Home » Newcomers » Newcomers » XML-Editor (urgently)
| XML-Editor (urgently) [message #156482] |
Mon, 12 June 2006 16:14  |
Originally posted by: felipd.hotmail.com
i tried to use the Xml-Editor-Plugin (Standard of Eclipse) in my
RCP-Application "Rcp application with a view", also Standard of Eclipse,
but it doesn't work.
The Error:
"Invalid Menu Extension (Path is invalid):
org.eclipse.ui.edit.text.gotoLastEditPosition"
What should I do?
| Re: XML-Editor (urgently) [message #156543 is a reply to message #156526] |
Tue, 13 June 2006 05:07   |
Daniel Megert wrote:
> Jos wrote:
>> Hello,
>> Eclipse, but it doesn't work.
> There is no XML editor in the Eclipse SDK. Do you mean the Ant Editor?
> Dani
>> The Error:
>> What should I do?
>> Thanks,
Hello Dani,
the Xml Editor is one of the "Templates to generate a fully-functioning
plug-in".
"Editor. This template creates a basic XML editor. It has all the basic
functions of an editor, such as cut, copy, paste, find, etc. It also has
syntax highlighting and supports double-clicking."
When we create a new plugin from this editor-template, that's what I meant.
| Re: XML-Editor (urgently) [message #156549 is a reply to message #156543] |
Tue, 13 June 2006 06:01   |
>> Jos wrote:
>>> Hello,
>> Dani
>>> The Error:
>>> What should I do?
>>> Thanks,
> Hello Dani,
> fully-functioning plug-in". "Editor. This template creates a basic XML
> editor. It has all the basic functions of an editor, such as cut,
> copy, paste, find, etc. It also has syntax highlighting and supports
> double-clicking."
> meant.
Ah, OK I see. This adds a dependency to org.eclipse.ui.editors (as shown
in the wizard). You probably miss that plug-in in your required list.
Note that org.eclipse.ui.editors is not an RCP plug-in and will drag in
IDE related stuff.
Dani
| Re: XML-Editor (urgently) [message #156997 is a reply to message #156549] |
Thu, 15 June 2006 09:25   |
Hello again,
>> Hello Dani,
>> double-clicking."
>> meant.
> IDE related stuff.
I don't miss that plug-in in my required list.
I will tell you step by step what i'm trying to do.
I have created a Rich Client Application:
File -> New -> Project -> Plug-in Project
Project name, for example: "Test"
-> Next
"Would like to create a rich client application" -> yes
now "create a plug-in using on of the templates"
-> RCP Mail Template
-> Next
-> Finish
Now I have my RCPApplication (Name = Test) already.
Then I want to use one Xml-Editor in this application.
I create the plug-in:
Project name, for example: "XmlEditor"
-> Next
"Would like to create a rich client application" -> no
-> Plug-in with an Editor
-> Next
-> Finish
So, I have the Plug-in Application and the Editor Plug-in
Now I add the Editor Plug-in "XmlEditor" in Dependencies from Plugin.xml
from "Test" and in -> Run -> Run -> Plug-ins, now "Deselect All", I select
"Teste" and "XmlEditor" (Workspace Plug-ins) and "add required plug-ins".
There is no problems by "validate Plug-in Set".
Now I click "apply" and "run". When I run, it comes a message "Invalid
org.eclipse.ui.edit.text.gotoLastEditPosition". I try to open a file in
the application: "file" -> "open file". I choose a XmlFile, but the editor
that appears is a normally Text-Editor. The Xml-Editor doesn't work.
Please, do what i did step by step and you will see how it is.
| Re: XML-Editor (urgently) [message #157529 is a reply to message #156997] |
Mon, 19 June 2006 13:08   |
Hello, I need still help
Jos wrote:
> Hello again,
>>> Hello Dani,
>>> double-clicking."
>>> meant.
>> IDE related stuff.
> -> Next
> -> Next
> -> Finish
> -> Next
> -> Next
> -> Finish
> Thanks
| Re: XML-Editor (urgently) [message #157772 is a reply to message #157529] |
Wed, 21 June 2006 06:02   |
> Jos wrote:
>> Hello again,
>>>> Hello Dani,
>>>> XML editor. It has all the basic functions of an editor, such as
>>>> cut, copy, paste, find, etc. It also has syntax highlighting and
>>>> I meant.
>>> shown in the wizard). You probably miss that plug-in in your
>>> required list. Note that org.eclipse.ui.editors is not an RCP
>>> plug-in and will drag in IDE related stuff.
>> I don't miss that plug-in in my required list. I will tell you step
>> Project name, for example: "Test" -> Next
>> -> Next -> Finish
>> Now I have my RCPApplication (Name = Test) already. Then I want to
>> Project name, for example: "XmlEditor" -> Next
>> -> Next -> Finish
>> Plugin.xml from "Test" and in -> Run -> Run -> Plug-ins, now
>> "Deselect All", I select "Teste" and "XmlEditor" (Workspace Plug-ins)
>> and "add required plug-ins". There is no problems by "validate
>> Plug-in Set".
>> in the application: "file" -> "open file". I choose a XmlFile, but
>> the editor that appears is a normally Text-Editor. The Xml-Editor
>> doesn't work.
Works for me using 3.2 RC7 or latest 3.3 build (I20060620-1010).
Dani
>> Thanks
| Re: XML-Editor (urgently) [message #158103 is a reply to message #157772] |
Thu, 22 June 2006 09:58   |
>> Jos wrote:
>>> Hello again,
>>>>> Hello Dani,
>>>>> I meant.
>>> -> Next -> Finish
>>> -> Next -> Finish
>>> Plug-in Set".
>>> doesn't work.
I tried with 3.2 RC7, there is still a problem: The log
!SESSION 2006-06-22 15:55:17.598
eclipse.buildId=unknown
java.version=1.5.0_06
BootLoader constants: OS=win32, ARCH=x86, WS=win32, NL=de_DE
Framework arguments: -application Noc.application
Command-line arguments: -application Noc.application -data
\\ws1\dantas\Profile\workspace2/../runtime-EclipseApplicatio n(4) -dev
file://ws1/dantas/Profile/workspace2/.metadata/.plugins/org. eclipse.pde.core/Eclipse
Application (4)/dev.properties -os win32 -ws win32 -arch x86
!ENTRY org.eclipse.osgi 4 0 2006-06-22 15:55:19.692
!MESSAGE Application error
!STACK 1
java.lang.RuntimeException: Application "Noc.application" could not be
found in the registry. The applications available are:
org.eclipse.ant.core.antRunner,
org.eclipse.help.base.infocenterApplication,
org.eclipse.help.base.helpApplication, org.eclipse.help.base.indexTool,
org.eclipse.jdt.apt.core.aptBuild, org.eclipse.jdt.core.JavaCodeFormatter,
org.eclipse.pde.build.Build,
org.eclipse.pde.junit.runtime.uitestapplication,
org.eclipse.pde.junit.runtime.coretestapplication,
org.eclipse.ui.ide.workbench, org.eclipse.update.core.standaloneUpdate,
org.eclipse.update.core.siteOptimizer.
org.eclipse.core.internal.runtime.PlatformActivator$1.run(Pl atformActivator.java:68)
org.eclipse.core.runtime.internal.adaptor.EclipseAppLauncher .runApplication(EclipseAppLauncher.java:92)
org.eclipse.core.runtime.internal.adaptor.EclipseAppLauncher .start(EclipseAppLauncher.java:68)
org.eclipse.core.runtime.adaptor.EclipseStarter.run(EclipseS tarter.java:400)
org.eclipse.core.runtime.adaptor.EclipseStarter.run(EclipseS tarter.java:177)
at org.eclipse.core.launcher.Main.invokeFramework(Main.java:336 )
at org.eclipse.core.launcher.Main.basicRun(Main.java:280)
at org.eclipse.core.launcher.Main.run(Main.java:977)
at org.eclipse.core.launcher.Main.main(Main.java:952)
> Dani
>>> Thanks
| Re: XML-Editor (urgently) [message #158522 is a reply to message #158103] |
Tue, 27 June 2006 09:07  |
Please, I still need an answer!
Jos
>>> Jos wrote:
>>>> Hello again,
>>>>>> Hello Dani,
>>>>>> I meant.
>>>> -> Next -> Finish
>>>> -> Next -> Finish
>>>> Plug-in Set".
>>>> doesn't work.
> \ws1dantasProfileworkspace2/../runtime-EclipseApplication(4) -dev
> !STACK 1
> at
> at
> at
> at
> at
>> Dani
>>>> Thanks
Current Time: Sun Nov 23 14:48:46 EST 2025
Powered by FUDForum. Page generated in 0.09783 seconds
