| Use of Facets [message #14611] |
Thu, 05 February 2009 08:29  |
I tried to define a facet for my project.
Context:
- I imported the SID model in Tigerstripe with the SID Import plugin
- Now I want to reduce the model to just the packages I need
- The packages I need are:
* Problem_ABE under Logical_View/Common_Business_Entities_Domain
* Service_Problem_ABE under Logical/View/Service_Domain
I create a SPM facet object in my project.
Then I try to define the scope. when I click on the "Add" button of the
Included patterns", the only thing that is proposed is the default
artifact package I defined for my project: org.tmforum.interfaces. I
discovered after a few trials that I can edit this string to specify the
pattern I need: Logical_View/Common_Business_Entities_Domain/Porblem_ABE/*
But the way to do that is not really evident.
More serious problem: I want only to have the objects in the 2 packages
above, not the objects, not the objects inherited, dependent, refereenced
or associated.
The current behaviour seems to include all of the above and the GUI for
defining the scope does not allow show the various checkboxes that are
defined in the doc pages.
Marc
| Re: Use of Facets [message #14642 is a reply to message #14611] |
Thu, 05 February 2009 10:11   |
Hi Marc,
Agreed, the scope definition (ie. Figuring out that the default package name
can be edited is far from obvious. Some usability improvement much needed
there).
What you are describing below though is different from the intent of a
facet. The facet is intended to be a "valid self-contained submodel", which
means we will include the extended artifacts no matter what, unless you
explicitly exclude everything manually (by listing them in the exclude
clause).
It seems you're more interested in a filtering mechanism. We currently have
no plan to do that. Could you maybe provide a bit context as what you're
trying to accomplish?
Eric
On 2/5/09 1:29 PM, in article
3fb65bf9b6c7f3ad1373aff85a5a3a1c$1@www.eclipse.org, "Marc FLAUW"
<marc.flauw@hp.com> wrote:
> Hello,
> Context:
> or associated.
> Best regards,
> Marc
| Re: Use of Facets [message #14672 is a reply to message #14642] |
Thu, 05 February 2009 12:34  |
Eric,
Yes, I want to do filtering out of all the parts I don't need. I will send
you a more detailed mail tomorrow.
Marc
| Re: Use of Facets [message #564444 is a reply to message #14611] |
Hi Marc,
there).
clause).
Eric
> Hello,
> Context:
> or associated.
> Best regards,
> Marc
| Re: Use of Facets [message #564467 is a reply to message #14642] |
Eric,
Marc
FUDForum. Page generated in 0.04370 seconds
