Home » Eclipse Projects » Eclipse Platform » New user - Please help
New user - Please help [message #157020] Fri, 14 November 2003 13:29 Go to next message
I just started using eclipse. I am having some difficulties in creating
a java project. Please help.
Here is my problem. I am using eclipse 3.0. I want to create a java
project, but the source files and the output files should be in a file
system outside the project's resource hierarchy. I thought I should
create the source folder as a "Linked resource". I did that by creating
a new folder under the root resource. I did that from the projects
properties dialog, "Java Build Path", "Source" tab, I clicked on "Add
Folder" -> "Create New Folder". I specified the folder name and in the
advanced tab, I checked "Link to folder in file system" and specified
the actual path to where the source reside. Now in the "Package
Explorere" view, I see the various java packages. If I double click on
any of the java sources in the package, I get an error
"Cannot open default editor on <filename>. Editor could not be initialized.
But if I open the file using "open with" -> "text editor", I am able to
open the file. But I don't see any syntax highlighting etc. So my
questions are:
1. How can I create a java project where the source files and the class
files reside in a file system outside the project's resource hierarchy.
2. If "Linked resources" are the way the to do this, why am I not able
to open any files using Java editor.
Anand
Re: New user - Please help [message #157318 is a reply to message #157020] Sat, 15 November 2003 12:01 Go to previous messageGo to next message
Originally posted by: daniel.megert.gmx.net
Anand Narasimhan wrote:
> creating a java project. Please help.
> creating a new folder under the root resource. I did that from the
> projects properties dialog, "Java Build Path", "Source" tab, I clicked
> on "Add Folder" -> "Create New Folder". I specified the folder name
> and in the advanced tab, I checked "Link to folder in file system" and
> specified the actual path to where the source reside. Now in the
> "Package Explorere" view, I see the various java packages. If I double
> click on any of the java sources in the package, I get an error
> initialized.
> to open the file. But I don't see any syntax highlighting etc. So my
> questions are:
> class files reside in a file system outside the project's resource
> hierarchy.
Everything you did is correct. I assume you are using 3.0 M4. This is a
known problem which has been fixed in the current stream.
Dani
> Thanks
> Anand
Re: New user - Please help [message #157511 is a reply to message #157318] Sun, 16 November 2003 16:04 Go to previous messageGo to next message
Hi Dani,
Thanks for the reply. yes, I am using 3.0M4. What is the current stream?
Anand
>> initialized.
>> questions are:
>> hierarchy.
> Dani
>> Thanks
>> Anand
Re: New user - Please help [message #157528 is a reply to message #157511] Sun, 16 November 2003 17:22 Go to previous message
Builds newer than 3.0M4 (integration builds that occur weekly).
3.0M5 will come out next week.
Darins
"Anand Narasimhan" <anandn@cisco.com> wrote in message
news:3FB7E675.1090604@cisco.com...
> Hi Dani,
> Thanks
> Anand
Previous Topic:Replace Three Grey Bars with Nice Image (Wizard)?
Next Topic:Does Rich Client Platform available now?
Current Time: Sun Aug 31 11:39:18 EDT 2025
Powered by FUDForum. Page generated in 0.04981 seconds
