Home » Eclipse Projects » GEF » org.eclipse.draw2d.examples?
org.eclipse.draw2d.examples? [message #156852] Thu, 04 November 2004 13:51 Go to next message
This is a multipart message in MIME format.
--=_alternative 0067927085256F42_=
Content-Type: text/plain; charset="US-ASCII"
I have GEF installed and successfully ran the Demo4 example. I am trying
to run the SimpleTreeExample.java file, but am finding that I cannot
import org.eclipse.draw2d.examples.AbstractExample;
I've clearly got all the other draw2d stuff such as
import org.eclipse.draw2d.ColorConstants;
import org.eclipse.draw2d.IFigure;
import org.eclipse.draw2d.PositionConstants;
I am new to eclipse, but I whatever I used to search in the archive didn't
turn up the answer (though it may well be in there). Where do these
examples live?
Donna
Content-Type: text/html; charset="US-ASCII"
<br><font size=2 face="sans-serif">I have GEF installed and successfully
ran the Demo4 example. I am trying to run the SimpleTreeExample.java file,
but am finding that I cannot </font>
<br>
<br><font size=2 face="sans-serif">import org.eclipse.draw2d.examples.AbstractExample;</font>
<br>
<br><font size=2 face="sans-serif">I've clearly got all the other draw2d
stuff such as</font>
<br><font size=2 face="sans-serif">import org.eclipse.draw2d.ColorConstants;</font>
<br><font size=2 face="sans-serif">import org.eclipse.draw2d.IFigure;</font>
<br><font size=2 face="sans-serif">import org.eclipse.draw2d.PositionConstants;</font>
<br>
<br><font size=2 face="sans-serif">I am new to eclipse, but I whatever
I used to search in the archive didn't turn up the answer (though it may
well be in there). Where do these examples live?</font>
<br>
<br><font size=2 face="sans-serif">Thanks</font>
<br><font size=2 face="sans-serif">Donna</font>
--=_alternative 0067927085256F42_=--
Re: org.eclipse.draw2d.examples? [message #156867 is a reply to message #156852] Thu, 04 November 2004 18:39 Go to previous messageGo to next message
------=_NextPart_000_000F_01C4C29D.A239AF80
charset="iso-8859-1"
Are you saying that you can't import AbstractExample? How are you =
trying to run SimpleTreeExample? If you're copying the code into your =
own plugin/project and trying to run from there, make sure your =
plugin.xml requires the org.eclipse.draw2d.examples project (or that =
that project is on the build path).
The easiest way to run the SmallTreeExample would be:
1) Right-click in Package Explorer, Import -> External Plugins and =
Fragments and import the org.eclipse.draw2d.examples plug-in.
2) Find SimpleTreeExample in the PackageExplorer, right-click and Run -> =
Java Application
<gresh@us.ibm.com> wrote in message news:cmdtna$1dv$1@eclipse.org...
I have GEF installed and successfully ran the Demo4 example. I am =
trying to run the SimpleTreeExample.java file, but am finding that I =
cannot=20
import org.eclipse.draw2d.examples.AbstractExample;=20
I've clearly got all the other draw2d stuff such as=20
import org.eclipse.draw2d.ColorConstants;=20
import org.eclipse.draw2d.IFigure;=20
import org.eclipse.draw2d.PositionConstants;=20
I am new to eclipse, but I whatever I used to search in the archive =
didn't turn up the answer (though it may well be in there). Where do =
these examples live?=20
Thanks=20
Donna
<HTML><HEAD>
charset=3Diso-8859-1">
<META content=3D"MSHTML 6.00.2800.1476" name=3DGENERATOR>
<STYLE></STYLE>
</HEAD>
<BODY bgColor=3D#ffffff>
<DIV><FONT face=3DArial size=3D2>Are you saying that you can't import=20
AbstractExample?&nbsp; How are you trying to run =
SimpleTreeExample?&nbsp; If=20
you're copying the code into your own plugin/project and trying to run =
from=20
there, make sure your plugin.xml&nbsp;requires the =
org.eclipse.draw2d.examples=20
project (or that that project is on the build path).</FONT></DIV>
<DIV><FONT face=3DArial size=3D2></FONT>&nbsp;</DIV>
<DIV><FONT face=3DArial size=3D2>The easiest way to run the =
SmallTreeExample would=20
be:</FONT></DIV>
<DIV><FONT face=3DArial size=3D2>1) Right-click in Package Explorer, =
Import -&gt;=20
External Plugins and Fragments and import the =
plug-in.</FONT></DIV>
<DIV><FONT face=3DArial size=3D2>2) Find SimpleTreeExample in the =
PackageExplorer,=20
right-click and Run -&gt;&nbsp;Java Application</FONT></DIV>
<BLOCKQUOTE=20
<DIV>&lt;<A href=3D"mailto:gresh@us.ibm.com">gresh@us.ibm.com</A>&gt; =
wrote in=20
message <A=20
href=3D"news:cmdtna$1dv$1@eclipse.org">news:cmdtna$1dv$1@eclipse.org</A>.=
...</DIV><BR><FONT=20
face=3Dsans-serif size=3D2>I have GEF installed and successfully ran =
the Demo4=20
example. I am trying to run the SimpleTreeExample.java file, but am =
finding=20
that I cannot </FONT><BR><BR><FONT face=3Dsans-serif size=3D2>import=20
org.eclipse.draw2d.examples.AbstractExample;</FONT> <BR><BR><FONT=20
face=3Dsans-serif size=3D2>I've clearly got all the other draw2d stuff =
such=20
as</FONT> <BR><FONT face=3Dsans-serif size=3D2>import=20
org.eclipse.draw2d.ColorConstants;</FONT> <BR><FONT face=3Dsans-serif=20
size=3D2>import org.eclipse.draw2d.IFigure;</FONT> <BR><FONT =
size=3D2>import org.eclipse.draw2d.PositionConstants;</FONT> =
<BR><BR><FONT=20
face=3Dsans-serif size=3D2>I am new to eclipse, but I whatever I used =
to search in=20
the archive didn't turn up the answer (though it may well be in =
there). Where=20
do these examples live?</FONT> <BR><BR><FONT face=3Dsans-serif=20
size=3D2>Thanks</FONT> <BR><FONT face=3Dsans-serif=20
size=3D2>Donna</FONT></BLOCKQUOTE></BODY></HTML>
------=_NextPart_000_000F_01C4C29D.A239AF80--
Re: org.eclipse.draw2d.examples? [message #156977 is a reply to message #156867] Fri, 05 November 2004 07:50 Go to previous messageGo to next message
--=_alternative 00468E5785256F43_=
Yes the problem is that I can't import AbstractExample. My problem is that
I don't know where the org.eclipse.draw2d.examples project is. When I try
the Import->External Plugins..... I do not see that as a choice. I have
installed the GEF examples.... is there somewhere else I need to look?
If I look in the eclipse\plugins directory I see only
org.eclipse.draw2d.doc.isv_3.0.1
org.eclipse.draw2d_3.0.1
So where do I download the draw2d examples plugin from?
Thanks in advance
Donna
<br><font size=2 face="sans-serif">Yes the problem is that I can't import
AbstractExample. My problem is that I don't know where the org.eclipse.draw2d.examples
project is. When I try the Import-&gt;External Plugins..... I do not see
that as a choice. I have installed the GEF examples.... is there somewhere
else I need to look?</font>
<br>
<br><font size=2 face="sans-serif">If I look in the eclipse\plugins directory
I see only</font>
<br>
<br><font size=2 face="sans-serif">org.eclipse.draw2d.doc.isv_3.0.1 </font>
<br><font size=2 face="sans-serif">org.eclipse.draw2d_3.0.1</font>
<br>
<br><font size=2 face="sans-serif">So where do I download the draw2d examples
plugin from? </font>
<br><font size=2 face="sans-serif">Thanks in advance</font>
--=_alternative 00468E5785256F43_=--
Re: org.eclipse.draw2d.examples? [message #157001 is a reply to message #156977] Fri, 05 November 2004 09:33 Go to previous message
--=_alternative 0050022205256F43_=
Never mind, I found the answer in a combination of two earlier posts:
There are also some code snippets in the package
org.eclipse.draw2d.examples, which is part of the dev.eclipse.org
/home/tools repository. However, these examples are not released as part
of
the GEF/Draw2d plug-ins.
You can also check out the draw2d and GEF examples in the CVS repository.
Here's how to connect to the GEF repository:
http://dev.eclipse.org/viewcvs/index.cgi/%7Echeckout%7E/gef- home/developer/faq.html?cvsroot=Tools_Project#install_cvs
Donna
<br><font size=2 face="sans-serif">Never mind, I found the answer in a
combination of two earlier posts:</font>
<br>
<br><font size=2><tt>There are also some code snippets in the package<br>
org.eclipse.draw2d.examples, which is part of the dev.eclipse.org<br>
of<br>
the GEF/Draw2d plug-ins.</tt></font>
<br>
<br><font size=2><tt>You can also check out the draw2d and GEF examples
in the CVS repository.<br>
Here's how to connect to the GEF repository:<br>
http://dev.eclipse.org/viewcvs/index.cgi/%7Echeckout%7E/gef- home/developer/faq.html?cvsroot=Tools_Project#install_cvs<br>
</tt></font>
<br>
--=_alternative 0050022205256F43_=--
Previous Topic:PaletteModeDialog in LogicExample
Next Topic:Adding Label to PolylineDecoration
Current Time: Sat Jul 26 14:05:45 EDT 2025
Powered by FUDForum. Page generated in 0.17162 seconds
