Hide and Show Figure on the fly [message #157059] |
Sat, 06 November 2004 02:29  |
Originally posted by: jsk_lam.hotmail.com
I want to allow users to show and hide certain figures on the fly. Could
someone please show me how to make the figures visible and invisible
programmatically? Also, if I make a figure invisible then will those
connection links be automatically disappear as well?
SL.
Re: Hide and Show Figure on the fly [message #157282 is a reply to message #157156] |
Mon, 08 November 2004 10:39  |
Originally posted by: gaslade.yahoo.com
Unfortunately it is not quite as easy as setVisible(boolean). This
method will stop the part from visually show on the free form surface
but it is still there....there is still an edit part for it. This means
a couple of things
1. If any hidden parts are off the current view port the user can still
scroll the view port to these hidden parts.... and see nothing....which
is confusing
2. Accessibility gets screwed up. Although the parts do not show, you
can still use the key board to navigate to them and the screen reader
will still read what ever you have set up for it to read.
What you really need to do is fool the GEF framework into thinking that
there are no model objects for the hidden parts.... so no edit parts get
created.
The easy part of this is 'hidding' the nodes..Your container model
object needs to be smart in its implementation of getChildren(). It
needs to return a List of only children that are visible. But it will
obviously have to be doing some internal bookkeeping so that it knows
ALL of its children...both hidden and visible ones.
The slightly harder part is handling connections..... if you 'hide' a
node by tweaking the getChildren() method and one of the children you
hide has connections drawn to or from it then suddenly there will be no
source/target for the connection. GEF, by default will draw the the
connection with the missing source/target by attaching the broken end to
10,10 ( or is it 0,0 .... I can't remember ). So you end up with a
connection that either comes from or goes to nowhere. So you also have
to tweak the getSourceConnections() and getTargetConnections() methods
so that if the source or target have been hidden then the connection
model object does not get included in the returned list. Obviously if
you are supporting filtering of connection types then the user could
hide a connection type and your tweak would have to cater for this as well.
Once you have tweaked these methods you need to get them invoked. In my
case I have an object that knows when a filter setting has changed and
fires an event that any container objects are listening for. The
containers then figure out what their hidden and visible children are
and fire a ChildrenAddedEvent and then a FilterEvent of mine.
The ChildrenAddedEvent causes GEF to kick into action and the
corresponding edit part will refresh the children. This takes care of
the nodes
The FilterEvent is caught by the edit parts and handled by calling
refreshTargetConnections() and refreshSourceConnections(). This takes
care of the connections
Guy
Kiril Mitov wrote:
> Try figure.setVisible(boolean). - works for me.
> You can call it in the refreshVisuals() method of the editPart.
> SL wrote:
>> Could someone please show me how to make the figures visible and
>> invisible programmatically? Also, if I make a figure invisible then
>> will those connection links be automatically disappear as well?
>> Thanks,
>> SL.
FUDForum. Page generated in 0.02803 seconds
