Home » Modeling » GMF (Graphical Modeling Framework) » Name not being updated
Name not being updated [message #156242] Thu, 18 October 2007 08:02 Go to next message
Originally posted by: trommas.yahoo.com
My model element (ClassNode) wraps an object from an OWL file. When I
run several editors, the object can be wrapped by multiple ClassNodes
(in different editors). getName() returns the wrapped object's name -
But this will differ from it's own name variabel if some other ClassNode
has edited it.
What I was thinking was to use an if. If the wrapped object's name has
changed, the model element should display the new name. I have tried to
fire a notification without success.
The properties tab gets the correct name, and normally I would use a Set
request.. But I can't since the change is detected in the getName()
method of ClassNode.
Any ideas?
Tomas
Re: Name not being updated [message #156270 is a reply to message #156242] Thu, 18 October 2007 08:57 Go to previous messageGo to next message
-----BEGIN PGP SIGNED MESSAGE-----
Hash: SHA1
first check if the 'label'editPart receives the notification.
- -stefan
> has edited it.
> Any ideas?
> Tomas
-----BEGIN PGP SIGNATURE-----
Version: GnuPG v2.0.7 (GNU/Linux)
Comment: Using GnuPG with Mozilla - http://enigmail.mozdev.org
iD8DBQFHF1ghIYVWjMSpDwwRAsgsAKCdg02ZT+fI+zMxe66luvU+yLa5FQCg 5DYK
XlvdQ/IqJU2fPRZ0Cs4sHcg=
=qFXZ
-----END PGP SIGNATURE-----
Re: Name not being updated [message #156286 is a reply to message #156270] Thu, 18 October 2007 09:37 Go to previous messageGo to next message
Thanks. I've checked out my ClassNodeNameEditPart. There don't seem to
be happening anything (I checked with the getLabelText() method).
However, if I duplicate a model element, the new element (the dup) picks
up the correct name.
Tomas
> Hash: SHA1
> - -stefan
>> has edited it.
>> Any ideas?
>> Regards,
>> Tomas
> =qFXZ
Re: Name not being updated [message #156294 is a reply to message #156286] Thu, 18 October 2007 10:20 Go to previous message
Hash: SHA1
your ClassNodeNameEditPart should listen to changes in the semantic
model. Normally, they're doing this through EditPolicies installed on
the editPart. The default generated EditParts should to this
automatically. I would take a look at the adapters which are listening
to your property/EObject, your ClassNodeNameEditPart or one of his
EditPolicies should be there.
- -stefan
> Tomas
> -stefan
>>>> has edited it.
>>>> Any ideas?
>>>> Regards,
>>>> Tomas
iD8DBQFHF2uZIYVWjMSpDwwRAmn4AKDZl97Zkb0THoI00C3x1Hvr/x6QQwCe OU9U
Jh9nNUZBcfj8Lv0BK4QQjbc=
=rUTJ
Previous Topic:Popup menuelements appear where they shouldn't
Next Topic:Using ColorCellEditor
Current Time: Fri Jul 25 22:01:48 EDT 2025
Powered by FUDForum. Page generated in 0.04620 seconds
