Home » Eclipse Projects » Eclipse Platform » org.eclipse.ui.editorActions mysterious behavior???
org.eclipse.ui.editorActions mysterious behavior??? [message #157250] Sat, 15 November 2003 01:54 Go to next message
Originally posted by: bob.objfac.com
Very frustrating. Three actions identically defined, but one shows the
accelerator key in the menu, two don't; two work, one doesn't...
1. Accelerator key shows in menu item and works:
plugin.xml:
<action accelerator="Ctrl+Shift+V" label="%Validate.label"
icon="icons/full/validate.gif" tooltip="%Validate.tooltip"
class="com.objfac.xmleditor.actions.XMLValidateAction"
menubarPath="com.objfac.xmleditor.topLevelMenu.xml/validateGroup "
id="com.objfac.xmleditor.topLevelMenu.xml.validate">
</action>
plugin.properties:
Validate.label=&Validate@Ctrl+Shift+V
Validate.tooltip=Validate document and show errors
2. Accelerator key doesn't show in menu item, but it works.
plugin.xml:
<action accelerator="Ctrl+Shift+D" label="%OpenDefinition.label"
tooltip="%OpenDefinition.tooltip"
class="com.objfac.xmleditor.actions.OpenDefinitionAction"
menubarPath="com.objfac.xmleditor.topLevelMenu.xml/navigationGroup "
id="com.objfac.xmleditor.topLevelMenu.xml.OpenDefinition">
</action>
plugin.properties:
OpenDefinition.label=Open &Definition@Ctrl+Shift+D
OpenDefinition.tooltip=Open definition of currently selected identifier
3. Accelerator key doesn't show in menu item and doesn't work, either.
plugin.xml:
<action accelerator="Ctrl+Shift+U" label="%OpenURI.label"
tooltip="%OpenURI.tooltip"
class="com.objfac.xmleditor.actions.OpenURIAction"
id="com.objfac.xmleditor.topLevelMenu.xml.OpenURI">
</action>
plugin.properties:
OpenURI.label=Open &URI@Ctrl+Shift+U
OpenURI.tooltip=Open currently selected URI
This is in 2.1.2 and previous.
Bob Foster
Re: org.eclipse.ui.editorActions mysterious behavior??? [message #157263 is a reply to message #157250] Sat, 15 November 2003 04:28 Go to previous message
Part of the problem is some weirdshit caching behavior on the part of PDE.
After numerous launches, the Ctrl+Shift+D accelerator started showing up in
the menu. But when I changed the OpenURI menu label to:
OpenURI.label=Open &URL@Ctrl+Shift+U
("URL" instead of "URI") the menu persistently shows "Open URI". Only by
renaming the runtime-workspace folder and relaunching in PDE can I get the
menu to properly show "Open URL". (Which also says it isn't my bug.)
However, even then, the accelerator does not appear in the menu item.
So now I have two questions:
a) Why do I have to make a new runtime-workspace to get a menu label to
change?
b) Why doesn't case 3 below work?
Bob Foster
"Bob Foster" <bob@objfac.com> wrote in message
news:bp4hie$lu7$1@eclipse.org...
> plugin.xml:
> </action>
> plugin.properties:
> plugin.xml:
> </action>
> plugin.properties:
> plugin.xml:
> </action>
> plugin.properties:
> Bob Foster
Previous Topic:FEATURE REQUEST: collapsable method-bodies
Next Topic:HTML editing perspective?
Current Time: Thu Nov 20 07:43:08 EST 2025
Powered by FUDForum. Page generated in 1.11129 seconds
