Home » Eclipse Projects » eRCP » Re: Integrating eRCP Javadoc
Re: Integrating eRCP Javadoc [message #1206] Thu, 11 June 2009 18:44 Go to next message
I found a bug report concerning this issue:
https://bugs.eclipse.org/bugs/show_bug.cgi?id=275501
On 16.02.2009 11:36, Matthias Schoettle wrote:
> how can I integrate the eRCP Javadoc into eclipse for developing?
> I tried adding the location to "Additional source code locations" in the
> source code settings for the target platform but this didn't work.
> Thanks
> Matthias
Re: Integrating eRCP Javadoc [message #1707 is a reply to message #1206] Mon, 29 June 2009 14:38 Go to previous messageGo to next message
An eRCP SDK is now available that includes JavaDoc and source. If you don't
already have the Eclipse 3.5 IDE, then I suggest downloading Pulsar and the
eRCP SDK is a one click install from there.
Otherwise, use the Eclipse installer to install the SDK from the update site
at www.eclipse.org\ercp\pulsar
"Matthias Schoettle" <eclipse@mattsch.com> wrote in message
news:h0s1cs$ane$1@build.eclipse.org...
>> Thanks
>> Matthias
Re: Integrating eRCP Javadoc [message #1715 is a reply to message #1707] Thu, 09 July 2009 12:06 Go to previous messageGo to next message
Thanks for providing the eRCP SDK.
Is it possible to install the SDK when using Eclipse 3.4 (Ganymede)?
>>> Hi,
>>> Thanks
>>> Matthias
Re: Integrating eRCP Javadoc [message #478968 is a reply to message #1715] Fri, 07 August 2009 13:27 Go to previous message
Yes, you can install into Eclipse 3.4 or 3.5.
news:h354hu$2t3$1@build.eclipse.org...
>> don't already have the Eclipse 3.5 IDE, then I suggest downloading Pulsar
>> and the eRCP SDK is a one click install from there.
>> site at www.eclipse.org\ercp\pulsar
>>>> Hi,
>>>> the source code settings for the target platform but this didn't work.
>>>> Thanks
>>>> Matthias
Re: Integrating eRCP Javadoc [message #563237 is a reply to message #1206] Mon, 29 June 2009 14:38 Go to previous message
>> Thanks
>> Matthias
Re: Integrating eRCP Javadoc [message #563257 is a reply to message #1707] Thu, 09 July 2009 12:06 Go to previous message
>>> Hi,
>>> Thanks
>>> Matthias
Re: Integrating eRCP Javadoc [message #563536 is a reply to message #1715] Fri, 07 August 2009 13:27 Go to previous message
>>>> Hi,
>>>> Thanks
>>>> Matthias
Previous Topic:eEMF on eRCP
Next Topic:Running examples with Windows Mobile 6.1 and WEME-WM50-ARM-PPRO11_6.1.1.20070306-115235
Current Time: Mon Jul 21 21:10:26 EDT 2025
Powered by FUDForum. Page generated in 0.50842 seconds
