Home » Newcomers » Newcomers » how to use IContextInformation with proposals
| how to use IContextInformation with proposals [message #156411] |
Sun, 11 June 2006 23:47  |
Originally posted by: rathish_j.thbs.com
Hi All
right now i am using CodeAssistant in my plugin with the help of
CompletionProposal API, i want show Context Information along with the
proposal. But the problem is, i don't how to integrate the proposal with
context information. That means whenever proposal selection changes, i have
to change the proposal information.
i am using context information like this.
IContextInformation info = new ContextInformation(displayStr, "Message");
proposals[proposalCount++] = new CompletionProposal (displayStr,
documentOffset, 0, displayStr.length(), lclsDesc.createImage(),
completion.trim(), info, "");
it's right or we have manually change the context information on the events?
thank u
rathish raj j
| Re: how to use IContextInformation with proposals [message #156417 is a reply to message #156411] |
Mon, 12 June 2006 02:07   |
Originally posted by: tom_eicher.ch.ibm.com
Ratish, what are you trying to accomplish, and what does not work as you
would expect?
Notes on terminology: "Context information" is the small tooltip that is
shown once a proposal has been inserted (for example, the parameter
hints after inserting a Java method proposal).
"Additional information" is shown while the proposal popup is presenting
the choices. An example for this is the javadoc information shown for
Java proposals. See ICompletionProposal::getAdditionalProposalInfo().
What is the "proposal selection"?
Sounds good to me - the proposal popup should show "Message" once the
proposal is applied.
Which events?
-tom
| Re: how to use IContextInformation with proposals [message #156428 is a reply to message #156417] |
Mon, 12 June 2006 05:09   |
Hello Tom,
Thank u for ur replay,
i want display the documentation information while proposal popup is
presented. i am giving additional information in
my CompeletionProposal constructor, but still i am not seeing the additional
information
completion.trim(), info, "Information");
any other way to set additional information?
rathish raj j
"Tom Eicher" <tom_eicher@ch.ibm.com> wrote in message
news:e6j0bn$koi$1@utils.eclipse.org...
> would expect?
> shown once a proposal has been inserted (for example, the parameter hints
> the choices. An example for this is the javadoc information shown for Java
>> have to change the proposal information.
>> events?
> Which events?
> -tom
| Re: how to use IContextInformation with proposals [message #156432 is a reply to message #156428] |
Mon, 12 June 2006 05:49   |
> information
Rathish, simply use the other constructor of CompletionProposal and pass
in the additionalProposalInfo parameter.
-tom
| Re: how to use IContextInformation with proposals [message #156444 is a reply to message #156432] |
Mon, 12 June 2006 11:20   |
Hello Tom
as far as is know, in the another constructor we don't have additional
information parameter. I think there must be some way to trigger it.
rathish
news:e6jdb7$tk5$1@utils.eclipse.org...
> -tom
| Re: how to use IContextInformation with proposals [message #156460 is a reply to message #156444] |
Mon, 12 June 2006 11:44  |
Hello Tom
i got how to use the additional information on the proposals. we have
set the InformationControlCreator like this.
assistant.setInformationControlCreator(getMyInformationContr ol(sourceViewer));
private IInformationControlCreator getMyInformationControl(ISourceViewer
sourceViewer)
return new IInformationControlCreator() {
public IInformationControl createInformationControl(Shell parent)
return new DefaultInformationControl(parent);
Thank u
rathish
"Rathish" <rathish_j@thbs.com> wrote in message
news:e6k02k$tc0$1@utils.eclipse.org...
> Hello Tom
> Thanks
> rathish
>> -tom
Current Time: Thu Nov 06 05:45:25 EST 2025
Powered by FUDForum. Page generated in 0.08819 seconds
