Home » Archived » BIRT » rcp + birt engine
rcp + birt engine [message #156724] Thu, 27 April 2006 08:16 Go to next message
Originally posted by: em.microcraft.se
First I like to thank the BIRT team for the great tools you put in our
hands!
We have already integrated the report engine i our web-applications and
now we are taking the next step.
We are trying to integrate the engine part of birt in our existing
rcp-application. At this date we don't want the designer and viewer,
only the engine so we can generate html and pdf-reports from existing
report design files (.rptdesign).
Our first approach would be to just add the birt-runtime-2_0_1/Report
Engine to the plugin that needs to generate reports.
We have a problem with that approach because we believe that it should
be possible to just add dependencies on the required plugins (everything
is plugins i eclipse, why add the report engine as something else?).
This would probably make it easier to perform updates in future because
we don't have to distribute the birt report-engine within the plugin
that is using it.
So after reading a bit about the plugings that BIRT consists of and what
dependencies they have to each other I ended up adding the following
plugins to our rcp application target:
org.eclipse.birt.core_2.0.1
org.eclipse.birt.data.oda_2.0.2
org.eclipse.birt.data_2.0.1
org.eclipse.birt.report.engine.emitter.html_2.0.1
org.eclipse.birt.report.engine.emitter.pdf_2.0.1
org.eclipse.birt.report.engine_2.0.1
org.eclipse.birt.report.model_2.0.1
org.eclipse.datatools.connectivity.oda_3.0.0
org.junit_3.8.1
....and I added dependencies on these plugins in the plugin that will be
responsible for generating reports.
We use a scripted data source in our reports and when I try to execute a
report, Birt don't seem to know about my java-classes (see log below).
How can I solve this classloadning problem? (if it is a class loading
problem...) And last but not least do you think it is possible to
integrate BIRT the way I'm trying to do? Or should I give up and go back
to the thread "Re: Integrate Birt in RCP" from 2006-03-24 and follow the
steps there despite i dislike to integrate birt in that way?
Ideas?
Best regards
Erik Mellegård
Part of log when running report:
FINARE: Start to execute
2006-apr-26 16:51:56 org.eclipse.birt.data.engine.script.ScriptEvalUtil
evaluateJSExpr
FINARE: ENTRY evaluateJSExpr() scriptText=function __bm_OPEN() {
//Initialize the report
var orderLocal;
var language;
var srvurl;
if(typeof support == 'undefined'){
//Preview mode. this section will not run on the web-server. This
will run in the RCP-app
garp =
Packages.com.garp.utils.InitialReference.getInitialReference ( "127.0.0.1",4444);
user = garp.getUser("XXX","");
factory = user.getB2BBaseFactory();
b2buser = factory.getUserInBolag("100","007","100","100");
orderLocal = b2buser.order();
language=" ";
//for images
srvurl="http://127.0.0.1:8080/b2b";
} else {
//Web-server mode. This is what is running on the web-server
orderLocal = support.order;
language=session.getAttribute("language");
srvurl =
"http://"+request.getServerName()+":"+request.getServerPort()+request.getContextPath();
order=orderLocal;
serverurl=srvurl;
lang=language;
onr = params['onr'];
oc = order.getOrderConfirm(onr);
odi = order.getOrderDetails(onr);
nf = new Packages.com.garp.www.NumberFormat();
lh = new Packages.com.garp.www.LangHandler();
i = odi.length;
count = 0;
} , source=DataSet[garpOrderconfirm].__bm_OPEN, lineNo=1
evaluateJSExpr
FINARE: ENTRY evaluateJSExpr() scriptText=__bm_OPEN(),
2006-apr-26 16:51:56 org.eclipse.birt.core.script.JavascriptEvalUtil
wrapRhinoException
FIN: Unexpected RhinoException.
Source=DataSet[garpOrderconfirm].__bm_OPEN, line=1, Script=
__bm_OPEN()
org.mozilla.javascript.EcmaError: TypeError: getInitialReference is not
a function. (DataSet[garpOrderconfirm].__bm_OPEN#8)
org.mozilla.javascript.ScriptRuntime.constructError(ScriptRu ntime.java:3240)
org.mozilla.javascript.ScriptRuntime.constructError(ScriptRu ntime.java:3230)
at org.mozilla.javascript.ScriptRuntime.typeError(ScriptRuntime .java:3246)
at org.mozilla.javascript.ScriptRuntime.typeError1(ScriptRuntim e.java:3258)
org.mozilla.javascript.ScriptRuntime.notFunctionError(Script Runtime.java:3317)
org.mozilla.javascript.ScriptRuntime.getPropFunctionAndThis( ScriptRuntime.java:1987)
at org.mozilla.javascript.gen.c6._c1(DataSet[garpOrderconfirm]. __bm_OPEN:8)
at org.mozilla.javascript.gen.c6.call(DataSet[garpOrderconfirm] .__bm_OPEN)
org.mozilla.javascript.optimizer.OptRuntime.callName0(OptRun time.java:105)
at org.mozilla.javascript.gen.c5._c0(DataSource[garpSource].__b m_OPEN:1)
at org.mozilla.javascript.gen.c5.call(DataSource[garpSource].__ bm_OPEN)
at org.mozilla.javascript.ContextFactory.doTopCall(ContextFacto ry.java:304)
at org.mozilla.javascript.ScriptRuntime.doTopCall(ScriptRuntime .java:2769)
at org.mozilla.javascript.gen.c5.exec(DataSource[garpSource].__ bm_OPEN)
org.eclipse.birt.core.script.JavascriptEvalUtil.evaluateScri pt(JavascriptEvalUtil.java:86)
org.eclipse.birt.data.engine.script.ScriptEvalUtil.evaluateJ SAsExpr(ScriptEvalUtil.java:527)
org.eclipse.birt.data.engine.script.JSMethodRunner.runScript (JSMethodRunner.java:79)
org.eclipse.birt.report.engine.script.internal.DtEScriptExec utor.handleJS(DtEScriptExecutor.java:71)
org.eclipse.birt.report.engine.script.internal.DataSetScript Executor.handleJS(DataSetScriptExecutor.java:159)
org.eclipse.birt.report.engine.script.internal.ScriptDataSet ScriptExecutor.handleOpen(ScriptDataSetScriptExecutor.java:6 6)
org.eclipse.birt.data.engine.impl.ScriptDataSetRuntime.open( ScriptDataSetRuntime.java:68)
org.eclipse.birt.data.engine.impl.PreparedScriptDSQuery$Scri ptDSQueryExecutor$CustomDataSet.open(PreparedScriptDSQuery.j ava:204)
org.eclipse.birt.data.engine.impl.PreparedScriptDSQuery$Scri ptDSQueryExecutor.executeOdiQuery(PreparedScriptDSQuery.java :180)
org.eclipse.birt.data.engine.impl.PreparedQuery$Executor.exe cute(PreparedQuery.java:711)
org.eclipse.birt.data.engine.impl.QueryResults.getResultIter ator(QueryResults.java:110)
org.eclipse.birt.report.engine.data.dte.DteDataEngine.execut e(DteDataEngine.java:210)
org.eclipse.birt.report.engine.executor.QueryItemExecutor.op enResultSet(QueryItemExecutor.java:62)
org.eclipse.birt.report.engine.executor.GridItemExecutor.exe cute(GridItemExecutor.java:82)
org.eclipse.birt.report.engine.executor.ReportExecutorVisito r.visitGridItem(ReportExecutorVisitor.java:172)
org.eclipse.birt.report.engine.ir.GridItemDesign.accept(Grid ItemDesign.java:117)
org.eclipse.birt.report.engine.executor.ReportExecutor.execu te(ReportExecutor.java:125)
org.eclipse.birt.report.engine.executor.ReportExecutor.execu te(ReportExecutor.java:89)
org.eclipse.birt.report.engine.api.impl.RunAndRenderTask.run (RunAndRenderTask.java:175)
at com.garp.b2soffline.birt.BirtReport.generateReport(BirtRepor t.java:76)
com.garp.b2soffline.ui.action.CreateBirtReportAction.run(Cre ateBirtReportAction.java:19)
at org.eclipse.jface.action.Action.runWithEvent(Action.java:996 )
org.eclipse.jface.action.ActionContributionItem.handleWidget Selection(ActionContributionItem.java:538)
org.eclipse.jface.action.ActionContributionItem.access$2(Act ionContributionItem.java:488)
org.eclipse.jface.action.ActionContributionItem$5.handleEven t(ActionContributionItem.java:400)
at org.eclipse.swt.widgets.Widget.sendEvent(Widget.java:843)
at org.eclipse.swt.widgets.Display.runDeferredEvents(Display.ja va:3125)
at org.eclipse.swt.widgets.Display.readAndDispatch(Display.java :2758)
at org.eclipse.ui.internal.Workbench.runEventLoop(Workbench.jav a:1699)
at org.eclipse.ui.internal.Workbench.runUI(Workbench.java:1663)
org.eclipse.ui.internal.Workbench.createAndRunWorkbench(Work bench.java:367)
at org.eclipse.ui.PlatformUI.createAndRunWorkbench(PlatformUI.j ava:143)
com.garp.b2soffline.product.workbench.B2SApplication.run(B2S Application.java:27)
org.eclipse.core.internal.runtime.PlatformActivator$1.run(Pl atformActivator.java:226)
org.eclipse.core.runtime.adaptor.EclipseStarter.run(EclipseS tarter.java:376)
org.eclipse.core.runtime.adaptor.EclipseStarter.run(EclipseS tarter.java:163)
at org.eclipse.core.launcher.Main.invokeFramework(Main.java:334 )
at org.eclipse.core.launcher.Main.basicRun(Main.java:278)
at org.eclipse.core.launcher.Main.run(Main.java:973)
at org.eclipse.core.launcher.Main.main(Main.java:948)
Re: rcp + birt engine [message #156799 is a reply to message #156724] Thu, 27 April 2006 11:24 Go to previous messageGo to next message
Erik,
I havent tried it this way. I normally just add the RE jars to my RCP
application.
That said I would think that this would work. Have you tried adding a class
folder to the application (using the Build Path) and putting your pojo
there? Using this method where you able to run a report off the sampledb?
Jason
"Erik Melleg
Re: rcp + birt engine [message #157136 is a reply to message #156799] Fri, 28 April 2006 09:53 Go to previous messageGo to next message
Thank you for your rapid reply.
Now I have tested to generate a report from a design using the
sample-db. It worked perfectly after adding the two following plugins:
org.eclipse.birt.report.data.oda.jdbc_2.0.1
org.eclipse.birt.report.data.oda.sampledb_2.0.1
From this I draw the conclusion that it is possible to use the birt
engine this way, which I feel good about.
My problem with the scripted datasource still exists though.
I have tried to add my POJO-jar-file to the build classpath with no
successs.
I also tried to register my plugin (which contains my POJOs) as a
"Buddy" to org.eclipse.birt.report.engine. by adding the following line
to my plugin manifest file
Eclipse-RegisterBuddy: org.eclipse.birt.report.engine
Other ideas? How can i tell the report engine class loader to look for
the classes in my plugin?
Best regards
Erik
Jason Weathersby wrote:
> Erik,
> application.
> Thanks
> Jason
> "Erik Mellegård" <em@microcraft.se> wrote in message
> news:e2qcnr$b6f$1@utils.eclipse.org...
>>Hi,
>>hands!
>>rcp-application. At this date we don't want the designer and viewer, only
>>the engine so we can generate html and pdf-reports from existing report
>>We have a problem with that approach because we believe that it should be
>>possible to just add dependencies on the required plugins (everything is
>>plugins i eclipse, why add the report engine as something else?). This
>>would probably make it easier to perform updates in future because we
>>don't have to distribute the birt report-engine within the plugin that is
>>using it.
>>org.junit_3.8.1
>>report, Birt don't seem to know about my java-classes (see log below). How
>>Ideas?
>>Best regards
>>Erik Mellegård
>>evaluateJSExpr
>>var orderLocal;
>>var language;
>>var srvurl;
>> //Preview mode. this section will not run on the web-server. This will
>>run in the RCP-app
>> garp =
>> language=" ";
>> //for images
>>} else {
>> srvurl =
>>order=orderLocal;
>>serverurl=srvurl;
>>lang=language;
>>i = odi.length;
>>count = 0;
>>evaluateJSExpr
>>wrapRhinoException
>>__bm_OPEN()
>>org.mozilla.javascript.EcmaError: TypeError: getInitialReference is not a
>>at
>>at
>>at
>>at
>>at
>>at
>>at
>>at
>>at
>>at
>>at
>>at
>>at
>>at
>>at
>>at
>>at
>>at
>>at
>>at
>>at
>>at
>>at
>>at
>>at
>>at
>>at
>>at
>>at
>>at
>>at
>>at
>>at
>>at
>>at
>>at
>>at sun.reflect.NativeMethodAccessorImpl.invoke0(Native Method)
>>at sun.reflect.NativeMethodAccessorImpl.invoke(Unknown Source)
>>at sun.reflect.DelegatingMethodAccessorImpl.invoke(Unknown Source)
>>at java.lang.reflect.Method.invoke(Unknown Source)
Re: rcp + birt engine [message #157181 is a reply to message #157136] Fri, 28 April 2006 10:55 Go to previous messageGo to next message
Erik,
I got this to work with my example by creating a classes directory in my
project.
I uploaded my POJO and then on the Runtime tab of my plugin added the folder
to the Classpath.
Jason
"Erik Melleg
Re: rcp + birt engine [message #157990 is a reply to message #157181] Wed, 03 May 2006 07:41 Go to previous message
I guess that the problem was that my POJOs were embedded inside a
jar-file that made them invisible in some way to the BIRT script
runtime. I solved the problem by adding my factory object as a
ScriptableJavaObject to the task before calling task.run(). Now the
report nows about my classes.
Thanks again for your rapid replies.
/Erik
> Erik,
> project.
> to the Classpath.
> Jason
> news:e2t6oc$tts$1@utils.eclipse.org...
>>Hi,
>>Now I have tested to generate a report from a design using the sample-db.
>>From this I draw the conclusion that it is possible to use the birt engine
>>successs.
>>I also tried to register my plugin (which contains my POJOs) as a "Buddy"
>>to org.eclipse.birt.report.engine. by adding the following line to my
>>Other ideas? How can i tell the report engine class loader to look for the
>>Best regards
>>Erik
>>>Erik,
>>>application.
>>>class folder to the application (using the Build Path) and putting your
>>>pojo there? Using this method where you able to run a report off the
>>>sampledb?
>>>Thanks
>>>Jason
>>>>Hi,
>>>>hands!
>>>>using it.
>>>>org.junit_3.8.1
>>>>Ideas?
>>>>Best regards
>>>>Erik Mellegård
>>>>evaluateJSExpr
>>>>var orderLocal;
>>>>var language;
>>>>var srvurl;
>>>>run in the RCP-app
>>>> garp =
>>>> language=" ";
>>>> //for images
>>>>} else {
>>>> srvurl =
>>>>order=orderLocal;
>>>>serverurl=srvurl;
>>>>lang=language;
>>>>i = odi.length;
>>>>count = 0;
>>>>evaluateJSExpr
>>>>wrapRhinoException
>>>>__bm_OPEN()
>>>>at
>>>>at
>>>>at
>>>>at
>>>>at
>>>>at
>>>>at
>>>>at
>>>>at
>>>>at
>>>>at
>>>>at
>>>>at
>>>>at
>>>>at
>>>>at
>>>>at
>>>>at
>>>>at
>>>>at
>>>>at
>>>>at
>>>>at
>>>>at
>>>>at
>>>>at
>>>>at
>>>>at
>>>>at
>>>>at
>>>>at
>>>>at
>>>>at
>>>>at
>>>>at
>>>>at
>>>>at
>>>>at
>>>>at
Previous Topic:Dynamic parameter over scripted POJO DataSet
Next Topic:Override values on the axis
Current Time: Sat Jul 19 10:10:34 EDT 2025
Powered by FUDForum. Page generated in 0.03455 seconds
