Home » Eclipse Projects » Eclipse Platform » Compiling one file without building the project
Compiling one file without building the project [message #157092] Fri, 14 November 2003 15:27 Go to next message
Originally posted by: arajwani.lehman.com
How do I compile just one file without building the whole project. Just
saving the file is not compiling it. When I build the project it takes
very long. Is there a menu item or popup to request one file compilation.
Re: Compiling one file without building the project [message #157323 is a reply to message #157092] Sat, 15 November 2003 12:06 Go to previous message
Eclipse uses an incremental compiler. If you enable auto-build then it
will build the file upon save. If auto-build is disabled then you can
simply use Build All (Ctrl+B) which will build all necessary resources.
There's no command to explicitly build a single file.
Dani
Previous Topic:Class Cast Exception, can't get past ...
Next Topic:Native Library already loaded in another classloader
Current Time: Sat Sep 06 09:48:21 EDT 2025
Powered by FUDForum. Page generated in 0.03393 seconds
