Home » Eclipse Projects » GEF » Create a block arrow
Create a block arrow [message #155500] Mon, 25 October 2004 17:06 Go to next message
Originally posted by: pavan.podila.gmail.com
--------------040004090503030605080600
I want to make a ConnectionEditPart that has a block arrow as it's
figure. What is the right way to do it ? I am thinking of using the
Polygon figure but not sure if it would automatically stretch. Any
pointers in this regard are greatly appreciated.
I have attached an image that depicts my requirement.
Pavan
Content-Type: image/gif;
name="arrow.gif"
Content-Disposition: inline;
filename="arrow.gif"
R0lGODlh8QAxAHAAACwAAAAA8QAxAIcAAAAICAgMDBAcHBwkKCgsLCw4PDw8 PDxMTExdXWFt
cXVxcXGRlZmlpaWlrrKusrq+vr7K0tre3t7m5ubq7vb29vb///8AAAAAAAAA AAAAAAAAAAAA
AAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAA AAAAAAAAAAAA
AAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAI/wAtCBxIsKDB gwgTKlzIsKHD
hxAjSpxIsWCFBRUqatzIsaPHjyBDNpQQAEFGkShTqlzJsmVBCQMcmHRJs6bN mzdhUpB5EqfP
n0CDjhxAYedMoUiTKq2psyjPpVCjSt3Y1OnRqVizaiVY1WrPrWDDIu3qVazZ szmJFl1r9Cva
t3A/kl37NK7duxTn0r2Kt69fhHr3uv1LuG9gwYUTG1bLtnFbxZDhHmZb12AC AJgza97MubPn
z6BDix5NurTp06hTq95swLHrxwYPPHhNu7bt27hz697Nu7fv38CDN648ULbw 48iTK1/OvLlv
4haMO59Ovbr1682JS8fOvbv379crb/8HT768+fO2645Hz769e+xP17+fT78+ cJ7y7evfz78x
gwT59SfggO1FcIAEARKo4ILcGShBdLMxKOGE1jkoUIIUZqghbxZeGOGGIIaY W4ceimjiiY6R
WCKKLIqo4oUFHCDjjDTWaOONOOao44489ujjj0AGKeSQRNKowIgHHiQBBEw2 6eSTUEYp5ZRU
VmnllVhmqeWWXHbppZMNMFbbi5GVmdVkRZFp5ppRoakmm3AmNdmbcdYJ1GF0 2qlnWq/lueef
LunlJ6CEqjTXoIUmGhJZiCrqaEddNfropBVVJSmlmEbU1KWZdjoUBZx6KmpC MIU66qkvCZAk
qqxONAEBD2oCFBAAOw==
--------------040004090503030605080600--
Re: Create a block arrow [message #155673 is a reply to message #155500] Tue, 26 October 2004 11:05 Go to previous messageGo to next message
"Any pointers". lol.
I would just subclass Figure or Shape and override paint (or outline/fill
for shapes).
I'm assuming you want to treat this arrow like a rectangle.
"Pavan Podila" <pavan.podila@gmail.com> wrote in message
news:cljm03$6ad$1@eclipse.org...
> Pavan
Re: Create a block arrow [message #155826 is a reply to message #155673] Wed, 27 October 2004 00:31 Go to previous messageGo to next message
I will be using this as a ConnectionEditPart. So when I move figures
connected by this arrow, will the arrow be automatically stretched. How
do I specify the size of the arrow. Do I give direct values for the
length of the arrow ? "Pointers" needed again.
> for shapes).
>>Hi,
>>Thanks,
>>Pavan
Re: Create a block arrow [message #155865 is a reply to message #155826] Wed, 27 October 2004 09:57 Go to previous message
To do what you are trying, you will need to create a custom connection
implementation.
You could extend PolylineConnection, but you'd be changing the way bounds
calculation and painting is done completely.
news:417F248C.9090207@gmail.com...
outline/fill
> > for shapes).
> >>Hi,
> >>Thanks,
> >>Pavan
Previous Topic:I have confused by create my connection?
Next Topic:Popup menu problem
Current Time: Sun Nov 16 06:27:39 EST 2025
Powered by FUDForum. Page generated in 0.04384 seconds
