Home » Modeling » GMF (Graphical Modeling Framework) » PDE/EMF/GMF
PDE/EMF/GMF [message #156319] Thu, 18 October 2007 11:04 Go to next message
Originally posted by: rego.gmail.com
Hi Guys,
I am not sure if I am asking at the right place but any guidance will be
helpful sorry for the trouble.
I was a J2EE developer and recently started working on Plugin/EMF/GMF, I
am reading and understanding the things but "Hello World!!!" kind of
examples or reading a lot without actual examples don't help you in real
projects. Can you point me to some references or books or training where I
can get some info about
1. how to customize the generated code
2. how the APIs are put together means when to use what API for
customization
3. Also I am seeing a lot of use of anonymous classes as well as command
and adapter pattern and callback methods. I am not very comfortable in
coding in that way.
So any kind of help or resource by anybody will be appreciated.
Re: PDE/EMF/GMF [message #156323 is a reply to message #156319] Thu, 18 October 2007 11:17 Go to previous messageGo to next message
-----BEGIN PGP SIGNED MESSAGE-----
Hash: SHA1
well, you might want to take a look at IBMs EMF/GEFs Redbook. You find a
bunch of links in the wiki, too.
http://wiki.eclipse.org/GMF_Documentation_Index
- -stefan
rego quanta schrieb:
> Hi Guys,
> I can get some info about 1. how to customize the generated code 2. how
> the APIs are put together means when to use what API for customization
> coding in that way.
-----BEGIN PGP SIGNATURE-----
Version: GnuPG v2.0.7 (GNU/Linux)
Comment: Using GnuPG with Mozilla - http://enigmail.mozdev.org
iD8DBQFHF3j1IYVWjMSpDwwRAu8rAKCURKQEaD2sbsOFEE4TT+lIw6rJqwCg yc17
tO7zrX4tHISj5QSdUt/72Es=
=SZ21
-----END PGP SIGNATURE-----
Re: PDE/EMF/GMF [message #156331 is a reply to message #156323] Thu, 18 October 2007 11:32 Go to previous messageGo to next message
--------------010307040502030809040800
Rego,
With regard to EMF, this is documentation central:
http://www.eclipse.org/modeling/emf/docs/
Some of the overviews would be good to read since they answer many of
your questions.
Following this simple tutorial and playing with the code will help get
your feet wet:
< http://dev.eclipse.org/viewcvs/indextools.cgi/*checkout*/org .eclipse.emf/doc/org.eclipse.emf.doc/tutorials/xlibmod/xlibm od.html>
> Hash: SHA1
> - -stefan
>> Hi Guys,
>> coding in that way.
> =SZ21
<html>
<head>
http-equiv="Content-Type">
</head>
Rego,<br>
<br>
With regard to EMF, this is documentation central:<br>
<blockquote><a href="http://www.eclipse.org/modeling/emf/docs/">http://www.eclipse.org/modeling/emf/docs/</a><br>
</blockquote>
your questions.<br>
<br>
your feet wet:<a
href=" http://dev.eclipse.org/viewcvs/indextools.cgi/*checkout*/org .eclipse.emf/doc/org.eclipse.emf.doc/tutorials/xlibmod/xlibm od.html"><br>
</a>
<blockquote><a
href=" http://dev.eclipse.org/viewcvs/indextools.cgi/*checkout*/org .eclipse.emf/doc/org.eclipse.emf.doc/tutorials/xlibmod/xlibm od.html"> http://dev.eclipse.org/viewcvs/indextools.cgi/*checkout*/org .eclipse.emf/doc/org.eclipse.emf.doc/tutorials/xlibmod/xlibm od.html</a><br>
</blockquote>
<br>
SKuhn wrote:
<blockquote cite="mid:ff7tfc$565$1@build.eclipse.org" type="cite">
<pre wrap="">-----BEGIN PGP SIGNED MESSAGE-----
Hash: SHA1
<a class="moz-txt-link-freetext" href="http://wiki.eclipse.org/GMF_Documentation_Index">http://wiki.eclipse.org/GMF_Documentation_Index</a>
- -stefan
</pre>
<blockquote type="cite">
<pre wrap="">Hi Guys,
coding in that way.
</pre>
</blockquote>
<pre wrap=""><!---->
Comment: Using GnuPG with Mozilla - <a class="moz-txt-link-freetext" href="http://enigmail.mozdev.org">http://enigmail.mozdev.org</a>
=SZ21
</pre>
</blockquote>
<br>
</body>
</html>
--------------010307040502030809040800--
Re: PDE/EMF/GMF [message #156490 is a reply to message #156331] Fri, 19 October 2007 10:45 Go to previous message
thanks a lot ED Skhun.
Previous Topic:GMF vs. MERLIN vs. GME
Next Topic:diagram partitioning cookbook
Current Time: Mon Nov 24 07:03:57 EST 2025
Powered by FUDForum. Page generated in 0.04036 seconds
