| elements dragged out of border [message #156679] |
Mon, 22 October 2007 11:31  |
Originally posted by: exquis.nospam.com
Hi All,
I am facing this problem where when I drag an item out of the boundary of
parent container, the item as well as its connections with other child
items becomes invisible. Two small arrows comes in the corner to show that
you can scroll but its kind of confusing as I am not sure how many people
will see those small arrows in the corner. I am looking for a solution
where when I drag the child item out of the parent boundary and parent
border should also stretch and allow child item to visible inside it,
istead of getting disappeared. What should be the approach for this.
| Re: elements dragged out of border [message #157351 is a reply to message #156710] |
Fri, 26 October 2007 15:38  |
Does the parent container resize itself to the size you want when you
press the Autosize button? If so, you could leave the parent container
in autosize mode always (that is, the bounds constraint should have a
size of (-1,-1)) and remove the resizable editpolicy.
Cherie
exquis wrote:
> Let me explain more accurately. I want to stop user from resizing the
> parent container if because of resizing any child element getting
> hidden. I think that way the problem will be resolved. How can I enforce
> this.
FUDForum. Page generated in 0.55821 seconds
