Home » Language IDEs » C / C++ IDE (CDT) » GNU Managed Builds
GNU Managed Builds [message #156684] Mon, 24 October 2005 07:14 Go to next message
I'm trying to create a plugin for a new GNU tool. It's slightly different
from the already supported CDT GNU tools e.g. the
compiler/linker/assembler
have different executable names and different user settable switches (which
I want to allow the user to select graphically).
My approach is to copy the existing plug-in
("org.eclipse.cdt.managedbuilder.gnu.ui_3.0.0") and base my new plugin on
this.
Some questions:
1. Is this the best approach ?
2. The existing plug seems to add the MINGW header files to a new project
automatically. How is this controlled ? (I need to disable it).
Thanks in advance,
Hugh,,
Re: GNU Managed Builds [message #157104 is a reply to message #156684] Mon, 31 October 2005 12:54 Go to previous message
> this.
> Some questions:
Does the current toolchain for gcc have different compiler/linker
switches, or is there just other naming, and/or additional switches?
If yes, then your approach seems reasonable. Otherwise, take a first
look on the MBS-documentation, maybe its sufficient to create a new
toolchain by adding a plugin.xml under a new toolchain plugin.
The switches declared in plugin.xml correlate to the UI, I think. (did
not take a look lately, since I use a new toolchain right now at work).
This can be disabled in the project settings under "Discovery Settings"
Tab. This also depends if your MinGW or cygwin is installed and which
one is first in PATH. (Should be changeable when using absolut paths to
the tools in the settings pages).
> Thanks in advance,
> Hugh,,
Previous Topic:How to include path in Standard project
Next Topic:The CDT can not work!
Current Time: Sat Aug 30 20:47:42 EDT 2025
Powered by FUDForum. Page generated in 0.04436 seconds
