Home » Archived » BIRT » problems integrating the report engine
problems integrating the report engine [message #156320] Wed, 26 April 2006 05:39 Go to next message
When I try to integrate the report engine into an application I get
the error that the extension id in the data source is missing:
26.04.2006 10:35:11
org.eclipse.birt.report.engine.data.dte.AbstractDataEngine prepare
SCHWERWIEGEND: Missing extenion id in data source definition, Datenquelle
org.eclipse.birt.report.engine.api.EngineException: Missing extenion id in
I use the flatfile datasource as an example...
What could be the cause of this? The extension id is present in the
rptdesign
file.
Any ideas?
Peter
Re: problems integrating the report engine [message #156324 is a reply to message #156320] Wed, 26 April 2006 05:40 Go to previous messageGo to next message
... and (as you might have guessed) I try to use 2.1RC1a ...
Re: problems integrating the report engine [message #170144 is a reply to message #156324] Wed, 14 June 2006 08:17 Go to previous message
Originally posted by: antpoure.yahoo.fr
I have exactly the same problem and like you no idea from where it could come from
Previous Topic:Add labels to points at scattercharts
Next Topic:Error code:EXTENSION_POINT_NOT_FOUND
Current Time: Sun Nov 23 14:13:53 EST 2025
Powered by FUDForum. Page generated in 0.04399 seconds
