Home » Newcomers » Newcomers » Eclipse 3.0 - unable to update to 3.0.1- third try at getting help from newsgroup
Eclipse 3.0 - unable to update to 3.0.1- third try at getting help from newsgroup [message #156785] Wed, 14 June 2006 12:22 Go to next message
Originally posted by: intrader.aol.com
Problem is that Eclipse is unable to create a manifest file.
The message I see is:
Start of message in next line...
Unable to complete action for feature "Eclipse Project SDK" due to errors.
  Unable to complete action for feature "Eclipse Platform " due to errors.
    Unable to create file
"/usr/share/eclipse/plugins/org.apache.ant_1.6.2/
META-INF/MANIFEST1149005493122.MF".
[/usr/share/eclipse/plugins/org.apache.ant_1.6.2/
(No such file or directory)]
"/usr/share/eclipse/plugins/org.apache.ant_1.6.2/META-INF/
[/usr/share/eclipse/plugins/org.apache.ant_1.6.2/META-INF/
End of message.
I would like to upgrade to 3.2 if possible, but the choice is not available
through the update feature.
P.S. I have tried this newsgroup for a couple of weeks on this issue with no
resolution.
Re: Eclipse 3.0 - unable to update to 3.0.1- third try at getting help from newsgroup [message #156833 is a reply to message #156785] Wed, 14 June 2006 14:31 Go to previous messageGo to next message
> Unable to complete action for feature "Eclipse Platform" due to errors.
> End of message.
> Thanks
> resolution.
I don't think you can upgrade directly to 3.2 via the Updater, since 3.2
is still not fully released. You'd probably have to download it
separately and either install it separately or else delete your current
eclipse directory and replace it with the new 3.2 one.
Re: Eclipse 3.0 - unable to update to 3.0.1- third try at getting help from newsgroup [message #156847 is a reply to message #156833] Wed, 14 June 2006 15:03 Go to previous messageGo to next message
>> errors.
>> End of message.
>> available through the update feature.
>> Thanks
>> no resolution.
Thanks for that information.
If I understand you correctly, I need to manually update by deleting the
current eclipse directory and replace with the new one. Would I not have
the same problems with the manifest that I mention with the automatic
update to 3.0.1 (the only offering by the update mechanism).
Re: Eclipse 3.0 - unable to update to 3.0.1- third try at getting help from newsgroup [message #156910 is a reply to message #156847] Wed, 14 June 2006 20:46 Go to previous messageGo to next message
>>>errors.
>>>End of message.
>>>Thanks
>>>no resolution.
By the very numbers you should see that 3.0=>3.0.1, 3.0=>3.1, and
3.0=>3.2 are quite different levels of complexity. Yes, for getting 3.2
I would recommend starting from an entirely fresh/clean download before
using the Update Manager to get the rest of what you want from the
Callisto projects. That doesn't mean you have to delete the current
directory and replace it... I have no problem with having multiple
versions of Eclipse on my system, even working with the same projects,
as long as I keep the versions in distinctly different locations (both
physically, on the disk, and logically in my own mind!).
RDS
Randy D. Smith randy (dot) d (dot) smith (at) intel (dot) com
Eclipse TPTP Committer, Platform Proj (data collection/agent controller)
Re: Eclipse 3.0 - unable to update to 3.0.1- third try at getting help from newsgroup [message #156948 is a reply to message #156910] Thu, 15 June 2006 02:15 Go to previous message
>>>>errors.
>>>> errors.
>>>>End of message.
>>>>Thanks
>>>>with no resolution.
I will definetelly consider keeping multiple version as I don't want to
loose the capability I have in 3.0.
I would want to solve the problem with creation of the manifest though,
because without a solution, I am not able to get the version that the
updater find 3.0.1.
Thanks so much for the information you provided.
Previous Topic:Is there a way to hide comments?
Next Topic:Eclipse on a webserver
Current Time: Fri Nov 21 09:40:57 EST 2025
Powered by FUDForum. Page generated in 0.09978 seconds
