Home » Archived » BIRT » Using the DE API
Using the DE API [message #156304] Wed, 26 April 2006 03:46
Has anybody any help on how to use the DE API when using
version 2.1 (either rc0 or rc1a).
When I use the design engine api as described for 2.0.1 but with version
2.1rc1a
I get an exception
26.04.2006 08:26:09 org.eclipse.birt.report.model.metadata.ExtensionLoader
logExtenstionException
SCHWERWIEGEND: Message:The extension point
[org.eclipse.birt.report.model.reportItemModel] is not found. Error
code:EXTENSION_POINT_NOT_FOUND
Ignoring the exception an reading the designfile anyway results in the
problem that most properties are lost. E.g. when I analyse a dataset the
extensionID is no longer available. The resulting designfile is then
unusable...
Could somebody point me to sourcecode where the DE API Version 2.1 is
used!?
Or maybe a hint where the above exception comes from. The documentation for
2.0.1 points out that the exception occurs when I am not using 2.0.1...
Peter
Previous Topic:Dynamic images
Next Topic:BIRT 2.0.1: Page break ignored in PDF
Current Time: Sun Jul 27 07:15:41 EDT 2025
Powered by FUDForum. Page generated in 0.23303 seconds
