Home » Language IDEs » ServerTools (WTP) » "Dynamic Web Project" in 3.2.2
"Dynamic Web Project" in 3.2.2 [message #156962] Tue, 17 January 2006 13:46 Go to next message
Originally posted by: ns_dkerber.ns_WarrenRogersAssociates.com
I had to reinstall my OS, and decided to try the latest Eclipse/WST
combination instead of using my previous installation. Unfortunately, I
can't find what I need.
Using what it said on the WST web page, I installed:
Eclipse 3.2M4
WST 1.5M4
EMF 2.2.0M4
GEF 3.2M4
JEM 1.2M1
Then I started this installation of eclipse with a -clean, and tried to
import my projects. The plain java .jar project came in fine, but I
can't find where to import my "Dynamic Web Project". Has the name for
that changed, or am I missing something? I don't see the J2EE
perspective either, which was in my previous installation. That makes
me think I might be missing something for WST to work properly.
Any help appreciated!
Remove the ns_ from if replying by e-mail (but keep posts in the
newsgroups if possible).
Re: "Dynamic Web Project" in 3.2.2 [message #156978 is a reply to message #156962] Tue, 17 January 2006 14:05 Go to previous messageGo to next message
> Eclipse 3.2M4
> WST 1.5M4
> EMF 2.2.0M4
> GEF 3.2M4
> JEM 1.2M1
The WST does not contain the J2EE perspective nor support for
Dynamic Web Projects. You need the full WTP download instead.
WST = Web Standard Tools
JST = J2EE Standard Tools
WTP = WST + JST (for now)
- Nitin
Re: "Dynamic Web Project" in 3.2.2 - more info [message #156986 is a reply to message #156962] Tue, 17 January 2006 14:10 Go to previous messageGo to next message
When I check the status of the JST, I see a couple of errors:
Plug-in: "org.eclipse.jst.jsp.core" version: "1.0.100.v20060111-0015"
referenced by this feature is not included at runtime. Runtime includes
plug-in version "1.0.100.v20060111_0015" supplied by feature
"org.eclipse.jst.web_core.feature" version "1.0.0".
Plug-in: "org.eclipse.jst.jsp.ui" version: "1.0.100.v20060112-0325"
plug-in version "1.0.100.v20060112_0325" supplied by feature
"org.eclipse.jst.web_ui.feature" version "1.0.0".
There are similar problems in the WST section. How do I correct these?
Can I just fix the obvious punctuation errors?
In article <MPG.1e370594b9d8ea1f9896b2@news.eclipse.org>,
ns_dkerber@ns_WarrenRogersAssociates.com says...
> Eclipse 3.2M4
> WST 1.5M4
> EMF 2.2.0M4
> GEF 3.2M4
> JEM 1.2M1
Re: "Dynamic Web Project" in 3.2.2 [message #156993 is a reply to message #156978] Tue, 17 January 2006 14:16 Go to previous messageGo to next message
In article <dqjf4v$6fm$2@utils.eclipse.org>, nitind@us.ibm.com says...
> > Eclipse 3.2M4
> > WST 1.5M4
> > EMF 2.2.0M4
> > GEF 3.2M4
> > JEM 1.2M1
Sorry for the red-herring typo! It was actually wtp-1.5M4.zip which I
installed. There appear to be some typo's in the class names which are
causing the problem (see my -more message).
Re: "Dynamic Web Project" in 3.2.2 - more info [message #157047 is a reply to message #156986] Tue, 17 January 2006 17:17 Go to previous messageGo to next message
On Tue, 17 Jan 2006 14:10:49 -0500, David Kerber <ns_dkerber@ns_WarrenRo=
> referenced by this feature is not included at runtime. Runtime include=
s
I'm surpised none of "us" saw this as we tested M4 ... it might be becau=
se we all tested the "sdk" version
of the zip file? If you are able, you might try that ... and if it works=
, open a big bad bug on the non-sdk version!
That would be an embarrasing whole in our procedures!
Re: "Dynamic Web Project" in 3.2.2 - more info [message #157125 is a reply to message #157047] Wed, 18 January 2006 09:10 Go to previous message
In article <op.s3jmvkx1ac05ss@dmw2t23.raleigh.ibm.com>,
david_williams@us.ibm.com says...
> On Tue, 17 Jan 2006 14:10:49 -0500, David Kerber <ns_dkerber@ns_WarrenRogersAssociates.com> wrote:
> I'm surpised none of "us" saw this as we tested M4 ... it might be because we all tested the "sdk" version
> of the zip file? If you are able, you might try that ... and if it works, open a big bad bug on the non-sdk version!
I just finished installing again, this time from the SDK zips, and it's
showing pretty much the same errors. Do you still want me to post a
bug, or have you already taken care of it?
Previous Topic:WTP and Tomcat 3.0.28
Next Topic:Where to put utility jar in EJB or EAR project?
Current Time: Tue Jul 22 00:48:48 EDT 2025
Powered by FUDForum. Page generated in 0.04187 seconds
