Home » Modeling » Epsilon » ant build
ant build [message #14727] Wed, 01 April 2009 05:42 Go to next message
I just got the newest Eclipse Ganymede Modeling Package and installed
Epsilon via the update manager with it. Now my ant build files don't seem
to work anymore. I get an elaborate error starting with
"loadModels:
[epsilon.loadModel] Internal error:
org.eclipse.emf.ecore.resource.Resource$IOWrappedException: Resource
'../Models/sca_v1_ClassDiagram.uml' does not exist."
for the first model it is supposed to load.
I never encountered this error with the previous versions. Did I maybe
forget to configure/think of something?
Thanks in advance for the help,
Anne
Re: ant build [message #14760 is a reply to message #14727] Wed, 01 April 2009 06:33 Go to previous messageGo to next message
Hi Anne,
If you are using relative paths, you should use the file attribute
instead of the value one. For example
<parameter name="modelFile" *file*="../Models/some.uml"/>
will work while
<parameter name="modelFile" *value*="../Models/some.uml"/>
will not.
Dimitris
Anne Keller wrote:
> seem to work anymore. I get an elaborate error starting with
> "loadModels:
> Anne
Re: ant build [message #14789 is a reply to message #14760] Wed, 01 April 2009 07:39 Go to previous messageGo to next message
Hi Dimitri,
I changed
<parameter name="modelFile" value="${basedir}/CardInsert.uml"/>
to
<parameter name="modelFile" file="${basedir}/CardInsert.uml"/>
but that doesn't change the error I get.
Something else I might be overlooking?
Thanks again and regards,
Anne
Re: ant build [message #14817 is a reply to message #14789] Wed, 01 April 2009 07:45 Go to previous messageGo to next message
Hi Anne,
Could you please zip and send me your project so that I can have a look?
Dimitris
Anne Keller wrote:
> Hi Dimitri,
> I changed
> to
> Anne
Re: ant build [message #14847 is a reply to message #14817] Wed, 01 April 2009 09:13 Go to previous messageGo to next message
Hi Anne,
Are you by any chance running Linux? If so, you may need to add a file:/
before your path to make sure that the load model task knows that it's
an absolute path. e.g.
<parameter name="modelFile" value="file:/${basedir}/CardInsert.uml"/>
Dimitris
Dimitris Kolovos wrote:
> Hi Anne,
> Cheers,
> Dimitris
> Anne Keller wrote:
>> Hi Dimitri,
>> I changed
>> to
>> Anne
Re: ant build [message #14874 is a reply to message #14847] Wed, 01 April 2009 09:37 Go to previous messageGo to next message
Solved. :)
There was a misunderstanding. My line read:
<parameter name="modelFile" file="../Models/some.uml"/>
which didn't work. But
works good (On Mac with and without the / ).
Anne
Re: ant build [message #14902 is a reply to message #14874] Wed, 01 April 2009 09:40 Go to previous messageGo to next message
Hi Anne,
Glad this helped :)
The problem is that in Windows you can easily tell if a path is relative
or not e.g. c:/file.txt is definitely absolute while /foo/file.txt is
relative. In Unix-based systems however the latter can be both (thus the
need for the file:/ prefix).
Dimitris
Anne Keller wrote:
> Solved. :)
> Anne
Re: ant build [message #14922 is a reply to message #14902] Wed, 01 April 2009 09:48 Go to previous messageGo to next message
Hi Dimitris,
Actually /foo/file.txt will always be an absolute path on a Unix-based
system. If you want a relative path you need to use foo/file.txt. I
think, Eclipse's standard path handling functions actually use this to
determine if a path is absolute or not, which is why I have found under
Windows you will sometimes have to use paths like /C:/... to make it
very clear to Eclipse that this is indeed an absolute path. Maybe at
some point someone will go in and make sure there is a platform-neutral,
consistently implemented way of identifying absolute vs. relative paths
in Java, but at this point everybody seems to be cooking their own.
Steffen
> Hi Anne,
> Glad this helped :)
> relative or not e.g. c:/file.txt is definitely absolute while
> /foo/file.txt is relative. In Unix-based systems however the latter
> can be both (thus the need for the file:/ prefix).
> Cheers,
> Dimitris
> Anne Keller wrote:
>> Solved. :)
>> Thanks,
>> Anne
Dr. rer. nat. Steffen Zschaler
Senior Research Associate
Lancaster University
Lancaster, United Kingdom
Email szschaler@acm.org
Phone +44 (01524) 510354
WWW http://www.steffen-zschaler.de/
Consider submitting to MDPLE, the 1st International Workshop on
Model-Driven Product Line Engineering
http://www.feasiple.de/workshop_en.html
Re: ant build [message #14938 is a reply to message #14922] Thu, 02 April 2009 08:44 Go to previous message
Hi Steffen,
I agree with everything you said :) I'll put this in my todo list for
further investigation.
Dimitris
Steffen Zschaler wrote:
> Hi Dimitris,
> Cheers,
> Steffen
>> Hi Anne,
>> Glad this helped :)
>> Cheers,
>> Dimitris
>> Anne Keller wrote:
>>> Solved. :)
>>> Thanks,
>>> Anne
Re: ant build [message #566306 is a reply to message #14727] Wed, 01 April 2009 06:33 Go to previous message
Hi Anne,
will work while
will not.
Dimitris
Anne Keller wrote:
> "loadModels:
> Anne
Re: ant build [message #566331 is a reply to message #14760] Wed, 01 April 2009 07:39 Go to previous message
Hi Dimitri,
I changed
to
Anne
Re: ant build [message #566354 is a reply to message #14789] Wed, 01 April 2009 07:45 Go to previous message
Hi Anne,
Dimitris
Anne Keller wrote:
> Hi Dimitri,
> I changed
> to
> Anne
Re: ant build [message #566366 is a reply to message #14817] Wed, 01 April 2009 09:13 Go to previous message
Hi Anne,
Dimitris
> Hi Anne,
> Cheers,
> Dimitris
> Anne Keller wrote:
>> Hi Dimitri,
>> I changed
>> to
>> Anne
Re: ant build [message #566383 is a reply to message #14847] Wed, 01 April 2009 09:37 Go to previous message
Solved. :)
Anne
Re: ant build [message #566399 is a reply to message #14874] Wed, 01 April 2009 09:40 Go to previous message
Hi Anne,
Glad this helped :)
Dimitris
Anne Keller wrote:
> Solved. :)
> Anne
Re: ant build [message #566407 is a reply to message #14902] Wed, 01 April 2009 09:48 Go to previous message
Hi Dimitris,
Steffen
> Hi Anne,
> Glad this helped :)
> Cheers,
> Dimitris
> Anne Keller wrote:
>> Solved. :)
>> Thanks,
>> Anne
Re: ant build [message #566428 is a reply to message #14922] Thu, 02 April 2009 08:44 Go to previous message
Hi Steffen,
Dimitris
> Hi Dimitris,
> Cheers,
> Steffen
>> Hi Anne,
>> Glad this helped :)
>> Cheers,
>> Dimitris
>> Anne Keller wrote:
>>> Solved. :)
>>> Thanks,
>>> Anne
Previous Topic:ant build
Next Topic:Problems View not Showing Markers from EVL
Current Time: Thu Oct 16 13:23:09 EDT 2025
Powered by FUDForum. Page generated in 0.07459 seconds
