Web App Libraries [message #156938] |
Tue, 17 January 2006 11:49  |
I am running Eclipse 3.1.1 with WTP 0.7 and I have found an odd occurence
when generating a Web Service.
I have an existing Web Service project that I have checked into CVS. I
checkout the service because the WSDL files that were used to create the
Web Service have changed and the project needs to be updated.
I then delete the old WSDL files from the WebContent and WebContent.wsdl
folders. I delete the old source code from the JavaSource directory.
I then inport the new WSDL files into the WebContent directory, selecct it
and create a new Web Service from the imported WSDL file. It creates a
WSDL in the WebContent.wsdl directory and the 6 java source files in the
Now I get an error message that I have never gotten before when generating
the Web Services: In the sourceSoapStub.java file
org.apache.axis.constants cannot be resolved error. Nothing has changed
between the old Web Service and the new one, the build path is still the
same.
I did a little more research and found that in the Web App Libraries
directory there were new jar files placed in there. However, there seems
to be an inconsistency, it looks like it added a wsdl4j-1.5.1.jar file but
it didn't delete the wsdl4j.jar 1.1. file that had existed before. There
are other files that it looks like it added updated versions without
deleting the old versions.
This seems to be the cause of the issue because if I delete the Web App
Libraries directory and the import external jar files and import the Web
Apps jar files from the Apache Axis file path (newer version) the errors
go away. Howver, I don't like doing it this way because the files are
not organized into a Web App Library, and if I try to import a new library
for this I don't get anything.
Can someone please provide a solution and/or explenation as to what is
going on and if there is a procedure to correct this?
Ben
Re: Web App Libraries [message #157008 is a reply to message #156938] |
Tue, 17 January 2006 15:19  |
I found the extra *.jar files in the WebContent/WEB-INF/lib directory of
my project if I look at it through Windows Explorer. If I delete the
duplicate *.jar files then the errors go away.
Again, I don't think this is the most efficient way of doing this. I
would be currious as to why these new files were added to this directory
when I ran the create new Web Services from the new WSDL file? Also,
where does it pull the new *.jar files from? Which directory etc...?
I hope this is useful information and would appreciate any insight that I
can get.
Ben
FUDForum. Page generated in 0.51571 seconds
