Home » Language IDEs » Java Development Tools (JDT) » patch of .class files in 3.0 M8
patch of .class files in 3.0 M8 [message #156871] Sat, 01 May 2004 02:58 Go to next message
Originally posted by: mravi.web.de
I just migrated from Eclipse 2.1.2 to 3.0 M8.
In 2.1.2, when I create a project, by default, it creates a src and bin
folder and puts all the classes in the bin folder.
Now, the src files are directly in the <workspacename> folder instead of
<workspacename>/src. With the default settings, I cud not find the
..class files anywhere. But when the unchecked clean output folders on
full build, I can see the .class files in the same folder as the source
files.
Is there any way, I can configure 3.0 to have all the class files to a
seperate folder?
Thanx in advance.
Ravi.
Re: path of .class files in 3.0 M8 [message #156880 is a reply to message #156871] Sat, 01 May 2004 03:00 Go to previous messageGo to next message
Sorry for the typo in the subject. I meant path and not patch.
Ravi.
Ravi Mutyala wrote:
> files.
> seperate folder?
> Thanx in advance.
> Ravi.
Re: path of .class files in 3.0 M8 [message #156904 is a reply to message #156880] Sat, 01 May 2004 05:44 Go to previous message
Go to the properties of your project
java build path settings
there you can set source/output folders
> Ravi.
> Ravi Mutyala wrote:
>> bin folder and puts all the classes in the bin folder.
>> of <workspacename>/src. With the default settings, I cud not find the
>> source files.
>> seperate folder?
>> Thanx in advance.
>> Ravi.
Previous Topic:enable assertions by default?
Next Topic:add my own content assist to java editor?
Current Time: Wed Jul 09 08:39:24 EDT 2025
Powered by FUDForum. Page generated in 0.06022 seconds
