
org.apache.tomcat.util.threads.ThreadPool$ControlRunnable.ru n(ThreadPool.java:684)
at java.lang.Thread.run(Thread.java:534)
logThis
SEVERE: Exception
Chart is invalid
org.eclipse.birt.chart.internal.factory.DataProcessor.fillSe riesDataSet(DataProcessor.java:1847)
Source)
Source)
Source)
Caused by: org.eclipse.birt.chart.exception.ChartException: The dataset
used by the Chart is invalid
... 36 more
org.eclipse.birt.chart.reportitem.ChartReportItemPresentatio nImpl onRowSets
SEVERE: Exception
Chart is invalid
Source)
Source)
Source)
... 36 more
Re: Reoort Engine can't produce chart [message #157638 is a reply to message #157316] Mon, 01 May 2006 20:20 Go to previous messageGo to next message
No luck.
I set BIRT_HOME = D:\BirtStudy\birt-runtime-2_0_1\Report~1
(Report~1 represents the folder "Report Engine". I use Report~1 to avoid
any possible problem caused by folder name with whitespace.)
The situation is the same. When I render the report as HTML output, the
chart can not be displayed. And I can't find the corresponding .png file.
I don't think the chart image file is generated.
If I render the report as PDF, it's OK. The chart exists in the PDF
document.
In fact, as you can see in my code, I set the chart image folder to be
"image"
I wonder where this "image" folder should be? Do I have to create it
myself? Or will BIRT create it automatically?
Besides, in the package birt-runtime-2_0_1, except the "Report Engine"
folder, I see there is a folder named "Chart Engine". I haven't used any
libraries or plugins in it. Are they useful?
Re: Reoort Engine can't produce chart [message #157686 is a reply to message #157542] Tue, 02 May 2006 04:00 Go to previous messageGo to next message
Can you file a viewer bug in bugzilla? This sounds like a problem, there is
no reason it would work with one url and not the other, particularly in that
place of the code.
David
news:38e0be591f4b7fefa4c8fa7533012efb$1@www.eclipse.org...
> Thanks
> setup
> logThis
> SEVERE: Exception
> Chart is invalid
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> Source)
> at
> Source)
> at
> Source)
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> logThis
> SEVERE: Exception
> Chart is invalid
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> Source)
> at
> Source)
> at
> Source)
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> ... 36 more
> onRowSets
> SEVERE: Exception
> Chart is invalid
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> Source)
> at
> Source)
> at
> Source)
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> ... 36 more
Re: Reoort Engine can't produce chart [message #157695 is a reply to message #157638] Tue, 02 May 2006 04:05 Go to previous messageGo to next message
Henry,
I think you have to create that image directory yourself. It should be under
ReportEngine I believe. Make sure the web-app process has rights to write
there.
David
news:e7409b334a6ad4f3ce0f4e73d956ab8a$1@www.eclipse.org...
> No luck.
> I set BIRT_HOME = D:BirtStudyirt-runtime-2_0_1Report~1
> document.
> "image"
Re: Reoort Engine can't produce chart [message #157807 is a reply to message #157686] Tue, 02 May 2006 12:15 Go to previous messageGo to next message
I entered the bug in bugzilla, #139735. The bug report has more detail
about the exact problem I am having.
Re: Reoort Engine can't produce chart [message #157823 is a reply to message #157807] Tue, 02 May 2006 12:26 Go to previous messageGo to next message
David
news:5550777b53e378e2a367adb7f9192e74$1@www.eclipse.org...
> Thanks
Re: Reoort Engine can't produce chart [message #160242 is a reply to message #157695] Thu, 11 May 2006 07:47 Go to previous messageGo to next message
Sorry that I have been busy in last week.
I created the "image" folder in %BIRT_ENGINE% and many other locations
that I bet BIRT might use. But none of them is used. When I render the
report as HTML, the chart (the .png file) seems not even generated.
BIRT, as a process of JBoss, has full privilege to write file in any
folder path of my PC. So I guess BIRT just don't know the right path to
handle image. But I don't see any exception being thrown.
David Michonneau wrote:
> Henry,
> there.
> David
>> No luck.
>> I set BIRT_HOME = D:BirtStudybirt-runtime-2_0_1Report~1
>> document.
>> "image"
Re: Reoort Engine can't produce chart [message #160274 is a reply to message #160242] Thu, 11 May 2006 08:32 Go to previous messageGo to next message
Did you try to get the webviewer example available for download and deploy
it? I am pretty sure it should work with JBoss. then you would be able to
see what's the difference in your code and the example.
David
news:160207f6e9b938dc6a07959afe4d4da1$1@www.eclipse.org...
>> Henry,
>> under ReportEngine I believe. Make sure the web-app process has rights to
>> write there.
>> Thanks,
>> David
>>> No luck.
>>> file. I don't think the chart image file is generated.
>>> document.
>>> "image"
Re: Reoort Engine can't produce chart [message #160820 is a reply to message #160274] Sun, 14 May 2006 22:19 Go to previous messageGo to next message
Yes, as said in the first post, the chart is successfully generated when
using the webviewer example deployed to JBoss. It is generated in
eportimages.
rt-viewer.war
ok, I will try to dig into those code to see what's the difference.
> David
>>> Henry,
>>> write there.
>>> Thanks,
>>> David
>>>> No luck.
>>>> document.
>>>> "image"
Re: Reoort Engine can't produce chart [message #161263 is a reply to message #160820] Mon, 15 May 2006 22:37 Go to previous message
I decompiled some classes of the webviewer example to compare with my
webapp, and found out what's wrong.
First of all, I didn't set the BaseImageURL. It must be set and should be
a relative path:
renderContext.setBaseImageURL("report/images");
Secondly, I set the ImageDirectory to be a relative path, while that it
should be an absolute path:
renderContext.setImageDirectory(this.getServletContext().get RealPath( "/report/images"));
Previous Topic:How to send Java Object as parameter to report engine?
Next Topic:Inserting tables with both portrait and landscape orientation
Current Time: Sun Nov 16 06:46:59 EST 2025
Powered by FUDForum. Page generated in 0.07664 seconds
