Home » Language IDEs » Java Development Tools (JDT) » How do I configure ant for the sources of Thinking in Java's book?
How do I configure ant for the sources of Thinking in Java's book? [message #156896] Sat, 01 May 2004 05:27 Go to next message
Originally posted by: gabalin.yahoo.com
I have downloaded the sources from Thinking in Java's book written by
Bruce Eckels and I've used the Eclipse editor to run some classes. My
question is
how to include and build the classes that come with these sources inside
Eclipse?. I've tried to used the External tool from Eclipse but it
didn't work. The error that I have is
JDK.version.check:
[javac] Compiling 1 source file
[javac] BUILD FAILED: file:C:/Program
Files/eclipse/plugins/Code/c02/build.xml:31: Unable to find a javac
compiler;
com.sun.tools.javac.Main is not on the classpath.
Perhaps JAVA_HOME does not point to the JDK
I know that I have to set the CLASSPATH but I don't know how. It is
clear that Java doesn't recognize the path indicated by the .xml file.
So, could you explain me which CLASSPATH file update and how must I
accomplish the task.
However the rest of the classes that come with Eclipse are well pointed
out by the external tool.
Pepe
Re: How do I configure ant for the sources of Thinking in Java's book? [message #156920 is a reply to message #156896] Sat, 01 May 2004 11:51 Go to previous message
Window>Preferences>Ant>Runtime>Classpath
Add the appropriate tools.jar from your JDK install
http://www.eclipse.org/eclipse/faq/eclipse-faq.html#users_16
Or simple start Eclipse using the -vm option to point to your JDK install
http://help.eclipse.org/help21/index.jsp?topic=/org.eclipse. platform.doc.user/tasks/running_eclipse.htm
Or (in 3.0 later builds) set your JAVA_HOME environment variable to point to
your JDK install
HTH
Darins
"Pepe Sanchez" <gabalin@yahoo.com> wrote in message
news:c6vqhs$vgh$1@eclipse.org...
> question is
> JDK.version.check:
> compiler;
> Pepe
Previous Topic:add my own content assist to java editor?
Next Topic:default editor not found
Current Time: Sat Jul 19 10:10:48 EDT 2025
Powered by FUDForum. Page generated in 0.07302 seconds
