Home » Eclipse Projects » GEF » DialogBox on object creation
DialogBox on object creation [message #14641] Mon, 22 July 2002 09:56 Go to next message
Originally posted by: jol.linuxgames.com
I've a GraphicalEditorWithPalette, in my palette i've define some entry
(PaletteToolEntry).
I've define a class Test which extends CreationTool to modify the
performCreation which is called when the objet is created on the surface.
My problem is :
I want to be able to display a dialog box when the object is created ( when
performCreation is called). How can i get the workbench shell to display a
modal dialog box ? Or a better Suggestion
Thanks a lot,
Jol
Re: DialogBox on object creation [message #14849 is a reply to message #14641] Mon, 22 July 2002 12:31 Go to previous messageGo to next message
Originally posted by: none.ibm.com
You can just create the dialog inside performCreation();
The dialog should probably me modal to:
this[....the tool].getCurrentViewer().getControl().getShell();
"vennin joel" <jol@linuxgames.com> wrote in message
news:ahh0vp$f9v$1@rogue.oti.com...
> Hello,
> (PaletteToolEntry).
> My problem is :
when
> Thanks a lot,
> Jol
Re: DialogBox on object creation [message #14965 is a reply to message #14849] Tue, 23 July 2002 09:27 Go to previous message
Thanks again ! ;)
"Randy Hudson" <none@ibm.com> a
Previous Topic:[newbie] Help! How do I get this going?
Next Topic:Status Line
Current Time: Sat Nov 22 14:06:02 EST 2025
Powered by FUDForum. Page generated in 0.27008 seconds
