Home » Eclipse Projects » GEF » Event loop exception usually caused by what reason?
Event loop exception usually caused by what reason? [message #156230] Sun, 31 October 2004 19:12 Go to next message
Originally posted by: hitdemo2002.yahoo.com.cn
when i draged a model from palette to viewer,it was show a error dialog:
Unhandled event loop exception
Reason:
java.lang.NullPointerException?
but i could't confirm where to locate errors,use eclipse debug logic to me
is difficult.event loop exception usually caused by what reason?
Re: Event loop exception usually caused by what reason? [message #156239 is a reply to message #156230] Sun, 31 October 2004 21:57 Go to previous messageGo to next message
error log is:
!MESSAGE Problems occurred when invoking code from plug-in:
"org.eclipse.core.runtime".
!STACK 0
org.eclipse.gef.internal.ui.properties.PropertySheetEntry.co mputePropertyDescriptorsFor(PropertySheetEntry.java:213)
org.eclipse.gef.internal.ui.properties.PropertySheetEntry.co mputeMergedPropertyDescriptors(PropertySheetEntry.java:170)
org.eclipse.gef.internal.ui.properties.PropertySheetEntry.re freshChildEntries(PropertySheetEntry.java:472)
org.eclipse.gef.internal.ui.properties.PropertySheetEntry.se tValues(PropertySheetEntry.java:668)
org.eclipse.ui.views.properties.PropertySheetViewer.setInput (PropertySheetViewer.java:805)
org.eclipse.ui.views.properties.PropertySheetPage.selectionC hanged(PropertySheetPage.java:370)
org.eclipse.ui.views.properties.PropertySheet.selectionChang ed(PropertySheet.java:185)
org.eclipse.ui.internal.AbstractSelectionService$3.run(Abstr actSelectionService.java:153)
org.eclipse.core.internal.runtime.InternalPlatform.run(Inter nalPlatform.java:616)
at org.eclipse.core.runtime.Platform.run(Platform.java:747)
org.eclipse.ui.internal.AbstractSelectionService.fireSelecti on(AbstractSelectionService.java:151)
org.eclipse.ui.internal.AbstractSelectionService$1.selection Changed(AbstractSelectionService.java:66)
org.eclipse.gef.ui.parts.AbstractEditPartViewer.fireSelectio nChanged(AbstractEditPartViewer.java:240)
org.eclipse.gef.ui.parts.AbstractEditPartViewer.appendSelect ion(AbstractEditPartViewer.java:171)
org.eclipse.gef.ui.parts.AbstractEditPartViewer.select(Abstr actEditPartViewer.java:562)
org.eclipse.gef.tools.SelectEditPartTracker.performSelection (SelectEditPartTracker.java:209)
org.eclipse.gef.tools.SelectEditPartTracker.performCondition alSelection(SelectEditPartTracker.java:155)
org.eclipse.gef.tools.SelectEditPartTracker.handleButtonDown (SelectEditPartTracker.java:89)
at org.eclipse.gef.tools.AbstractTool.mouseDown(AbstractTool.ja va:977)
at org.eclipse.gef.tools.SelectionTool.mouseDown(SelectionTool. java:490)
at org.eclipse.gef.EditDomain.mouseDown(EditDomain.java:201)
org.eclipse.gef.ui.parts.DomainEventDispatcher.dispatchMouse Pressed(DomainEventDispatcher.java:327)
org.eclipse.draw2d.LightweightSystem$EventHandler.mouseDown( LightweightSystem.java:503)
org.eclipse.swt.widgets.TypedListener.handleEvent(TypedListe ner.java:132)
at org.eclipse.swt.widgets.EventTable.sendEvent(EventTable.java :82)
at org.eclipse.swt.widgets.Widget.sendEvent(Widget.java:796)
at org.eclipse.swt.widgets.Display.runDeferredEvents(Display.ja va:2772)
at org.eclipse.swt.widgets.Display.readAndDispatch(Display.java :2431)
at org.eclipse.ui.internal.Workbench.runEventLoop(Workbench.jav a:1377)
at org.eclipse.ui.internal.Workbench.runUI(Workbench.java:1348)
org.eclipse.ui.internal.Workbench.createAndRunWorkbench(Work bench.java:254)
at org.eclipse.ui.PlatformUI.createAndRunWorkbench(PlatformUI.j ava:141)
at org.eclipse.ui.internal.ide.IDEApplication.run(IDEApplicatio n.java:96)
org.eclipse.core.internal.runtime.PlatformActivator$1.run(Pl atformActivator.java:335)
org.eclipse.core.runtime.adaptor.EclipseStarter.run(EclipseS tarter.java:273)
org.eclipse.core.runtime.adaptor.EclipseStarter.run(EclipseS tarter.java:129)
at org.eclipse.core.launcher.Main.basicRun(Main.java:185)
at org.eclipse.core.launcher.Main.run(Main.java:704)
at org.eclipse.core.launcher.Main.main(Main.java:688)
!ENTRY org.eclipse.ui 4 4 十一月 01, 2004 10:50:14.609
!MESSAGE Unhandled event loop exception
!ENTRY org.eclipse.ui 4 0 十一月 01, 2004 10:50:14.609
!MESSAGE java.lang.NullPointerException
!STACK 0
org.eclipse.gef.tools.ToolUtilities.getSelectionWithoutDepen dants(ToolUtilities.java:35)
org.eclipse.gef.tools.DragEditPartsTracker.createOperationSe t(DragEditPartsTracker.java:166)
org.eclipse.gef.tools.AbstractTool.getOperationSet(AbstractT ool.java:586)
org.eclipse.gef.tools.DragEditPartsTracker.captureSourceDime nsions(DragEditPartsTracker.java:124)
org.eclipse.gef.tools.DragEditPartsTracker.setState(DragEdit PartsTracker.java:542)
org.eclipse.gef.tools.AbstractTool.stateTransition(AbstractT ool.java:1257)
org.eclipse.gef.tools.SelectEditPartTracker.handleButtonDown (SelectEditPartTracker.java:97)
Re: Event loop exception usually caused by what reason? [message #156261 is a reply to message #156239] Mon, 01 November 2004 05:33 Go to previous messageGo to next message
Originally posted by: dyx.gmx.net
Open
org.eclipse.gef.internal.ui.properties.PropertySheetEntry.co mputePropert=
yDescriptorsFor(IPropertySource =
source)
(From project`s package explorer click: =
Plugin-Dependencies->gef.jar->org.eclipse.gef.internal.ui.properties.Pro=
pertySheetEntry)
and set a break point in the first line of the method.(just rightclick o=
n =
th bar beside the line and choose toggle breakpoint.) Then run as debug=
and see what is null.
It should be either either source or source.getDescriptors()returns null=
Maybe you implement IPropertySource in your model, but in the
getDescriptors method return null somewhere?
> error log is:
> =3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D =3D=3D=3D=3D=
=3D
> !STACK 0
> at
> org.eclipse.gef.internal.ui.properties.PropertySheetEntry.co mputePrope=
> at
> org.eclipse.gef.internal.ui.properties.PropertySheetEntry.co mputeMerge=
> at
> org.eclipse.gef.internal.ui.properties.PropertySheetEntry.re freshChild=
> at
> org.eclipse.gef.internal.ui.properties.PropertySheetEntry.se tValues(Pr=
> at
> org.eclipse.ui.views.properties.PropertySheetViewer.setInput (PropertyS=
> at
> org.eclipse.ui.views.properties.PropertySheetPage.selectionC hanged(Pro=
> at
> org.eclipse.ui.views.properties.PropertySheet.selectionChang ed(Propert=
ySheet.java:185)
> at
> org.eclipse.ui.internal.AbstractSelectionService$3.run(Abstr actSelecti=
onService.java:153)
> at
> org.eclipse.core.internal.runtime.InternalPlatform.run(Inter nalPlatfor=
m.java:616)
> at
> org.eclipse.ui.internal.AbstractSelectionService.fireSelecti on(Abstrac=
> at
> org.eclipse.ui.internal.AbstractSelectionService$1.selection Changed(Ab=
> at
> org.eclipse.gef.ui.parts.AbstractEditPartViewer.fireSelectio nChanged(A=
> at
> org.eclipse.gef.ui.parts.AbstractEditPartViewer.appendSelect ion(Abstra=
> at
> org.eclipse.gef.ui.parts.AbstractEditPartViewer.select(Abstr actEditPar=
tViewer.java:562)
> at
> org.eclipse.gef.tools.SelectEditPartTracker.performSelection (SelectEdi=
> at
> org.eclipse.gef.tools.SelectEditPartTracker.performCondition alSelectio=
> at
> org.eclipse.gef.tools.SelectEditPartTracker.handleButtonDown (SelectEdi=
> at org.eclipse.gef.tools.AbstractTool.mouseDown(AbstractTool.ja va:977=
> at org.eclipse.gef.tools.SelectionTool.mouseDown(SelectionTool. java:4=
90)
> at
> org.eclipse.gef.ui.parts.DomainEventDispatcher.dispatchMouse Pressed(Do=
> at
> org.eclipse.draw2d.LightweightSystem$EventHandler.mouseDown( Lightweigh=
tSystem.java:503)
> at
> org.eclipse.swt.widgets.TypedListener.handleEvent(TypedListe ner.java:1=
32)
> at org.eclipse.swt.widgets.Display.runDeferredEvents(Display.ja va:277=
2)
> at org.eclipse.swt.widgets.Display.readAndDispatch(Display.java :2431)=
> at org.eclipse.ui.internal.Workbench.runEventLoop(Workbench.jav a:1377=
> at
> org.eclipse.ui.internal.Workbench.createAndRunWorkbench(Work bench.java=
:254)
> at org.eclipse.ui.PlatformUI.createAndRunWorkbench(PlatformUI.j ava:14=
1)
> at =
> org.eclipse.ui.internal.ide.IDEApplication.run(IDEApplicatio n.java:96)=
> at
> org.eclipse.core.internal.runtime.PlatformActivator$1.run(Pl atformActi=
vator.java:335)
> at
> org.eclipse.core.runtime.adaptor.EclipseStarter.run(EclipseS tarter.jav=
a:273)
> at
a:129)
> at
> sun.reflect.NativeMethodAccessorImpl.invoke(NativeMethodAcce ssorImpl.j=
ava:39)
> at
> sun.reflect.DelegatingMethodAccessorImpl.invoke(DelegatingMe thodAccess=
orImpl.java:25)
> !ENTRY org.eclipse.ui 4 4 十一月 01, 2004 10:50:14.6=
09
> !ENTRY org.eclipse.ui 4 0 十一月 01, 2004 10:50:14.6=
09
> !STACK 0
> at
> org.eclipse.gef.tools.ToolUtilities.getSelectionWithoutDepen dants(Tool=
Utilities.java:35)
> at
> org.eclipse.gef.tools.DragEditPartsTracker.createOperationSe t(DragEdit=
> at
> org.eclipse.gef.tools.AbstractTool.getOperationSet(AbstractT ool.java:5=
86)
> at
> org.eclipse.gef.tools.DragEditPartsTracker.captureSourceDime nsions(Dra=
> at
> org.eclipse.gef.tools.DragEditPartsTracker.setState(DragEdit PartsTrack=
er.java:542)
> at
> org.eclipse.gef.tools.AbstractTool.stateTransition(AbstractT ool.java:1=
257)
> at
90)
> at
> at
tSystem.java:503)
> at
32)
2)
> at
:254)
1)
> at =
> at
vator.java:335)
> at
a:273)
> at
a:129)
> at
ava:39)
> at
orImpl.java:25)
Using Opera's revolutionary e-mail client: http://www.opera.com/m2/
Re: Event loop exception usually caused by what reason? [message #156430 is a reply to message #156230] Mon, 01 November 2004 09:14 Go to previous messageGo to next message
Originally posted by: eostroukhov.hotmail.com
Check your <runtime workspace>/.metadata/.log file
"hitdemo2002" <hitdemo2002@yahoo.com.cn> wrote in message
news:cm3v85$lgd$1@eclipse.org...
> Reason:
Re: Event loop exception usually caused by what reason? [message #156433 is a reply to message #156430] Mon, 01 November 2004 09:15 Go to previous message
Oops I still need to learn what those plus signes along the messages mean :)
sorry.
"Eugene Ostroukhov" <eostroukhov@hotmail.com> wrote in message
news:cm5gbv$g6m$1@eclipse.org...
> > Reason:
me
Previous Topic:short question about LocationPropertySource in logic example
Next Topic:Migrate logic example to RCP platform?
Current Time: Sun Nov 09 03:53:45 EST 2025
Powered by FUDForum. Page generated in 0.03218 seconds
