| Charting in RCP application [message #156407] |
Wed, 26 April 2006 14:45  |
Originally posted by: techjunkie01876.gmail.com
We are developing an enterprise application client in Eclipse RCP
framework. As part of it, we need to incorporate charts and graphs that
are clickable.
I am wondering if we can use BIRT charting framework for displaying charts
within an SWT composite. If so, what plugins out of BIRT are required? I'd
appreciate if anyone can point me to the right docs. Thanks.
Regards.
| Re: Charting in RCP application [message #157073 is a reply to message #156922] |
Fri, 28 April 2006 07:23  |
Pete,
Yes, you can use the chart builder, you will need a few more plugins in that
case
org.eclipse.birt.chart.ui
org.eclipse.birt.chart.ui.extension
org.eclipse.birt.core.ui
Please take a look at the org.eclipse.birt.chart.examples plugin for some
examples of Chart API use and Chart Builder use outside of BIRT reports.
This plugin has a lot of examples, and should cover most use cases, so it's
a good place to get started.
David
"Pete" <techjunkie01876@gmail.com> wrote in message
news:c760705a857bf203fc0b263fbe51740e$1@www.eclipse.org...
> Thanks David. I did manage to produce some charts within my RCP app. But,
> find it very difficult to explore without proper docs. All BIRT docs talk
> about chart builder tool and I am not sure that tool can be used for
> creating charts within RCP app.
FUDForum. Page generated in 0.03812 seconds
