| How to execute Macro in standard Make C project? [message #156562] |
Thu, 20 October 2005 16:53 |
I'm trying to see if CDT is going to be adaptable for my project. My
existing c source has a reference to a macro called COMP_INC(). For
example in the c source file it looks like this:
#include COMP_INC(kernal, init.h)
The indexer is failing with: C/C++ Indexer problem: Invalid preprocessor
directive: {0} in file: <path to file> Which points to the above
include line.
In the project properties, C/C++ Include Paths & Symbols, I've entered
the path to the macro, where the .h resides to support the macro. But I
get the same error.
I next tried to set a -imacros directive in the "Discovery Options" for
the "Compiler invocation command" as follows: /tools/bin/gcc -imacros
/vob/comp/make-lib/preinclude_macros.h. But when I make a change in the
source, and save it, then the indexer or scanner fails with: "Error
launching external scanner info generator (/tools/bin/gcc -imacros
/vob/comp/make-lib/preinclude_macros.h -E -P -v -dD
/var/eclipse/projects/ios-project-31/.metadata/.plugins/org. eclipse.cdt.make.core/specs/cpp) ".
Any ideas how I can get Indexer/scanner to expand the macro in the c source?
Thanks for the help in advance.
frank
FUDForum. Page generated in 0.04290 seconds
