| Notification not working [message #156384] |
Fri, 19 October 2007 07:22  |
Originally posted by: trommas.yahoo.com
I have debugged an error, and it seems like this line in setName()
crashes, when I call setName from the getname method.
eNotify(new ENotificationImpl(this, Notification.SET,
EditorPackage.CLASS_NODE__NAME, oldName, name));
Why would a notification crash? (it's parameters - oldName and name are
correct and valid)
Tomas
| Re: Notification not working [message #156493 is a reply to message #156393] |
Fri, 19 October 2007 11:01   |
-----BEGIN PGP SIGNED MESSAGE-----
Hash: SHA1
you should create a command and execute it on through the commandStack.
If you want to make it undoable by eclipse you want to use
AbstractEMFCommand.
This might help you as an example, it applies a profile to a package:
private static class ApplyProfile extends AbstractEMFOperation{
Package package_;
Profile profile;
public ApplyProfile(TransactionalEditingDomain editingDomain,
org.eclipse.uml2.uml.Package package_,Profile profile) {
super(editingDomain, "ApplyProfile "+profile.getName());
this.package_=package_;
this.profile=profile;
protected IStatus doExecute(IProgressMonitor monitor,
IAdaptable info) throws ExecutionException {
try{
package_.applyProfile(profile);
return org.eclipse.core.runtime.Status.OK_STATUS;
} catch (Exception e){
return org.eclipse.core.runtime.Status.CANCEL_STATUS;
And is executed by:
// Ausfuehren
AbstractEMFOperation op = new
ApplyProfile((TransactionalEditingDomain) editingDomain,model,oioProfile);
try {
UMLDiagramEditorPlugin.getInstance().getWorkbench().getOpera tionSupport().getOperationHistory().execute(op,
new NullProgressMonitor(), null);
} catch (ExecutionException e) {
UMLDiagramEditorPlugin.getInstance().logError("www.OiO.de Profile
Application Error" , e);
For background information, read the EMF-Transaction Tutorials
Working with EMF Operations and Creating Transactions.
You can find both in the Eclipse Help.
- -stefan
Tomas Zijdemans schrieb:
> Thanks :)
> I made a try catch, which resultet in:
> java.lang.IllegalStateException: Cannot modify resource set without a
> write transaction
> Alex Shatalin wrote:
>> Hello Tomas,
>> Can you post a stacktrace of "crash" here?
>> Alex Shatalin
-----BEGIN PGP SIGNATURE-----
Version: GnuPG v2.0.7 (GNU/Linux)
Comment: Using GnuPG with Mozilla - http://enigmail.mozdev.org
iD8DBQFHGMbIIYVWjMSpDwwRAlFRAJ99Oees6Cvv1p72YtGRhTrTDTlVkgCf RK4b
nuX8F9U6KU782hK+AP4Z4lY=
=El+1
-----END PGP SIGNATURE-----
| Re: Notification not working [message #156951 is a reply to message #156493] |
Wed, 24 October 2007 07:58  |
Thanks, but I really just need a simple command that sets a name to an
element.
I've tried to get this working with:
TransactionalEditingDomain domain = TransactionUtil.getEditingDomain(book);
CommandStack stack = domain.getCommandStack();
// execute some change
Command cmd = domain.createCommand(SetCommand.class, new
CommandParameter(book, EditorPackage.BOOK__NAME, "dummy"));
stack.execute(cmd);
But I think I'm getting the editing domain wrong, any suggestions?
Tomas
> Hash: SHA1
> AbstractEMFCommand.
> Package package_;
> Profile profile;
> @Override
> try{
> And is executed by:
> // Ausfuehren
> try {
> - -stefan
>> Thanks :)
>> write transaction
>>> Hello Tomas,
>>> Alex Shatalin
> =El+1
FUDForum. Page generated in 0.36713 seconds
