| Is there a way to import many eclipse projects at once? [message #157227] |
Tue, 04 May 2004 15:34  |
Originally posted by: chris.nospam.genly.us
Hi, All.
I there a way to import many java projects at once given the existence of
the eclipse .project and .classpath files in the root of each project? I
have an existing directory structure with many projects.
Importing them by hand will be tedious. But it is easy to locate the
directories using the Unix find command.
A team project set is not a good solution. Loading from a project set will
fetch the projects from CVS, and will put the projects at the same
directory level. In my case it is important to preserve the relative
placements of these directories. I want to fetch the projects using the
CVS command line, to preserve releative paths between projects, and then
tell eclipse to import all the projects I just retrieved from CVS.
Any help would be appreciated.
Chris
| Re: Is there a way to import many eclipse projects at once? [message #157332 is a reply to message #157274] |
Wed, 05 May 2004 10:00   |
Originally posted by: linnet.nospam.users.sourceforge.net
Hi Chris,
I'll take a look at how complex it would be to "backport" it to 2.1.x
(if I can find the time).
Jesper
Chris Genly wrote:
> Thanks very much. Looks like a really useful plugin. Unfortunately, I'm
> using 2.1 so I can't use it.
> Chris
> Jesper Kamstrup Linnet wrote:
>>Hi Chris,
>>Yes, it is indeed tedious. I have made a plugin for this exact purpose.
>>See http://eclipse-tools.sourceforge.net/projecttransfer .
>>Best regards,
>>Jesper
>>Chris Genly wrote:
>>>Hi, All.
>>>will fetch the projects from CVS, and will put the projects at the same
>>>Chris
| Re: Is there a way to import many eclipse projects at once? [message #157727 is a reply to message #157332] |
Fri, 07 May 2004 09:24  |
I have now released a version (v0.9.4) of the import/export plugin which
works with Eclipse 2.1.x to the SourceForge project
(http://eclipse-tools.sourceforge.net/projecttransfer). It is also
available on the update site (http://eclipse-tools.sourceforge.net/updates).
Jesper
> Hi Chris,
> Best regards,
> Jesper
>> Chris
>>> Hi Chris,
>>> Best regards,
>>> Jesper
>>> Chris Genly wrote:
>>>> Hi, All.
>>>> existence of
>>>> project? I
>>>> the
>>>> then
>>>> Chris
FUDForum. Page generated in 0.05665 seconds
