Home » Modeling » GMF (Graphical Modeling Framework) » Iterate through Diagram roots
Iterate through Diagram roots [message #156639] Mon, 22 October 2007 06:10 Go to next message
Originally posted by: trommas.yahoo.com
I want to iterate through all books, no matter which diagram root they
belong to.
I've tried this to iterate through all libraries (diagram roots), but it
only iterate through a single library.
for (Resource a : library.eResource().getResourceSet().getResources()) {
Library library = (Library) resource.getContents().get(0);
for (Book book : library.getBooks()) {
System.out.println(book.getName());
Any ideas?
Tomas
Re: Iterate through Diagram roots [message #156663 is a reply to message #156639] Mon, 22 October 2007 07:35 Go to previous messageGo to next message
-----BEGIN PGP SIGNED MESSAGE-----
Hash: SHA1
try tree iterator:
e.g.
/* TreeIterator<EObject> allContents = res.getAllContents();
Package package_ = null;
while (allContents.hasNext()) {
new UMLSwitch<Object>() {
public Object caseProfile(Profile profile) {
System.out.println("TreeIterator "+profile);
return profile;
}.doSwitch(allContents.next());
> belong to.
> Any ideas?
> Tomas
-----BEGIN PGP SIGNATURE-----
Version: GnuPG v2.0.7 (GNU/Linux)
Comment: Using GnuPG with Mozilla - http://enigmail.mozdev.org
iD8DBQFHHIr5IYVWjMSpDwwRAnFJAKDD58U/NooKCtz5EeSAqiDwAyzyzwCf b2uH
Mtpsb0kSo27b8HgV/SBNmJ0=
=C2lt
-----END PGP SIGNATURE-----
Re: Iterate through Diagram roots [message #156671 is a reply to message #156663] Mon, 22 October 2007 09:36 Go to previous messageGo to next message
Thanks SKuhn.
It's unfortunately not possible (or very difficult) to iterate all
diagram roots (because they are in different files etc.)
So I have some other ideas (The problem is that my model elements wraps
objects from a owl-file (they have listeners attached), this causes sync
problems with gmf):
Is there perhaps a refresh diagram command I could call when the user
selects a tab (or switches focus to a window) with a diagram in it?, or
(slightly more unattractive) I could make a menu element which runs an
update command on the diagram.
Any suggestions or tips welcome :)
Tomas
Re: Iterate through Diagram roots [message #156685 is a reply to message #156671] Mon, 22 October 2007 12:23 Go to previous messageGo to next message
Hash: SHA1
they're also in another ResourceSet or EditingDomain? If not, iterate
over every Resource in your ResourceSet.
There's a handleMajorSemanticChange command in the EditParts. I'm not
sure what it's doing exactly, but it already helped me once. I just
figured out that it's refreshing nearly every element in the diagram.
- -stefan
iD8DBQFHHM5lIYVWjMSpDwwRAupxAJ97zBa01XtA8+QgE2KhF4P23kVOkACc Cmn2
WvqonfJ2m0kZRttEg3BXYSk=
=3Zrn
handleMajorSemanticChange (was: Iterate through Diagram roots) [message #157847 is a reply to message #156685] Wed, 31 October 2007 05:08 Go to previous message
How strange! I searched for the methodcall to handleMajorSemanticChange
and found it in the taipan and mindmap projects I've downloaded.. But
not in my own plugins!
The method it called ex from TopicEditPart's handleNotificationEvent
method. My similar class has no handleMajorSemanticChange method at all
(and hence handleMajorSemanticChange is never called)
Why is this?
Tomas Zijdemans
Previous Topic:Adding menu to GMF diagram
Next Topic:property sheet attributes customization
Current Time: Wed Nov 12 13:20:17 EST 2025
Powered by FUDForum. Page generated in 0.04672 seconds
