Home » Language IDEs » Java Development Tools (JDT) » enable assertions by default?
enable assertions by default? [message #156851] Fri, 30 April 2004 19:22 Go to next message
Hi all,
is there a way to enable assertions by default when "Run..."-ning
programs from within eclipse?
I know that I can add a "-enableassertions" in the VM arguments field
on the arguments tab of an application's Run config., but that's than
only valid for that particular applications (or actually only that
particular Run-setup). What I am looking for is to enable assertions
by default for ALL programs being run (or debugged) via eclipse.
Michael
Re: enable assertions by default? [message #156859 is a reply to message #156851] Fri, 30 April 2004 19:44 Go to previous message
In the latest 3.0 builds:
Window>Preferences>Java>Installed JRES>Edit
You can set Default VM Arguments for each installed JRE
HTH
Darins
"Michael Moser" <mmo@zurich.ibm.com> wrote in message
news:c6umn0$6u8$1@eclipse.org...
> Hi all,
> Michael
Previous Topic:is there a way to use ordinary cursor and smart indent at the same time?
Next Topic:patch of .class files in 3.0 M8
Current Time: Fri Jul 18 22:47:09 EDT 2025
Powered by FUDForum. Page generated in 0.03324 seconds
