Home » Eclipse Projects » Eclipse Platform » code generation issue
code generation issue [message #156276] Thu, 13 November 2003 06:49 Go to next message
Originally posted by: veith.pixel.de
hi,
IMO, the setting "java" -> "code generation" -> "code and comments"
should be moved to the project settings. If yu're working on different
projects for different clients (buyers) you should have the facility to
easily switch the class description template according to the current
project / client.
Gernot
Re: code generation issue [message #156284 is a reply to message #156276] Thu, 13 November 2003 07:37 Go to previous message
Originally posted by: manahan.NOSPAM.ca.ibm.com
You can request that here: https://bugs.eclipse.org/bugs/
Peter
Gernot Veith wrote:
> hi,
> project / client.
> Gernot
Previous Topic:Eclipse crashes on startup
Next Topic:Context menu missing standard group
Current Time: Fri Jul 18 00:16:22 EDT 2025
Powered by FUDForum. Page generated in 0.26947 seconds
