Home » Eclipse Projects » GEF » Palette Questions
Palette Questions [message #155920] Wed, 27 October 2004 15:21 Go to next message
Originally posted by: dyx.gmx.net
What`s the difference between PaletteTemplateEntry and CreationEntry ?
How does the logicexample`s LogicPlugin.createComplexTemplatePartsDrawer=
know how to build the model objects ? It is only given the String =
constant TemplateConstants.TEMPLATE_FULL_ADDER and no model.class in a =
factory.
Re: Palette Questions [message #156018 is a reply to message #155920] Thu, 28 October 2004 15:36 Go to previous message
The template drop target on the logic's diagram looks at the string and runs
it through a switch statement. You can use any mechanism you wish. In
fact, the template could be a creation factory if you want.
"Frank Dyck" <dyx@gmx.net> wrote in message news:opsgjmpqjt0i05et@celeron...
How does the logicexample`s LogicPlugin.createComplexTemplatePartsDrawer()
factory.
Previous Topic:Problem with DelegatingLayout
Next Topic:PaletteCustomizer possible with standard i.e. non-Flyout palette?
Current Time: Sat Nov 15 06:05:14 EST 2025
Powered by FUDForum. Page generated in 0.03805 seconds
