Home » Modeling » GMF (Graphical Modeling Framework) » How to capture the event mouseOver
How to capture the event mouseOver [message #157266] Fri, 26 October 2007 11:12 Go to next message
Originally posted by: ijerez2001.gmail.com
how to capture the event when the mouse is over a figure.
I need this because i want to create a tooltip when it happen
Re: How to capture the event mouseOver [message #157278 is a reply to message #157266] Fri, 26 October 2007 11:27 Go to previous messageGo to next message
Hi Iván,
You may try to use IFigure#setTooltip(IFigure) and let GEF handle
tooltip invocation.
Boris
Iván Jerez wrote:
> Hello,
> Thanks
Re: How to capture the event mouseOver [message #157291 is a reply to message #157278] Fri, 26 October 2007 11:54 Go to previous message
Thanks again.
"Boris Blajer" <boris.blajer@borland.com> escribió en el mensaje de
noticias:fft10f$6jt$1@build.eclipse.org...
> Hi Iván,
> You may try to use IFigure#setTooltip(IFigure) and let GEF handle tooltip
> invocation.
> Best regards,
> Boris
> Iván Jerez wrote:
>> Hello,
>> Thanks
Previous Topic:Add problem view
Next Topic:two diagram views on one model
Current Time: Fri Nov 21 09:35:00 EST 2025
Powered by FUDForum. Page generated in 0.07046 seconds
