Home » Eclipse Projects » GEF » Migrating to 3.x TransferDropTargetListener
Migrating to 3.x TransferDropTargetListener [message #157082] Sat, 06 November 2004 12:40 Go to next message
Originally posted by: Lamont_Gilbert.rigidsoftware.com
Looks like EditPartViewer no longer likes TransferDropTargetListener
from gef, and now only accepts
org.eclipse.jface.util.TransferDropTargetListener.
Is there any clean way to migrate my TransferDropTargetListener class
based on the gef version to the jface version?
Respectfully,
CL Gilbert
"Verily, verily, I say unto you, He that entereth not by the door() into
the sheepfold{}, but climbeth up some other *way, the same is a thief
and a robber."
GnuPG Key Fingerprint:
82A6 8893 C2A1 F64E A9AD 19AE 55B2 4CD7 80D2 0A2D
For a free Java interface to Freechess.org see
http://www.rigidsoftware.com/Chess/chess.html
Re: Migrating to 3.x TransferDropTargetListener [message #157091 is a reply to message #157082] Sat, 06 November 2004 12:46 Go to previous messageGo to next message
Well after deep investigation turns out the gef version is already based
on the jface version.
I wonder then why they kept the old method when you could eliminate it
without any issues? Was the behavior different?
(or has the gef version just changed itself to comply?)
My solution was just to cast the type to the jface version and that
forced it into the proper method.
Respectfully,
CL Gilbert
and a robber." John 10:1
Re: Migrating to 3.x TransferDropTargetListener [message #157245 is a reply to message #157091] Mon, 08 November 2004 10:08 Go to previous messageGo to next message
The old method and type remained for compatibility.
Re: Migrating to 3.x TransferDropTargetListener [message #157413 is a reply to message #157245] Tue, 09 November 2004 11:13 Go to previous messageGo to next message
What is the compatability issue if the new method accepts a supertype of
what the old method accepts? Or is this not exactly true?
Was their different functionality within them? Java being a
late-binding language, I would think this would not be a problem right?
Respectfully,
CL Gilbert
Re: Migrating to 3.x TransferDropTargetListener [message #157436 is a reply to message #157413] Tue, 09 November 2004 11:29 Go to previous messageGo to next message
I'm 99.9% sure you would get a method not found error. The .class file will
contain a call to the old method, and the VM does not go walking up the
supertype chain looking for a replacement method.
If all code was recompiled, then it would work without source changes.
Re: Migrating to 3.x TransferDropTargetListener [message #157474 is a reply to message #157436] Tue, 09 November 2004 21:16 Go to previous messageGo to next message
I think that is not correct. The VM does go walking up the supertype
chain looking for methods, that is what late binding is all about.
Unless you declared your method as final, java can not know before
runtime exactly what it needs to execute.
I just tested it, and unless my test was broken, this is true.
Respectfully,
CL Gilbert
Re: Migrating to 3.x TransferDropTargetListener [message #157482 is a reply to message #157474] Tue, 09 November 2004 22:02 Go to previous message
>> file will
My test was broken. You are 100% correct. The called method is
determined at compile time.
Respectfully,
CL Gilbert
Previous Topic:Editor -> MultiPageEditor
Next Topic:HTML widget control
Current Time: Tue Nov 04 19:20:53 EST 2025
Powered by FUDForum. Page generated in 0.03415 seconds
