Home » Modeling » GMF (Graphical Modeling Framework) » diagram partitioning - wrong palette loaded
diagram partitioning - wrong palette loaded [message #156903] Wed, 24 October 2007 05:21 Go to next message
hi
this seems like a "small" thing but i dont find the fault:
i did an editor based on one ecore file and 2 graph,tool,map files
(based on usecase2 of norbert schöpke)
when i run the editor i can create an example. the deal is that in the
palette there are only the entries of the sub-model (which i cant add to
canvas - ok) but if i mouse-over the diagram surface i get the model
elements. so everything despite the palette entries is ok.
ideas?
thx in advance
hannes
Re: diagram partitioning - wrong palette loaded [message #156967 is a reply to message #156903] Wed, 24 October 2007 08:12 Go to previous messageGo to next message
Hi Hannes!
You definitely get this behaviour if you open your diagram
with the sub diagram editor.
You have a super diagram editor and a sub diagram editor.
If you select "Open with..." in the context menu of your
diagram file you are able to choose both editors. If you
choose the sub diagram editor you get the behaviour.
Maybe that is your problem.
Nicolai
I'm using an evaluation license of nemo since 51 days.
You should really try it!
http://www.malcom-mac.com/nemo
Re: diagram partitioning - wrong palette loaded [message #156972 is a reply to message #156967] Wed, 24 October 2007 08:37 Go to previous messageGo to next message
Hej Nicolai,
you definitley got the point that the wrong editor is loaded/dominant.
Now here comes the crucial point: if i go for "Open with.." the editors
are both checked. They do have different names but maybe on the basic
level somewhere their identifiers are same.. (thats my suggestion)
so it maybe a wrong value in one of the gmfgen files....
any ideas world?
thx anyways!
by hannes
Nicolai Kamenzky schrieb:
> Hi Hannes!
> Cheers,
> Nicolai
Re: diagram partitioning - wrong palette loaded [message #157060 is a reply to message #156972] Wed, 24 October 2007 15:43 Go to previous messageGo to next message
I have decided to remove the open with entry of my sub
editor since you won't be able to directly open the
diagram file with the sub editor anyway.
But I don't know how to remove the entry because I didn't
work on that yet.
If you know how to do that please tell it to me. :)
Nicolai
Re: diagram partitioning - wrong palette loaded [message #158537 is a reply to message #157060] Tue, 06 November 2007 10:28 Go to previous message
ok thats what i found out lately about this topic:
when i was creating models quick and dirty and this palette/editor
problem occured it came from the Gen Editor View property "ID" from the
sub-gmfgen was the same as the one of the top-models .gmfgen. You can
change it by changing the "Class Name" property of Gen Editor View....
(in the sub..)
greetings
> work on that yet.
> Cheers,
> Nicolai
Previous Topic:how to change the width limit for a compartment
Next Topic:propsheet.ecore problem in CVS
Current Time: Wed Nov 05 03:59:55 EST 2025
Powered by FUDForum. Page generated in 0.03600 seconds
