| CCE during Annotated Java Import [message #14685] |
Mon, 22 May 2006 15:35  |
--------------050904080507010703060603
I get the following ClassCastException when I try to create a model using
File->New->EMF Model->Annotated Java
I have one java source on the src tree which is attached here. This
source is exactly same as in case of Derby where Synonym is added to
Derby model.
Anyone tried creating a EMF model for DTP from Annotated Java source ?
Anthos
!ENTRY org.eclipse.emf.importer.java 2 0 2006-05-23 05:08:05.640
!MESSAGE org.eclipse.emf.ecore.impl.EFactoryImpl
!STACK 0
java.lang.ClassCastException: org.eclipse.emf.ecore.impl.EFactoryImpl
org.eclipse.emf.importer.java.builder.JavaEcoreBuilder.used( JavaEcoreBuilder.java:485)
org.eclipse.emf.importer.java.builder.JavaEcoreBuilder.used( JavaEcoreBuilder.java:508)
org.eclipse.emf.importer.java.builder.JavaEcoreBuilder.analy seProject(JavaEcoreBuilder.java:306)
org.eclipse.emf.importer.java.builder.JavaEcoreBuilder.compu teEPackages(JavaEcoreBuilder.java:456)
org.eclipse.emf.importer.java.JavaImporter.doComputeEPackage s(JavaImporter.java:82)
org.eclipse.emf.importer.ModelImporter.computeEPackages(Mode lImporter.java:482)
org.eclipse.emf.importer.java.ui.JavaPackagePage.computeEPac kages(JavaPackagePage.java:106)
org.eclipse.emf.importer.java.ui.JavaPackagePage$2.execute(J avaPackagePage.java:81)
org.eclipse.ui.actions.WorkspaceModifyOperation$1.run(Worksp aceModifyOperation.java:101)
at org.eclipse.core.internal.resources.Workspace.run(Workspace. java:1737)
org.eclipse.ui.actions.WorkspaceModifyOperation.run(Workspac eModifyOperation.java:113)
org.eclipse.jface.operation.ModalContext.runInCurrentThread( ModalContext.java:369)
at org.eclipse.jface.operation.ModalContext.run(ModalContext.ja va:313)
at org.eclipse.jface.wizard.WizardDialog.run(WizardDialog.java: 851)
org.eclipse.emf.importer.java.ui.JavaPackagePage.computeEPac kages(JavaPackagePage.java:96)
org.eclipse.emf.importer.java.ui.JavaPackagePage$1.run(JavaP ackagePage.java:59)
at org.eclipse.swt.widgets.RunnableLock.run(RunnableLock.java:3 5)
org.eclipse.swt.widgets.Synchronizer.runAsyncMessages(Synchr onizer.java:123)
at org.eclipse.swt.widgets.Display.runAsyncMessages(Display.jav a:3325)
at org.eclipse.swt.widgets.Display.readAndDispatch(Display.java :2971)
at org.eclipse.jface.window.Window.runEventLoop(Window.java:820 )
at org.eclipse.jface.window.Window.open(Window.java:796)
at org.eclipse.ui.actions.NewWizardAction.run(NewWizardAction.j ava:181)
at org.eclipse.jface.action.Action.runWithEvent(Action.java:499 )
org.eclipse.jface.action.ActionContributionItem.handleWidget Selection(ActionContributionItem.java:539)
org.eclipse.jface.action.ActionContributionItem.access$2(Act ionContributionItem.java:488)
org.eclipse.jface.action.ActionContributionItem$5.handleEven t(ActionContributionItem.java:400)
at org.eclipse.swt.widgets.Widget.sendEvent(Widget.java:928)
at org.eclipse.swt.widgets.Display.runDeferredEvents(Display.ja va:3348)
at org.eclipse.swt.widgets.Display.readAndDispatch(Display.java :2968)
at org.eclipse.ui.internal.Workbench.runEventLoop(Workbench.jav a:1914)
at org.eclipse.ui.internal.Workbench.runUI(Workbench.java:1878)
org.eclipse.ui.internal.Workbench.createAndRunWorkbench(Work bench.java:419)
at org.eclipse.ui.PlatformUI.createAndRunWorkbench(PlatformUI.j ava:143)
at org.eclipse.ui.internal.ide.IDEApplication.run(IDEApplicatio n.java:95)
org.eclipse.core.internal.runtime.PlatformActivator$1.run(Pl atformActivator.java:78)
org.eclipse.core.runtime.internal.adaptor.EclipseAppLauncher .runApplication(EclipseAppLauncher.java:92)
org.eclipse.core.runtime.internal.adaptor.EclipseAppLauncher .start(EclipseAppLauncher.java:68)
org.eclipse.core.runtime.adaptor.EclipseStarter.run(EclipseS tarter.java:400)
org.eclipse.core.runtime.adaptor.EclipseStarter.run(EclipseS tarter.java:177)
at org.eclipse.core.launcher.Main.invokeFramework(Main.java:336 )
at org.eclipse.core.launcher.Main.basicRun(Main.java:280)
at org.eclipse.core.launcher.Main.run(Main.java:977)
at org.eclipse.core.launcher.Main.main(Main.java:952)
name="MaterializedView.java"
Content-Disposition: inline;
filename="MaterializedView.java"
package oracle.dbtools.modelbase;
import org.eclipse.datatools.modelbase.sql.schema.SQLObject;
import org.eclipse.datatools.modelbase.sql.tables.ViewTable;
* @model
public interface MaterializedView extends ViewTable, SQLObject {
* @model
ViewTable getView();
* @model
void setView(ViewTable value);
--------------050904080507010703060603--
| Re: CCE during Annotated Java Import [message #15430 is a reply to message #14866] |
Mon, 29 May 2006 13:10  |
Anil,
In order to support a scenario where you want to use @model annotations
to extend a model installed in the development environment I've opened
https://bugs.eclipse.org/bugs/show_bug.cgi?id=144254 and committed the
changes for today's EMF 2.2.0RC6 build. With these changes, if you
create an Empty EMF Project, the wizard will produce a skeleton
MANIFEST.MF which you can edit to depend on the SQL model plugin. Once
you have that dependency (and the DTP guys register their model in the
runtime, as I spelled out in my other notes) the SQL model's GenModel
will automatically be processed to resolve references to SQL model so
you'll be able to use either direct editing of an Ecore model or @model
annotations to extend the SQL model...
Anil T Samuel wrote:
> Hi Ed
> That didnot make much sense to me. If you tell me what I did wrong
> then that would help. I followed the EMF whitepapers / docs to try
> this procedure of creating a EMF model, where it creates both .ecore
> and .genmodel.
> If I try creating a New EMF model using File->New->EMF Model wizard
> then that generates only .genmodel.
> Regards
> Anthos
> Ed Merks wrote:
>> Anil,
>> I can't imagine how the model could end up with an EFactoryImpl as
>> the root object:
>> public void used(EModelElement modelElement)
>> EPackage ePackage =
>> (EPackage)EcoreUtil.getRootContainer(modelElement);
>> The method is only ever called with an EClassifier or an
>> EStructuralFeature, and neither can be contained by an EFactory...
>> It's odd to put @model on your setters.
>>> Hi
>>> using
>>> Derby model.
>>> Regards
>>> Anthos
>>> !STACK 0
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at sun.reflect.NativeMethodAccessorImpl.invoke0(Native Method)
>>> at sun.reflect.NativeMethodAccessorImpl.invoke(Unknown Source)
>>> at sun.reflect.DelegatingMethodAccessorImpl.invoke(Unknown Source)
>>> at java.lang.reflect.Method.invoke(Unknown Source)
>>> * @model
>>> * @model
>>> * @model
| Re: CCE during Annotated Java Import [message #578090 is a reply to message #14685] |
Tue, 23 May 2006 08:22  |
--------------060401080906010501000403
Anil,
I can't imagine how the model could end up with an EFactoryImpl as the
root object:
EPackage ePackage =
> Hi
> Derby model.
> Regards
> Anthos
> !STACK 0
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> * @model
> * @model
> * @model
<html>
<head>
</head>
Anil,<br>
<br>
root object:<br>
<blockquote> public void used(EModelElement modelElement)<br>
{<br>
EPackage ePackage =
(EPackage)EcoreUtil.getRootContainer(modelElement);<br>
</blockquote>
EStructuralFeature, and neither can be contained by an EFactory...<br>
<br>
It's odd to put @model on your setters.<br>
<br>
<br>
<blockquote cite="mid4472129A.2070404@oracle.com" type="cite">Hi
<br>
<br>
using
<br>
<br>
<br>
<br>
<br>
Derby model.
<br>
<br>
<br>
<br>
<br>
Anthos
<br>
<br>
<br>
<br>
!STACK 0
<br>
<br>
<br>
<br>
<br>
<br>
<br>
<br>
<br>
<br>
<br>
<br>
<br>
<br>
<br>
<br>
<br>
<br>
<br>
<br>
<br>
<br>
<br>
<br>
<br>
<br>
<br>
<br>
<br>
<br>
<br>
<br>
<br>
<br>
<br>
<br>
<br>
<br>
<br>
<br>
<br>
<br>
<br>
<br>
<br>
<br>
<br>
<br>
<br>
<br>
<br>
<br>
<br>
<br>
<pre wrap="">
<hr size="4" width="90%">
* @model
* @model
* @model
</pre>
</blockquote>
<br>
</body>
</html>
--------------060401080906010501000403--
| Re: CCE during Annotated Java Import [message #578223 is a reply to message #14717] |
Wed, 24 May 2006 21:27  |
Hi Ed
That didnot make much sense to me. If you tell me what I did wrong then
that would help. I followed the EMF whitepapers / docs to try this
procedure of creating a EMF model, where it creates both .ecore and
..genmodel.
If I try creating a New EMF model using File->New->EMF Model wizard then
Anthos
Ed Merks wrote:
> Anil,
> root object:
> EPackage ePackage =
>> Hi
>> Derby model.
>> Regards
>> Anthos
>> !STACK 0
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> * @model
>> * @model
>> * @model
| Re: CCE during Annotated Java Import [message #578522 is a reply to message #14866] |
Anil,
> Hi Ed
> and .genmodel.
> Regards
> Anthos
> Ed Merks wrote:
>> Anil,
>> the root object:
>> EPackage ePackage =
>>> Hi
>>> using
>>> Derby model.
>>> Regards
>>> Anthos
>>> !STACK 0
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> * @model
>>> * @model
>>> * @model
FUDForum. Page generated in 0.04766 seconds
